my lift is creaking and squeaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tio Pepe, Sep 18, 2009.
  1. Sep 21, 2009 at 7:43 AM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    what is the lithium grease for that everyone is talking about in these threads?
    is dry teflon lube something i can get at an autoparts store like advanced or pepboys?
  2. Sep 21, 2009 at 10:28 AM
    brandob9
    brandob9 Well-Known Member
    Brandon
    Portland, OR
    09 DC Long Bed
    Soundproofed cab, beeps purged, bed lights, extra bed tie-downs and TSB springs.
    Are they poly bushings? If so, it's part of the deal. You get a firmer bushing, good for off-road and racing applications, but they will make noise. If you are looking for a good street set-up, good old rubber is a much better bushing choice.
  3. Sep 21, 2009 at 10:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    When propperly greased, the poly bushings should be silent.
  4. Sep 21, 2009 at 10:51 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Im gonna go out and mention one other thing that I think it could be from what's already been mwntioned- Sway bar bushings. I'd try hitting them with a bit of silicone and see if the sound goes away. if it does, then i'd unbolt them and coat them with a little bit heavier grease as a long term solution.
    I have an OME lift and have been very happy with it. Basically no squeaks, rattles, anything. Once in a while i'll get a little creak offroad from something under the passenger side of the truck, but its seldom and not very audible unless you're outside the truck.
  5. Sep 21, 2009 at 10:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not a bad thing to check. :)
  6. Sep 22, 2009 at 7:23 AM
    Tio Pepe
    Tio Pepe [OP] Well-Known Member
    eastexas
    2009 4x4-Dbl Cab, Long Bed, SR5, SUPERCHARGED
    TRD installed Supercharger, Air Intake, & Exhaust. 3" lift with OME 885's & OME AAL. JBA shorty headers
    thanks for the input. So I will have my guy look at sway bars and everything else under there to regrease. Do yall think he cut corners with lubing up parts on the install, or do these things just happen? If I had spent the extra cheddar on Total Chaos would I not be dealing with it?
  7. Oct 1, 2009 at 11:14 AM
    Tio Pepe
    eastexas
    Turns out that the issue was in fact with the sway bars. Apparently the larger springs didnt give the sway bars enough room to flex. The OME kit from toytec has a part for that, though it didnt come with it. They said it would be a couple of weeks waiting on it, so the guy at my shop just fabricated a similar part to give the sway bars more room. So now I have a sweet lift with no squeaking! Thanks for the tips, guys.
  8. Oct 1, 2009 at 11:53 AM
    livintall
    livintall Well-Known Member
    Joe
    Phoenix, Az
    06 PreRunner SR5 TRD OR
    Energy suspensions has a very thick, very tacky, waterproof lube for poly bushings that is excellent for long term squeak reduction. Ive used it in past projects and it has never let me down. Lithium grease and others will eventually dissipate and the squeak will return.
  9. Oct 1, 2009 at 11:56 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I know my rear leafs squeak, it could be those.
  10. Oct 1, 2009 at 1:21 PM
    RelentlessFab
    Eric
    Sparks, NV
    :thumbsup:
  11. Oct 1, 2009 at 1:27 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Good to know! Thanks.
