My Mechanic has given up.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bennydojo, Jan 14, 2011.
  1. Jan 14, 2011 at 2:59 PM
    Bennydojo
    Bennydojo [OP] Member
    Ben
    Virginia
    '95 Tacoma SX 2.7L 4X4
    Here I am with my 1995 Toyota Tacoma SX Regular Cab 4x4 -2.7L 4Cyc- 162K Miles
    The power steering is the issue, it grinds makes a bunch of noise and barely works.
    I've spent a little over $1000 trying to get it fixed to no avail. and I am about at wit's end.
    -Pump has been replaced twice
    -Power Steering Hoses have Been replaced
    -Rack and Pinion has been replaced
    Problem still happens.
    I guess my questions is 2 parts.
    What else could it be?!
    Is there a way to just bypass the Power Steering system all together and just have Manual steering? If so is it safe?
    Anyone's thoughts on this matter would be greatly appreciated.
    -Ben
  2. Jan 14, 2011 at 3:01 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    What kind of fluid do you have in the PS system?
  3. Jan 14, 2011 at 3:04 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    ever check the rag joint in the steering shaft?
  4. Jan 14, 2011 at 4:37 PM
    rushr
    rushr Well-Known Member
    04 DC TRD 4X4
    OME 883 Coils, Dakar Leaf Packs/D6XL AAL, Nitrocharger Sport Shocks, ARB Bumper, Warn M8000 w/Synthetic Line, BAMF Sliders, Odyssey Battery, ProComp 7069 15x8, BFG KM2 33x10.5x15, Frame End Cap Mod, Hayden Transmission Cooler
    Plugged screen in the bottom of the fluid reservoir.
  5. Jan 14, 2011 at 4:51 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Boom
    Try that, this has been a resolution before
  6. Jan 14, 2011 at 6:13 PM
    Bennydojo
    Ben
    Virginia
    Cool I will check these things.
    Thanks Much!!
  7. Jan 14, 2011 at 6:14 PM
    trd7
    trd7 4wd tacoma
    Tyler
    Columbia, SC
    95.5 Tacoma 4x4 4cyl auto
    AEM air intake
    is your truck lifted? big tires could be stressing the system
  8. Jan 14, 2011 at 6:15 PM
    SmoothFox
    SmoothFox Well-Known Member
    DFW TEXAS
    2010 TRD OFFROAD 4x4
    CBI Sliders,PIAA Lights, 5100's, 4 leaf pack.
  9. Jan 14, 2011 at 6:16 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    I got stock steering and my 37's dont stress it :)
  10. Jan 14, 2011 at 8:41 PM
    Bennydojo
    Ben
    Virginia
    Nope, Standard Wheels/Tire size.
  11. Jan 14, 2011 at 9:03 PM
    DonnoD
    DonnoD Well-Known Member
    don
    las vegas
    07 dc 4x4 v6
    it might not be on the PS system. it could be seized ball joints, try disconnecting the tie rods from the knuckle and see if the wheels turn freely or it also just might need a good flushing on the PS system.
  12. Jan 15, 2011 at 6:50 AM
    Whitfield
    Whitfield Well-Known Member
    Central Virginia
    99 TRD X-cab on 35's / 96 X-cab on 33's
    Selling my 96 Tacoma to fund the FJ80 build up.
    Hellow to a fellow VA Taco owner...
    Is this the truck that was at Redbeards Psycho Racing garage in Hopewell back before christmas?
    If so it is the PS resevoir screen...
    I was their and helping yall inspect it last time thru. I found the fix a few weeks later and emailed Lonnie but he disagrees. I am sure that this truck was the screen. So sure I would perform the screen fix for free if that is the same truck.
    If not the same truck then their is another guy in Va who has installed 2 pumps + 1 racks over that darned screen. Somthing is breaking down and contaminating the Power steering system on these trucks. We flushed many saw dust looking chunks of sludge out of that system. At first I thougth it was internal hose or o-ring break down but squishing the chunks on white paper showed them to be a greasy petroleium based sludge build up. I am sure this build up is now plugging the screen too. Even though you clean the screen with the pump off it still doesn't flow enough fluid since it is only gravity fed.
    If you are local to Hopewell / Col Hgts and need some help PM me or ask Redbeard for Whitfields Cell # .
  13. Jan 15, 2011 at 7:10 AM
    giscott
    giscott Well-Known Member
    Scott
    Austin
    2003 TRD SR5 PreRunner DC Revtek 3" Lift,
    Now that's what this place is all about. Whitfield, you're a stand up guy.
  14. Jan 15, 2011 at 7:16 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    So what's the status? Did you put the screen in OP?
  15. Jan 15, 2011 at 8:07 AM
    Whitfield
    Central Virginia
    Thanks giscott !!!
    Background ~
    Back in the fall I was asked to stop by a friends and look at a local Taco with steering isues as described above. Removing and inspecting the NEW replacement rack that was only a few months old we found the saw dust size sludge chunks like I mentioned above. I made mention of a similar situation 10yrs earlier on another make where the PS high psi hose was contaminating the system breaking down internally and the hoses were the only part of THIS system that had not been replaced. At the time I had no recomnedation other then to activly super flush the system and replace the hoses ~ but this was before I knew about the screen.
    Knowing what I know now ~ the sludge contamination has remained in the system with each part that was not replaced recontaminating the new parts. As the pump / rack / hoses on this truck were all done at seperate times. Each old part recontaminated the new pump screen in short order. The pump return screen should be removed and thrown away along with an active flush of new fluid performed until the fluid coming out of the return line is clean and free of sludge.
    If you still want to run a PS fluid fliter the run a cleanable element filter on the return line prior to the resevoir.
  16. Jan 17, 2011 at 6:55 AM
    Bennydojo
    Ben
    Virginia
    Wow, I'm really impressed at the outpouring of Help I got here.. I wish I had found this place earlier! As I could have saved many hours of my time and a lot of money...
    UPDATE : I was able to use a flathead screw driver in the PS reservoir and clean out a bunch of build-up on that screen.. This seemed to almost instantly improve the power steering going in and out and reduce the "whine".. I'm still getting the whining sound intermittently but I imagine a good power steering fluid flush would help that..
    THANKS!!!!!!!!!
  17. Jan 17, 2011 at 7:07 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I had a 95 4X4 2.7L and the power steering reservoir lost 3/4 of it's fluid. I could not find any leaks anywhere and the unit began to whine. I filled up the reservoir with Prestone power steering fluid which had stop leak already mixed in it. I never had a problem again with it. Hope cleaning the screen fixed your problem.
  18. Feb 19, 2011 at 12:31 PM
    Iceman63
    Iceman63 Member
    Garth
    Richmond, VA
    97' Tacoma 4X4
    Guys, I'm having the exact same problem with my 97'. Loud whining/humming type sound...power steering working, but a little harder than usual. How is the screen accessed for cleaning?
  19. Feb 21, 2011 at 6:55 AM
    Bennydojo
    Ben
    Virginia
    Open the Power steering reservoir and its about i'd say 5-6 inches down from the top. I used a flat head and kind of felt around with it, you can't miss it. - Caution : I'd be very gentle, from what I've read, it doesn't take much to tear up the screen.
