My Lift Shopping list
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JavaJoe1, Jan 10, 2012.
  1. Jan 10, 2012 at 2:37 PM
    JavaJoe1
    JavaJoe1 [OP] Well-Known Member
    Joe
    Florida
    2012 Access cab Pre-Runner SR5
    Secondary air filter removal, AFE Pro Dry, 5100's all around front set at 2.5, 2" AAL in rear, ImMrYo Mirror Bracket, 265/70-17 Grabber AT2's, XD Addicts, wanting to do: BHLM, Satoshi/T-rex grill
    Ok so I have done a lot of research on here, much thanks to all the posters for great info. I have decided to go the 5100 rout for my 2012 Access cab prerunner SR5.
    I have made my purchase and am awaiting delivery. My question now is did I miss anything? I will be installing the following components my self this weekend. Any input, suggestions, or tips would be greatly appreciated.
    Rear ToyTec Add-A-Leafs
    Zinc Axle Shims (3 Degree) 05 & UP Tacoma
    Bilstein Height adjustable 5100 front and rear 5100 shocks(set at 2.5)
    Front Top Plate Spacer (One - 1/4")
  2. Jan 10, 2012 at 2:38 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    looks like you're good. you may want to look into extended brake lines if yours gets too taught though
  3. Jan 10, 2012 at 2:57 PM
    JavaJoe1
    Joe
    Florida
    Hey thanks for the quick replies guys. Good idea on the DSMS call. My leaf pack is the 3 leaf non-TSB pack so I got the Toytec non-TSB AAL.
    Really hoping I don't need the UCA's as my budget is kind gone after this and my new XD addicts and 265/70-17 Grabbers :D
  4. Jan 10, 2012 at 6:32 PM
    JavaJoe1
    Joe
    Florida
    And now to jack my own thread....
    Just looked at the aforementioned Addicts I ordered, and I may have ordered the 5.71 backspaced -12mm offset 17x9's. I am going to run grabber at2's 265/70-17.
    Question is the backspace and offset I think I wanted is 4.5 and -12mm. What will the rims I ordered look like in comaprison?
    Sorry for all the questions relative noob here.
  5. Jan 10, 2012 at 10:41 PM
    TACWUT
    TACWUT Well-Known Member
    San Diego
    12 prerunner DC
    Flowmaster turndown, 5100 up front/5150 rear, maxtrac spindles, 2" tuff country add a leaf+TSB.
    I have a 5.0 BS you can see them on my profile oh and with ur tire on a 17x9. They look good but the shop needed to add a spacer and some new lugs that were longer.
  6. Jan 11, 2012 at 5:23 AM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Don't put the shims in till you know you need em. I think a lot of vibration issues are caused from people thinking they need to shim or add carrier bearing drops with spring install. Check drive line angles then decide to shim.
  7. Jan 12, 2012 at 6:15 AM
    JavaJoe1
    Joe
    Florida
    Thanks for the shim tip.
    As to the wheels, I called 4 wheel drive hardware's customer service and they told me they actually have a brick and mortar store in my town went over and met some cool people who just swapped them out.
    Cant wait for the rest of this stuff to get here! Will definitely get a build thread together as it comes together this thing is going to look sweet!
  8. Jan 12, 2012 at 6:23 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You sure you need the 1/4" spacer if you're running stock coils? If you put the stock coils back on the correct side I'm not sure you need the spacer. Hopefully someone who knows for sure will chime in on this before your install.
    Also, I agree with others, I don't think you'll need the axle shims. The people I know that are running them put on 2.5 - 3" of lift in the rear using Dakars or All-Pro Expos.
  9. Jan 12, 2012 at 6:36 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    all pro u-bolt flit kit would make a nice addition to the add a leaf, you can probably sneak in the aal on your stock one but for 50 bucks it's a nice clearance upgrade. your call
