My LED Gauge and AC Lights Install
Discussion in '1st Gen. Tacomas (1995-2004)' started by SRQ TACO, Feb 7, 2011.
  1. Feb 7, 2011 at 3:01 PM
    SRQ TACO
    SRQ TACO [OP] Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    The guidline to doing the install can be found here.
    http://www.customtacos.com/tech/index.php?article=77
    Ok heres what I used for the install
    For the gauge cluster led's use 194's and you will need 2 of them if you have no tach and 4 if you have a tach. Make sure to get the leds that have 5 led's and that use a wide angle like these.
    http://www.superbrightleds.com/cgi-b...cs/WLED-x5.htm
    For the A/C controls it requires #74 bulbs it takes 2 for the controls and those bulbs can be single led's like these.
    http://www.superbrightleds.com/cgi-b...pecs/74-x.html
    If you follow what I said you will have results like mine(I used all blue led's).
    If you guys have any questions just let me know I'm here to help.
  2. Feb 7, 2011 at 4:31 PM
    giscott
    giscott Well-Known Member
    Scott
    Austin
    2003 TRD SR5 PreRunner DC Revtek 3" Lift,
    The product links aren't working for me.
  3. Feb 8, 2011 at 4:09 AM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    1995 Tacoma 4X4
    ARE Impulse Shell, BFG AT KO's
    Man that is NICE. Putting that on my to do list!
  4. Feb 8, 2011 at 4:44 AM
    jazzystoy69
    jazzystoy69 ((( FOR THOSE ABOUT TO ROCK , I SALUTE YOU )))
    Joseph
    CONNECTICUT
    LITTLEPUNISHER
    Intake mod - Flowmaster super40 - cree reverse lights - Grillecraft - MetalMiller emblem - Bilstien 5100s front and back - Spidertraxs 1.5 - AFE prodry S filter - Extang Black Max cover - Black muffler tip - 20% Tints All Around - Energy Poly Sway Bar Bushings - Sway Bar Links - AVS Hood Bug Defflector - AVS Black smoked window rain guards - Engine Silicone Hoses - sockmonkey bedside badges - sockmonkey TRD windshield Decal - westing step bars - snobord Light Bar & Hella Black Magic 500 Lights - TRD shift Knobs - Black shorty antena - dee zee all weather floor mats -Black Smoked LEDS Euro tail Lights - T R D Custom Front Plate - T R D 3rd brake Light Cover - Tail Gate Seal -CoverKing neoprene seat covers.
    cant wait to the weather (snow) clears .thats going to be for me. .Great Look.
  5. Nov 3, 2013 at 6:22 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr Mojo Risin
    Josh
    Canton and Marietta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Build
    Great write up, definitely going to be using this. Is there a way to change the light ring around the ignition? Planning on doing this during my Christmas break so just doing some research ahead of time.
  6. Nov 4, 2013 at 11:54 PM
    SRQ TACO
    Damon
    Sarasota, Florida
    Yes you can I think it's a little 94 bulb
  7. Nov 5, 2013 at 2:26 PM
    BYJOSHCOOK
    Josh
    Check Out My Build
    ok thanks! I'll look into that
