My Konig Countersteer Offroad Type X fitment problems
Discussion in 'Wheels & Tires' started by vermintrex, Dec 30, 2010.
  1. Dec 30, 2010 at 4:10 PM
    vermintrex
    vermintrex [OP] Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    So...my Toyota dealership tried to fit my brand new 17" Konig Countersteer Offroad Type X's today, and ended up refusing to do so because they rubbed the front fender where the mud flaps bolt on. They showed me a video of them going from lock to lock and the inboard tread did in fact push the rear of the fender out quite a bit, till it let go and snapped back into place as the tires pushed past. They barely cleared the front of the fender, but sneaked past.
    Sooo...my question is, do you guys think a 1.6" front lift (Eibach springs on 5100's) will give me enough clearance to fit the Countersteer's wrapped in 265/70/17's ? Would it be enough for the suspension to cycle through it's travel without making contact ? I don't think even removing the mudflaps (which I don't want to do) would have given enough clearance with the stock suspension.
    The Konig's are 8 inch wide with a -10 Offset. I don't know what that works out to for backspacing but they sit farther out of the fenders than stock.
    As a side note for anyone considering these rims, your stock lug nuts won't work, you'll need longer ones. Also, they had to use a thin walled socket to be able to fit between the nuts and the bolt holes, so you'd need to carry a socket with you in the truck in case of a flat.
    Any help from the wheel and tire gurus would be appreciated. What a frustrating day...thought I was gonna be able to post pic's for you guys.
  2. Dec 31, 2010 at 5:18 AM
    TRDsport253
    TRDsport253 Well-Known Member
    Fife, Wa
    05 PreRunner TRDsport
    TRD Cold air TRD Cat-back
    Can't wait to see some pics.:)
  3. Dec 31, 2010 at 6:11 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    That works out to approx 4" backspacing. They shouldn't rub too bad with the 265/70's. If anything it's because they sit out a little further than is ideal.
    Most tuner wheel companies (Konig, Rays, Volk, etc.) use spline-drive lug nuts. They are skinnier than normal lugs.
  4. Dec 31, 2010 at 8:36 AM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    What about a 1.6" lift up front, think that would give me enough clearance to keep the flaps on ?
    Thanks for the help.
  5. Dec 31, 2010 at 8:42 AM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    It was rubbing bad enough to flex the fender, I wouldn't want that to be a regular thing. I know tons of guys run BFG A/T's with aftermarket rims and still have their flaps, but maybe most of them are lifted too.
    I'll dig up some more info on spline drive lug nuts.
    Thanks for the help
  6. Dec 31, 2010 at 8:47 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    you need more backspace.
  7. Dec 31, 2010 at 9:27 AM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    Maybe these are gonna be more hassle than it's worth. I waited 2 months for these fuckin things to be shipped, thought it was gonna be a straightforward bolt up :mad:
    Anyone know what trucks these will bolt up to nicely. If I'm gonna have to sell them I guess I need to know my target market.
  8. Dec 31, 2010 at 10:40 AM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    I think what I'm gonna do is remove the front flaps and then take it in to a proper tire shop and get them to set up one wheel and see if it it still rubs. If it doesn't then I'll have them install everything including the TPMS swap.
    Then I'll get the 5100's with Eibach springs. Once I've got the front lifted I can always try the front flaps again, if it still rubs...oh well, no front flaps.
    Thanks for the help guys, I'll update the thread once I've got something to show.
  9. Dec 31, 2010 at 8:14 PM
    tacoyaki
    tacoyaki Active Member
    PM me if you wanna sell...thanks. Im local.
  10. Jan 2, 2011 at 7:06 PM
    westbank
    westbank Active Member
    Gord
    Calgary
    2010 4WD LB
    Good info nonetheless on the Type X. What shipping supplier did the wheels arrive with and did you have any brokerage/duty charges?
  11. Jan 4, 2011 at 8:33 PM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    They were sent USPS from the seller (JLB Motorsports) and came the rest of the way by Canada Post. I had to pay $33 Cdn duty on the first two to arrive, the third and fourth arrived seperately a couple days later, but wasn't charged any further duty.
    I've since removed the front flaps and I'm taking them into Kal Tire on the weekend for a test fit, if they don't rub I'll get them installed.
  12. Jan 4, 2011 at 10:17 PM
    niptek
    niptek Well-Known Member
    the countersteer offroad X should fit after you do the lift. Trimming will be necessary for no rubbing issues. good luck. i own a set at the moment with 285/75/16 with nitto terra grapplers. Spacers in the front push them out, so i can get some more stability with lift.
  13. Jan 5, 2011 at 6:25 PM
    westbank
    Gord
    Calgary
    2010 4WD LB
    Good to know on the shipping. I've been talking to JLB about the different shipping methods. Just deciding between the 16s & 17s.
  14. Jan 5, 2011 at 8:31 PM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    I'm only gonna be running 265/70/17's and they only contacted the mudflaps the first time. If they still rub with the flaps removed the only thing I could trim is the fender itself...which obviously ain't gonna happen.
  15. Jan 5, 2011 at 9:03 PM
    tacomadude18
    tacomadude18 Well-Known Member
    carlitos
    Glenwood Springs, CO
    SR5 TRD Sport DCLB
    AFE cold air intake,tinted windows, Snug top, Brand New XD Addicts 17x9 with a -12 offset. (hopefully get a 6 inch lift kit, also wanna get an exuast system..) new! Exelon Kenwood with 12" rockford punch
    Rim Information
    Rim Brand: XD Series
    Number of Bolts: 6
    Rim Material: Alloy
    Rim Width: 9
    Bolt Pattern: 6x139.7
    Rim Structure: One Piece
    Rim Diameter: 17
    Offset: -12
    so, do i need to cut if i get these?
  16. Jan 5, 2011 at 9:05 PM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    can you start your own thread please, thanks.
  17. Jan 5, 2011 at 9:12 PM
    tacomadude18
    carlitos
    SR5 TRD Sport DCLB
    i already have, im just trying to get info. you dont have to awser it. (douche)
  18. Jan 5, 2011 at 9:28 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    how is he being a douche? it's called thread jacking, and do some reading before you start asking simple questions.
  19. Jan 6, 2011 at 6:56 AM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    I don't want this thread derailed.
    I have not resolved my own fitment problems yet and if this thread becomes the general "will this fit" thread it becomes useless to me and all those who have tried to help me out.
    Learn a bit about forum etiquette before you start throwing around insults.
    Good luck with your rims.
  20. Jan 6, 2011 at 7:00 AM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    Be aware that JLB will not accept foreign credit cards, you will either need to pay with a US credit card, bank draft or Western Union money transfer.
    Not much (actually none) security for the buyer, but I took a chance and everything worked out.
