My lift says 4.5 backspacing what's the offset do ??
Discussion in 'Wheels & Tires' started by K1992f, Feb 20, 2011.
  1. Feb 20, 2011 at 12:57 PM
    K1992f
    K1992f [OP] Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    My lift says to have a backspacing 4.5" .. The wheels I'm looking at are 4.5" backspacing but it says -24 mm offset dose that mean anything or should I Just worry about the 4.5" backspacing will this wheel work ok
  2. Feb 20, 2011 at 2:53 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Don't worry about offset, just backspacing. With 4.5" BS, -24mm is a 10" wide rim. Why are you wanting to run such a wide rim? What size tires are you planning on?
    Spoonman likes this.
  3. Feb 20, 2011 at 2:55 PM
    Archangel
    Archangel Special Assistant to the Regional Manager
    Charlotte, NC
    '04 T4R SR5 4x4
    you must be lifted pretty decent (6" or more) for that wide a wheel. Pics?
  4. Feb 20, 2011 at 2:56 PM
    K1992f
    Kanon
    Rcd lift I'm going for looks .. Yes a 20-10"
  5. Feb 20, 2011 at 2:59 PM
    TexasTacoma37
    What size tires?
  6. Feb 20, 2011 at 3:04 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Here's some comparo's for you regardless of wheel diameter:
    10" wide, 4.5" BS= -24mm offset
    --------, 5" BS= -12mm offset
    9" wide, 4.5" BS= -12mm offset
    --------, 5" BS= 0mm offset
    --------, 4" BS= -24mm offset
    8" wide, 4.5" BS= 0mm offset
    --------, 5" BS= +12mm offset
    --------, 4" BS= -12mm offset
    FishingInSand likes this.
  7. Feb 20, 2011 at 3:09 PM
    K1992f
    Kanon
    Was going with 33/12.5/20. But not thinking 295/55/20. ??
