My Need For Speed
Discussion in 'Off-Topic Discussion' started by ToyotaTacoma4Ever, Jun 26, 2013.
  1. Aug 29, 2014 at 6:23 PM
    #61
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever [OP] Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    Well another day with the skyline
    Let The Engine Strip Down Commence
    So start taking the main crankshaft pulley with the the timing belt and cam gears. Then the intake manifold with the cam covers after with the cams. By the time you know it the head is off and it's looking like this
    Now was time to take the oil pan off. You can see in the picture below that the front diff is connected to the oil pan. The whole reason why the engine came out for a blown diff.
    Engine oil pan off and sitting on the ground, then the pic on the engine
    Main lower bearing brace removed with all the baffling
    And finally got all the pistons out sitting pretty on the bench
    So another day done with everything almost everything dis-assembled. All that's gotta be done is cleaning and take a closer look at my front diff
  2. Aug 29, 2014 at 7:10 PM
    #62
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Awe yeah. This just got good.:D
  3. Aug 29, 2014 at 7:27 PM
    #63
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    OH
    MY
    GAWD
    :jerkoff:
  4. Aug 29, 2014 at 9:00 PM
    #64
    ToyotaTacoma4Ever
    Eric
    Alberta
    Literally took a year to get here finally!
    Thanks man, I sure hope everything goes well too. Nice car to show lol
  5. Aug 29, 2014 at 9:20 PM
    #65
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    subd :D
    Nice r33!
  6. Aug 31, 2014 at 3:38 PM
    #66
    ToyotaTacoma4Ever
    Eric
    Alberta
    Well got around to removing the crank shaft from the block including the oil pump
    Inspected all the bearing journals and the cylinder bores. All looks well without the need of re-boring the cylinders so im pretty happy about that
    So now it was time to inspect my front diff so here we go. Took off the front cover and the side cover to where it seal on the side. Split the flange and removed the whole extended shaft
    Once that was out it was a little bit of manoeuvering to get the diff out
    Here's the whole reason why the engine came out (don't mean to keep repeating myself but ive got proof of what happened now) Pictures will do the talking
    Now no one in my town will clean up the oil pan or the engine block so i'll be driving down to the bigger city down south for the shop im bringing my engine parts can do the following jobs for me
    -Balance the crankshaft
    -Clean and flux coat (check for cracks) the oil pan
    -Clean and flux coat (check for cracks) the engine block
    -Deck and re-hone engine block
    So pretty much saran-wrapped the oil pan, engine block and lower bearing brace and in the Tacoma it goes for a road trip down south for next weekend
    There you go for all you readers. Everything dismantled and now we can start the re-building phase of things for then engine and a new front diff
  7. Aug 31, 2014 at 5:56 PM
    #67
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Awesome, I'm doing basically the same thing with my corolla. The 3TC is about a million times simpler though :laugh:
    Sorry if I missed it but are you planning on replacing the pistons/rods for more boost?
  8. Aug 31, 2014 at 6:06 PM
    #68
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    ME GUSTA
  9. Aug 31, 2014 at 6:14 PM
    #69
    ToyotaTacoma4Ever
    Eric
    Alberta
    Oh yeah I bet it's much easier haha
    It's on my first page why I wanna build my motor but no worries, I haven't really explained to much on exactly why anyways
    The stock engine can handle 500 hp but your pushing it and you better have a great tune to run that but before you even hit 500 you have to replace the head gasket to a metal one
    I'd like to hit somewhere between 500 - 600 hp reliably so a full forged bottom end is an overkill but I'll have a bullet proof bottom end. I'd like to hit a minimum of 20 psi with the new turbos so we'll see where this goes
    Still don't have a plan for the engine head haha
  10. Sep 7, 2014 at 8:48 AM
    #70
    ToyotaTacoma4Ever
    Eric
    Alberta
    Time to take apart everything in the diff which included that smaller axle/shaft, bearings and seals. Got a hand from my old man on this one!
    Before i went down south to the shop a good friend of mine already has the tomei baffle installed which he told me the drain back hole in the oil pan have to be enlarged as part of the instructions. I did just that but needed one hell of a long bit to get the far side of the hole since the drill would hit the side before the bit would go through
    After the mod i left the next day to drop off my block and oil pan. Got news that the balancing required all of the rotating assembly which is pistons, rods, crankshaft, harmonic balancer and flywheel. Well shucks thats gonna have to wait for later until i get the pistons, rods and harmonic balancer!
    Back at home with the one day trip. That amde for a long day driving in the taco. So back at home and at the car again.
