My MPG is NOT Bery GOOD. WHY?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GeoTaco1, Jan 30, 2011.
  1. Jan 30, 2011 at 10:04 AM
    GeoTaco1
    GeoTaco1 [OP] Well-Known Member
    Geo
    11 Tacoma TRD Off Road
    NEW Toyo TIRES Bed Cage to hold 120 LBS of sand and fishing rod holder, window air deflectors, Bug Deflector, & finally Avid Light Bar and step rails....
    2011 Off Road V6 Automatic No Real Mods.
    I just replaced the BFG with Toyos same size.
    I am now up to 650 miles and I drive mostly highway and some local driving on the snow. My latest Reading was:
    15.5 MPG :eek:
    I thought I should be getting 19 or higher?? Do you think the 240 lbs of sand in the back is the reason?
    (But I added a hood & window deflectors, which should have compensated to raise my MPG! Right! :D)
    BTW: I use Regular Gas 87 Oct.
    What are others getting on the same truck?
  2. Jan 30, 2011 at 10:05 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    It's a truck it sucks but your not alone
  3. Jan 30, 2011 at 10:14 AM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    Probably a combo of winter gas, extra weight, new truck, and snow driving. I would wait till the summmer before I really worried about 15mpgs
  4. Jan 30, 2011 at 10:17 AM
    JKD
    JKD Well-Known Member
    Winter weather driving, winter blend gas.
    How fast do you go on the highway? How long do you idle to warm up? How much time do you spend driving on slick roads at city speeds?
  5. Jan 30, 2011 at 10:20 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    Mine got drastically better with every fill up untill I hit about 1,200 miles. Now I'm holding pretty strong at 16.7-17.9
  6. Jan 30, 2011 at 10:22 AM
    GeoTaco1
    Geo
    Of course officially I only do speed limit, give and take 20, I only let it warm up for 20 seconds. I was thinking of trying 89 Octaine, but I do not want the truck to get "used to it". It should run fine at 87.
    I have tried different tire pressures for driving comfort, but never below 29 PSI. I am not running 30 front and 29 back. I may take out 120 lbs off the sand weight once the ice storms go away.
    Maybe when I hit it hard to see if it downshifts on the highway (especially when next to an F150) maybe it guzzles it up???
  7. Jan 30, 2011 at 10:25 AM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    The 2,000 RPM and under range is your friend if you want good MPG.
  8. Jan 30, 2011 at 11:10 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    03 regular cab 4x4
    I get a bit over 19 with mine (4x4 v6/auto stock double cab TRD with rugged trails) on 87 octane in my normal driving which is about 70 percent highway at 65-70. But I honestly don't get on the gas hard very often. One thing to check is the weight of the new tires. When I went from wimpy highway tread 265/70/16 michelins to slightly heavier and certainly more aggressive general grabber at2's in the same size on my last 05 4 cylinder it dropped 1-1.5 MPG. I'll probably run the same tires on this truck once the rugged trails need to be replaced.
  9. Jan 30, 2011 at 11:15 AM
    BartStar
    BartStar Well-Known Member
    pa
    2011 Tacoma 4X4 Double Cab, 6 speed man
    15.5 mpg? thats good! same here, new truck (same truck) I am now around up to 500 miles and my last fill up I only got 13.95 mpg
  10. Jan 30, 2011 at 11:18 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's the winter..... winter gas, and god knows what else. Normal!!
    I have an 07 and I consistantly get 18-19mpg in the summer and usually around 16-17mpg in the winter. And since I've been running 150lbs in the bed this past couple winters...15-16mpg.
  11. Jan 30, 2011 at 11:25 AM
    Crazyfrog
    Crazyfrog Well-Known Member
    Keith
    Monroe Ohio
    2010 TRD 4X4 DC
    OME 885's, Bilstien 5100, 2"AAL, Weathertechs, AVS visors, Access bed cover
    I had one tank that was 16, but most fall between high 17's and low 20's. Truck now has 7000 miles, and driving is a mix of highway and in town, along with some country roads. I drive it for work, and drive ALOT! The truck is only 2 1/2 months old. Best i can say is just drive it easy when accelorating, and try to run under the 2000 rpms as suggested. It should get better.
