My mechanic said he heard a tick (video)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrGooch, Oct 27, 2023.
  1. Oct 27, 2023 at 8:34 AM
    MrGooch
    MrGooch [OP] Well-Known Member
    2021 Black TRD Pro
    It's my 21 pro with 31k miles. Had my guys do oil, trans, diff fluid drain and fill and when I picked it up one of the guys was like hey have Toyota listen to this tick, it seems abnormal.
    Asking you guys, as far as I'm aware it's always done this... I think? It's only on pass side and you can hear it through the wheel gap and after about a 10min warmup is when it starts to get this loud
    https://youtube.com/shorts/imjUu7vK82E?feature=share
  2. Oct 27, 2023 at 8:42 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Could be a high pressure pump
  3. Oct 27, 2023 at 8:46 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Absolutely normal all my tacomas have made that noise some worse then others.
    usmc2msu likes this.
  4. Oct 27, 2023 at 8:48 AM
    MrGooch
    2021 Black TRD Pro
    Yea my 19 kinda did the same just don't remember it being that loud. I'll have Toyota look at it before my warranty ends just cover my ass
  5. Oct 27, 2023 at 12:15 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Mine sounds the same, I think that’s completely normal.
    Chew likes this.
  6. Oct 27, 2023 at 12:19 PM
    McHale
    McHale Well-Known Member
    2023 Toyota Tacoma TRD OR MGM Access Cab
    My brand new Taco with 600 miles sounds just like that.
  7. Oct 27, 2023 at 12:20 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
  8. Oct 27, 2023 at 4:23 PM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    They aren't the quietest engines ever. Direct injection and a high pressure fuel pump, injector cleaning cycles....they make ticky sounds all the time. Mine is quieter than that (but not what I'd call quiet by any means), could just be variations from one vehicle to another, though, plus listening to it with earbuds on YouTube adds a variable. Most engines with direct injection that I've been around are noisy suckers, not just this engine, so I guess it is what it is :notsure:. Maybe get under the hood with one of those automotive stethoscopes and see where the noise is coming from.
    soundman98 likes this.
  9. Oct 27, 2023 at 4:39 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    That sounds like it's at a valve train frequency similar to when a single lifter is acting up, if it stays the same frequency when revving it a little then it could be a pump or some other system but if it increases with RPM then its a moving component driven off the crankshaft, to me it sounds just like what a bad lifter sounds like. I've heard exh leaks that didn't sound like a leak but it doesn't sound like that. Not trying to scare you but if that's normal count me surprised, the 22 TRD I test drove wasn't noticeably louder then my 140K 4.0. Dealer will prob tell you it's normal but I'd give them the opportunity to listen to it.
  10. Oct 27, 2023 at 4:52 PM
    MrGooch
    2021 Black TRD Pro
    Thanks. Like others said it's kinda normal but I'm still under warranty so I'm booking an appointment so they can at least note it in the case something is actually f'd down the road. The truck runs great I'm not really concerned at all. Engine warranty good up to 60k right?
    ridefreak[QUOTED] likes this.
  11. Oct 27, 2023 at 5:01 PM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    I think it's a good idea. Does the tick increase in frequency with RPM?
  12. Oct 27, 2023 at 5:07 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    the noise I’m hearing in the video, which is not what I would call a tick. I would call that a very faint knock, my truck is never made that noise
    ridefreak likes this.
  13. Oct 27, 2023 at 5:16 PM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    I agree, I used the word tick but it sounds more like a slight knock sound.
  14. Oct 27, 2023 at 7:34 PM
    MrGooch
    2021 Black TRD Pro
    I throw a tank of 93 in every so often but mostly use 87. Fwiw?
  15. Oct 28, 2023 at 2:27 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I don’t believe it’s a fuel related noise. Those simply do not happen at idle. These engines are rather noisy with the idle cycle. That noise is just DIFFERENT. I would have it looked at. to me it does not sound like a lifter or typical valve train noise.
  16. Oct 28, 2023 at 3:11 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Get a long screwdriver and try to pinpoint the location of the noise. KEEP THE SCREWDRIVER AWAY FROM MOVING PARTS!
    https://www.youtube.com/watch?v=QvG9K95vFDY
    shakerhood likes this.
  17. Oct 28, 2023 at 7:16 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Make sure you put the handle end in your ear :anonymous:
    super_white[QUOTED] likes this.
  18. Oct 28, 2023 at 7:27 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    the high press fuel pump is at the back of the engine, passenger side. it is cam/follower driven so it will vary with rpm.
    BeastBoy likes this.
  19. Oct 28, 2023 at 7:29 AM
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    I know mine doesn't sound anything like that. You wanna hear a loud motor you should listen to my 701 enduro. That bike sounds like the motor is going to grenade into a million pieces everytime I ride it. But thats ktm/husky for you and its totally normal lol.
    faawrenchbndr likes this.
  20. Oct 28, 2023 at 8:06 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    :rofl:
