My LS swapped 3rd Gen Tacoma build thread
Discussion in '3rd Gen. Builds (2016-2023)' started by Drewthecarguy, Mar 19, 2023.
  1. Apr 8, 2023 at 8:53 AM
    #41
    Drewthecarguy
    Drewthecarguy [OP] Well-Known Member
    Drew
    2016 TRD OR
    3.6TT Engine swapped, Icon Stage 4, SCS wheels
    Are you doing a 3rd gen?
  2. Apr 8, 2023 at 8:54 AM
    #42
    Pittsy
    Pittsy Ex car guy, currently in rehab
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    send gen. The mounts looked the same. I really didnt pay too much attention/remember if there were any difference between it and the 3rd gen motor mounts.
  3. Apr 8, 2023 at 9:18 AM
    #43
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    I was a production fabricator for 3 years before going fire, if you ever need something quick and he’s not available. Offer still stands for brewskies and an extra hand :cheers: I wouldn’t mind some first hand sights of an ls sitting in a taco either as I eventually will go this route :rofl:
  4. Apr 8, 2023 at 12:16 PM
    #44
    Pittsy
    AZ
    Nothing ab out the LS Swap process on buy truck has been quick. Such a pain :rofl:
    If you're down to finish mounting my motor and trans in,PM me haha I don't wanna clutter up his thread.
    MulletTaco[QUOTED] likes this.
  5. Apr 8, 2023 at 1:57 PM
    #45
    MulletTaco
    Kevin
    Somewhere in AZ
    Copy that lmao
  6. Apr 11, 2023 at 11:11 AM
    #46
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    6L80e from the 2014 period and further forward are less plagued with issues and easier to bulletproof
    But still not without ANY issues… they overheat unless you configure them to live around 180
    But from the factory they live around 200
    So
    You can see the rub issue there in the way of reliability but… that’s a 10$ problem if you’re aware of it early on
  7. Apr 11, 2023 at 4:29 PM
    #47
    Pittsy
    AZ
    How did you do the throttle pedal, by wire or cable? In either case, how did you do the pedal mounting?
    Caboose117 likes this.
  8. Apr 11, 2023 at 4:34 PM
    #48
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Just enough info to wanna know more!
    I think we need a full on install video :rofl:
    Steves104x4 likes this.
  9. Apr 11, 2023 at 4:36 PM
    #49
    Pittsy
    AZ
    Throttle is the one thing I don’t have figured out yet
  10. Apr 13, 2023 at 6:31 PM
    #50
    Drewthecarguy
    Drew
    2016 TRD OR
    It’s a CTS-V pedal mounted in the stock location with a little bracket I made
  11. Apr 14, 2023 at 8:09 AM
    #51
    Pittsy
    AZ
    Roger that.
  12. Apr 14, 2023 at 11:39 AM
    #52
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Drew I’d love to see a more in depth of how you had to modify stuff specifically for your LS including all the brackets you made
    or the wiring harness modifications/replacements
    also… does your radio work? In your video
    It’s off off so I was curious
    Also, would it have solved some of your clearance issues had you set up the LS as a dry sump?
  13. Apr 16, 2023 at 10:42 AM
    #53
    Drewthecarguy
    Drew
    2016 TRD OR
    mounts and oil pan is really the only things custom made and they are a very simple design, radio does work no problems there
    dry sump could possibly solve some clearance issues but the cost of a set up doesn’t outweigh the benefit I don’t believe
    Caboose117[QUOTED] likes this.
  14. Apr 16, 2023 at 12:46 PM
    #54
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    What about your trans crossmember?
    Is it gonna be a big hurtle to get the 4WD back working?
  15. Apr 16, 2023 at 1:17 PM
    #55
    Drewthecarguy
    Drew
    2016 TRD OR
    Trans mount is basically a 3x3 aluminum square tubing spacer on the stock trans crossmember and the 4x4 will be super easy
  16. Apr 16, 2023 at 1:21 PM
    #56
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    When you get a chance I’d love to see pictures of the spacer and how you handle the 4WD
    I’m doing a LT motor but I’m sure it will be identical
  17. Apr 24, 2023 at 9:48 AM
    #57
    JManning1423
    JManning1423 Well-Known Member
    Jacob
    Huntsville, AL
    2017 M/T Sand Tacoma TRD OR
    Too many to count
    Do you think it's feasible to keep a manual transmission and 4x4 with this swap? The one thing I refuse to ever give up is my third pedal.
    doublethebass likes this.
  18. Apr 24, 2023 at 9:51 AM
    #58
    Capitulate
    Capitulate Well-Known Member
    Too cool, very nice work
  19. Apr 24, 2023 at 11:23 AM
    #59
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    @tacotunner06 has a manual 4x4 with his ls. I believe its a tr6060 trans
    JManning1423[QUOTED] likes this.
  20. Apr 24, 2023 at 12:14 PM
    #60
    Drewthecarguy
    Drew
    2016 TRD OR
    I believe it’s possible I remember seeing someone who made a adapter plate for a LS into like a first gen or something maybe the bellhousing bolts are the same that would make it pretty easy
    JManning1423[QUOTED] and HondaGM like this.
