My Lift (decisions)
Discussion in 'Suspension' started by jmed99, Mar 25, 2010.
  1. Mar 25, 2010 at 5:56 PM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    Ok, I'm taking my taco (09 DC TRD OR 2 x4) to the dealership to get the susp TSB performed next Friday. I do absolutely no off roading. I would like a 3" lift.
    My buddy has a revtec spacer in the front and some kind of a ford lift on the back he bought for $40. He has Moto 17" 951s and BFG AT's (285/70/17). His rides very well and he does not have the TSB done. He has had this setup for a while and loves it....no problems at all! He works at a tire shop and says he can align it perfectly with no problems.
    I was leaning toward the toytec ultimate kit but he has me convinced to go with the spacer up front not to mention it's cheaper. I'm guessing after the TSB, I'll still need to AAL for the rear to get it leveled.
    What are the cons of the spacers if I don't do any off roading? He love he set up so I'm just wondering if this is the way I should go.
    Please help! Thanks guys!:D
  2. Mar 25, 2010 at 6:02 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Tsb does aal and adds height to the rear so no you don't need another aal
  3. Mar 25, 2010 at 6:56 PM
    jmed99
    SC
    According to the toytec website it says you need a 1.5" AAL with the TSB instead fo the 2.5" AAL without the TSB. So I will still need an AAL after the TSB, right?
  4. Mar 25, 2010 at 7:29 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Get the TSB, go home and measure from the center of the hub straight up to the bottom of the fender at all 4 wheels, determine how much higher the rear is than the front. Then you'll know where to go from there.
    Or TSB + spacer, then see how much lower the rear is, if it is.
  5. Mar 25, 2010 at 7:36 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    Get the TSBs and 5100s...it is about the same cost as spacers but will ride so much better on the road. search the site...you will see a lot of happy 5100 people.
  6. Mar 25, 2010 at 7:37 PM
    TRICOMA
    Tri
    Carlsbad, CA
    TSB brings it up about an inch or so when it settles...if you want 3 inches you will need an AAL
  7. Mar 25, 2010 at 8:21 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    if you want to save the coin man just get you a spacer lift up front. 3" toytec spacer up front and the tsb + a 1" toytec block in the rear. that'll give you the lift to run the bigger tires and be a heck of alot cheaper than the ulk.
  8. Mar 26, 2010 at 4:42 AM
    jmed99
    SC
    Will the ride be a lot stiffer with this setup?
  9. Mar 26, 2010 at 8:09 AM
    TRICOMA
    Tri
    Carlsbad, CA
    Yes...get 5100 for just a bit more and you will have a much better ride than stock and you will get the lift you want. Also get a AAL for the rear not blocks.
  10. Mar 26, 2010 at 9:47 AM
    jmed99
    SC
    I just drove my buddies 05 with revtec 3" spacer and blocks and It drove pretty good to me. With that in mind, I'm leaning toward the toytec 3" spacer & AAL.
    If It feels super stiff can't I add the 5100s later?
    He didn't buy UCAs and he says he aligns perfectly....will I need UCAs if I go with the 3" toytec spacer and an AAL?
  11. Mar 26, 2010 at 11:10 AM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    Your friend is right! It is cheaper to get a spacer lift but the ride will be significantly rougher
