My key won't turn steering wheel is not locked
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UMC, Jan 31, 2024.
  1. Jan 31, 2024 at 9:18 AM
    UMC
    UMC [OP] I will not comply
    Thomas
    South Fork of the American river.
    13 TRD Sport DCLB 4x4
    35's & rear locker
    Got in truck this morning and trying to turn key and it won't turn. The steering wheel is NOT locked. Any suggestion?
  2. Jan 31, 2024 at 9:20 AM
    1schoir
    1schoir Well-Known Member
    Freeport, NY
    2006 Red Tacoma SR5 Access Cab 5 speed..1995 Blue Tacoma Extra Cab 4 cyl 5 speed...
    It sounds like your key got worn out to the point where it will not depress the tumblers.
    It would not hurt to spray some HHS 2000 lube or graphite powder into the lock.
    MR5X5 likes this.
  3. Jan 31, 2024 at 9:24 AM
    NJOffRoad
    NJOffRoad Well-Known Member
    Anthony
    Pine Barrens, NJ
    2021 Cement TRD OR 4x4
    -Off-Grid Engineering Dual Battery system with Redarc BCDC1225D and Full Throttle Group 35 AGM -SPOD BantamX -Expedition Essentials 3TPAM -Spiker Engineering hood struts -Taco Vinyl raptor grill -Baja Designs Squadron Sport fogs -Baja Designs Squadron Pro ditch lights -KC Cyclones under-hood lights -ARB Twin Compressor -Mobtown Offroad Skids & Sliders -Diamondback Tonneau Cover
    oh man. this happened to my subaru legacy and I needed a new ignition cylinder to the tune of like $500, which was like 10% of what the cars value was at the time. I'd try 1schoir's suggestion and see if you can get yours working. Do you have a spare key to try?
  4. Jan 31, 2024 at 9:27 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I'd try the key in the outside door lock.
    That will tell you if its a key fitment issue.
    Kolter45 and T Fades like this.
  5. Jan 31, 2024 at 9:38 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Is the truck in park?
    Strictlytoyz and TnShooter like this.
  6. Jan 31, 2024 at 9:41 AM
    MR5X5
    MR5X5 Well-Known Member
    Happened to me. Worn key, gummy cylinder. Got a new key cut and sprayed a lot of Houdini lock spray (Lowe's) into the lock, lots of key in/out cycles, and it started working again. No issues since.
  7. Jan 31, 2024 at 10:00 AM
    UMC
    Thomas
    35's & rear locker
    Thanks for the suggestions I'll try spraying something in there see if that works if not I'll try a spare key. I don't have a spare key so I need to go to the dealer and get one made. I had somewhere to be today so someone else came and picked me up I'll try this later.
    TomTwo likes this.
  8. Jan 31, 2024 at 10:06 AM
    TnShooter
    Deogee
    STOCK
    I'd try the key in the door lock first.
    No need in spraying stuff in the ignition if the key wont work.
    I doubt your issue is due to stuck pins in the ignition.
    I'd also try putting the truck in Neutral and trying the key.
    The key wont turn if its in any gear other than Park or Neutral.
    UMC[QUOTED][OP] and T Fades like this.
  9. Feb 1, 2024 at 9:58 AM
    UMC
    Thomas
    35's & rear locker
    I went to the dealer and had them make me a new key then took that home and it worked. I had to hold the old key close to it so it would start the engine. I then took it to the dealer to have them program the new key and I got a spare key programmed as well.
    I should have done this a long time ago. I often drive out in the middle of nowhere. If this happened there it would have been epic..
    Fyi the old key did work in the door handle to unlock but would not work in the ignition.
    Thanks for the help guys.
    TnShooter and TomTwo like this.
  10. Feb 1, 2024 at 1:26 PM
    MR5X5
    Glad you got it fixed. Hopefully the dealer didn't bend you over too badly. For future reference, FWIW, you can buy programmable key blanks off Amazon, and key programmers off eBay or the likes and do it yourself for under $100.
    UMC[OP] and 1schoir like this.
  11. Feb 1, 2024 at 2:30 PM
    UMC
    Thomas
    35's & rear locker
    Thanks . It was pretty bad. I'm going to try to forget about that now. Hopefully there's never a next time.
    TnShooter likes this.
  12. Feb 3, 2024 at 8:04 PM
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    All that matters is it's fixed, time and your next paycheck will cushion the impact, besides you're not stranded in BFE.