    Theres this charcoal canister in the engine bay which is used for emissions purposes which is getting deleted (EVERYONE gets rid of these)
    So with the canister out already when i pulled the engine it was just lines left over. It was easy as snip, cut pull out haha
    There is one issue though the canister see'e which is fuel vapors from the gas tank which is the line in the pic above. So snip and cut again half way down the frame of the car and bend it back into the frame.
    So thats all I've got for now until i hear back from the shop with my block and oil pan. Still figuring out what to do with my head. Still have yet to order any pistons, rods or bearings. So next update might be in a couple of weeks or so
  11. Sep 9, 2014 at 9:38 AM
    #71
    ToyotaTacoma4Ever
    Eric
    Alberta
    The shop I brought my block to are big into making big block V8's. They have seen the inline 6 blocks before and they're all old guys working in the shop so I'm sure they have plenty of experience. I'll see how they do with the machining on my block.
    Until I hear from them is when I can start ordering any kind of parts for the block
  12. Sep 9, 2014 at 12:47 PM
    #72
    Z E R 0
    Z E R 0 Well-Known Member
    California
    02 Tacoma 4x4
  13. Sep 9, 2014 at 3:36 PM
    #73
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Oops.
    Well that sounds awesome. Looking forward to the 4 wheel burnout videos!
  14. Sep 9, 2014 at 5:20 PM
    #74
    ToyotaTacoma4Ever
    Eric
    Alberta
    no worries man
    haha oh yeah! that will be a time! I've got a friend who owns the identical car as me with a built engine and he can spin in 1st on all fours! The shitty thing is that he ran into the same front diff issue as me with to many launches at the drag strip
  15. Sep 11, 2014 at 9:45 AM
    #75
    ToyotaTacoma4Ever
    Eric
    Alberta
    Nice story and I'm sure that's a lesson learned
    That's a good thing my friend that has the front diff issue tows his car down since home is around 450KM away. Me and my other friend we drove to the same track with both our skylines for the circuit racing and not the drag strip. I brought pretty much all my tools and some spare parts in case we did break down. Luckily nothing big happened other then a leaking fuel line :$
  16. Sep 27, 2014 at 7:56 AM
    #76
    ToyotaTacoma4Ever
    Eric
    Alberta
    Well even after a couple weeks things are slowed down. Manage to work some OT for the upcoming bills I've got coming haha
    So the block is still in the shop since they found my cylinders to be tapered and needed to be re-bored to next size. So 86.5mm pistons it is. They have ordered the CP pistons and Eagle Rods, soon to order ACL bearings. Shop is still waiting on mail to get my pistons in, but I did get to check out my beautiful con rods
    On this weekend I got off from work and not working the OT, I dropped off my flywheel, my ATI Harmonic Dampener and crankshaft off for everything can get balanced
    So now the shop pretty much has my entire bottom end and it's simply a waiting game now. So who knows when the next update on this build will be. Stay Tuned! :D
  17. Sep 29, 2014 at 1:12 PM
    #77
    ToyotaTacoma4Ever
    Eric
    Alberta
    Yes those rods are very strong! Rated up to 1200 HP lol
    Yeah the rebuild is gonna take a while so it is a winter project, sure hope everything falls into place with the car when spring comes around
  18. Dec 20, 2014 at 3:28 PM
    #78
    ToyotaTacoma4Ever
    Eric
    Alberta
    Well a nice 4 month wait and I finally got my block back, to bad I was in such a rush to get mounted and wrapped I nearly forgot to take a picture. I had a long day and drive so you guys will eventually see the block all done lol
    The Oil Pan looks sooo fresh!
    With that said got all my other parts (pistons, rods and bearings) just need to order a new set of ARP main bolts but there's still so much to do while I wait for them to come in the mail! Got the crankshaft back in there too!
  19. Dec 20, 2014 at 4:07 PM
    #79
    AR15xAR10
  20. Jan 6, 2015 at 9:08 PM
    #80
    ToyotaTacoma4Ever
    Eric
    Alberta
    Not a whole much of an update here, figured i would start tackling my front diff. Thanks to my old man for letting me bring my oil pan to his shop to make it easier to work on! i do say removing the outer races on the bearings inside was not very fun since they are in there pretty tightly
    So first started off by installing the new crown gear and bearings on the new LSD diff. Old one is on the left, new one is right in picture
    So give another 3-4 hours for putting the new outer races back in and putting new bearings on the pinion shaft and next thing you know we have everything together
    It sure looks pretty but until i went to check my backlash thats when we started having issues…
    Zero backlash in the teeth, bearings on the diff have wayy to much preload and the pinion shaft doest have enough pre-load. Great, so now ive gotta play with shims since the stock ones i kept from my old one never aligned the gears right nor put the right amount of pre-load on. So out came the front diff to start with getting the right pre-load on the pinion shaft then see how the gears mesh. This just became a long wait for shims..
