My new 2021 Tacoma has been in the shop for 5 days so far.****FIXED****
Discussion in '3rd Gen. Tacomas (2016-2023)' started by danadavenport, Sep 16, 2021.
  1. Sep 16, 2021 at 8:32 AM
    Zuess42
    Zuess42 Member
    Was your truck final assembly in Mexico or San Antonio ? Just curious, that may provide a directional hint to the underlying cause.
  2. Sep 16, 2021 at 8:33 AM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    How’s that?
  3. Sep 16, 2021 at 8:36 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Wasn't there an issue with radiator mounts and/or cab mounts causing this same noise?
    Beerpayzdabillz and tonered like this.
  4. Sep 16, 2021 at 8:40 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Im gonna put money on a loose cab mount, on the side the noise is coming from.
    Slow sharp turn isnt enough force to cycle the suspension, so instead of the coilover cycling it tweaks the cab mount and you get a clunk.
    tonered likes this.
  5. Sep 16, 2021 at 8:43 AM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    you sure it's not the ABS system performing it's pre-check?
  6. Sep 16, 2021 at 8:50 AM
    danadavenport
    danadavenport [OP] Well-Known Member
    2021 SR5 DCLB
    Baja mx
    Baja Mx final assembly point.
    Im guessing hes asking because of the quality control topics on Toyota's new production facilities. The Baja facility has been producing Tacomas since 2002 so Im sure they have the wrinkles ironed out by now
    Male with predominantly female name
    tonered likes this.
  7. Sep 16, 2021 at 8:57 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I had a clunk that started at about 25k or so. Initially, it would happen just once in each direction. At first it was gentle, and I chalked it up to the brake pads moving in the calipers. It started getting louder, and by 40k, the stock suspension was toast. At 50k with the noise getting louder and would happen in any hard turn.
    I checked over all of the fasteners up front. Nothing was loose, and it was no help. Finally at 55k, I started swapping out parts. After I replaced the front cab mounts, it quieted down significantly. After I swapped in new front shocks with reused stock coils, the sound was completely gone.
    I would ask them to look at / swap at least the front two body mounts, if not all six. Maybe the other coilover also?
    Also early in my Taco's life, I had to snug up the rear body mounts as they settled and would squeak almost like the leafs do.
  8. Sep 16, 2021 at 9:10 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Don't laugh, its happened till they decide they've had it long enough, and give it back saying they never saw the problem, or it didn't happen for them.
  9. Sep 16, 2021 at 9:14 AM
    danadavenport
    2021 SR5 DCLB
    Thank you for the good info. I will mention the body mount next time they call. When I walking the around the parking lot they had tons of modified tacomas parked out back. Turns out most were employee vehicles so Im pretty confident they will figure it out.
  10. Sep 16, 2021 at 9:16 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    Tacos (and TW) tend to get folks into mods. Hopefully they get you sorted out quickly.
    :cheers:
  11. Sep 16, 2021 at 9:16 AM
    danadavenport
    2021 SR5 DCLB
    I dropped it off Mon morning. About 11am they called and said they could not duplicate the noise. I went back about noon with the tech and got it to duplicate the noise without leaving the parking lot. They have acknowledged hearing the noise as of noon on Mon.
    davidstacoma likes this.
  12. Sep 16, 2021 at 9:17 AM
    danadavenport
    2021 SR5 DCLB
    Haha the funny thing is I have all new shocks and coils ready to put on it once its back
    tonered[QUOTED] likes this.
  13. Sep 16, 2021 at 9:20 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    WrecklessAbandon likes this.
  14. Sep 16, 2021 at 9:23 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I noticed a slight clunk in mine a few times when I first bought it when slowly turning left out of the parking lot at work, sounded like it came from the truck bed. 8000 miles later haven’t heard it since, either they fixed the parking lot or shit settled in lol.
  15. Sep 16, 2021 at 9:28 AM
    #35
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Have them check the front body mounts (radiator support area). They are often misaligned during assembly and it doesn't take long for the metal to cut through them.
    I had a similar problem and ripped my suspension apart probably 10 times, re-torqueing everything, and couldn't find the source. The dealer found it and told me it's a known problem.
  16. Sep 16, 2021 at 9:55 AM
    #36
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    My 2021 had 38 miles on it when I removed the stock front suspension and UCA to install Bilstein 5100, and SPC UCA's with some 285's.
    IFS has a funny issue "perfect storm" if the front coils are positioned in a certain location/orientation, the alignment is set at a certain spec, the coils can contact the sway bar or have some type of binding and popping sound while turning at slow speed. The sound is rather unique. To correct this you need to rotate the coils on the struts to a different orientation.
    If it was a loose body mount like another member suggested the sound would be a like thumping inside the cab.
  17. Sep 16, 2021 at 9:59 AM
    #37
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    Wrong. It sounded like a suspension clunk/pop kind of noise.
    tonered likes this.
  18. Sep 16, 2021 at 10:00 AM
    #38
    danadavenport
    2021 SR5 DCLB
    You are the second person to mention that so it must be more of a common issue. Thank you
  19. Sep 16, 2021 at 10:02 AM
    #39
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    Seriously, I tortured myself trying to track down the noise. Do yourself a favor and just have the dealership check them.
    tw0leftskis, toku58 and tonered like this.
  20. Sep 16, 2021 at 10:06 AM
    #40
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    3x back on the same issue it's a lemon law candidate.
    ajb7074 likes this.