  12. Jan 30, 2011 at 11:29 AM
    ShaLor
    ShaLor Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
    Well here's your problem! :D
    I tried to explain to my wife what doing even an extra 10 miles over the speed limit does to your fuel economy and she didn't believe me until we got a MINI Cooper with the fuel economy computer built in. When we traveled across country and we got to Texas where the speed limit is 10 mph faster than California, we got 100 miles LESS from a tank of gas. That clued her in that speeding really really kills fuel economy.
  13. Jan 30, 2011 at 12:48 PM
    Salesman
    Salesman Member
    Texas
    09 Prerunner SR5
    just purchased not modifications
    The 2 wheel drive Prerunner V6 must do a lot better on the road and in town compared to 4 wheel drive.
    I drive daily 65-70 and I am averaging highway and city combines 21.5.
    This made a big difference on money spent from the GMC I had before this.
  14. Jan 30, 2011 at 1:13 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    Sure you drive the speed limit, but how fast do u drive to get to the speed limit. I am sure if you keep the rpms under 2k u will get the mpg u want.
    nothing is wrong with your truck, the mpg will get better in a few thousand miles. Be easy on her till she is well broken in.
  15. Jan 30, 2011 at 1:34 PM
    PPower05
    PPower05 Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    Haven't had the problem in my 10 off road TRD.... Been getting consitant 17-18 mpg.... Keep the RPM's below 2, you will find that many times you are actually going below the speed limit (my commute is 65 miles one way through some moutains)
  16. Jan 30, 2011 at 2:17 PM
    705 Taco
    705 Taco Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    I'm paying about $1.15 a litre for fuel here. Thats about $4.40 a US gallon and the reason I bought a 2.7 litre engine. I went 320 miles on the first tank of winter gas. The weather was cold and I used four wheel drive a lot. This truck will get good mileage. Just not until I break the engine in and the weather warms up. Your's will get better too. Give it a bit of time.
  17. Jan 30, 2011 at 2:20 PM
    Ralph Pootawn
    Ralph Pootawn Well-Known Member
    Fairfax, Va
    '11 Timberland Mica TRD Off-Road
    N/A
    Sorry, but why'd you change the tires out so soon?
  18. Jan 30, 2011 at 3:27 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    14.5mpg here:rolleyes:
  19. Jan 30, 2011 at 4:55 PM
    Will
    Will Well-Known Member
    Will
    Lansdale, PA
    08 PreRunner TRD Sport
    Pioneer Premier P600UB Access Lorado WeatherTech FloorLiner
    I got 14.4 my last tank. I was shocked. Never had that bad. I mean it was below 3/4 of a tank at 80 miles. Usually it's between 105-120. I drove about 140 miles this weekend on a new tank of gas and it's back to "normal". Actually about 125 until it went below 3/4 of a tank.
    Still can't figure it out. Never had below 16.2 before then. I'm usually in the mid-high 16's for winter, and a little higher when it's warmer. I'm hoping that was just a one time thing.
  20. Jan 30, 2011 at 5:48 PM
    sweater914
    sweater914 Well-Known Member
    North Dakota
    '09 I4 5spd Access Cab Timberland Mica SR5
    Winter doesn't help fuel mileage for several reasons:
    1. Cold air overall is more dense than warm air. This seems insignificant until you're driving at interstate speeds, our aerodymanic bricks we're pushing down the road have to overcome the additional resistance.
    2. If it's cold you're probably using the defroster, you're thinking no big deal but you're losing at least .5 mpg because the defroster uses the air conditioning compressor to dry out the air.
    3. I takes longer for the truck to reach operating temperature, until the cats and the coolant temps warm up the engine is running either on a high idle or rich.
    4. Winter blend fuels, the formulations change with the seasons supposedly to help with emissions, which is a wash if you're burning more FUEL.
    5. Any changes away from stock will probably effect your mileage away from the EPA numbers. As much as we all like taller trucks, A/T tires, larger wheels, heavy metal bumpers, any and all engine mods, all will negatively effect your mileage due to increased weight, rolling resistance, and pushing more air/fuel through the engine.
    All is well and good if you willing to accept the we're driving a truck and not a Honda Civic which isn't immune to winter mileage variations.
