My New Audio Setup
Discussion in 'Audio & Video' started by kansay, Apr 24, 2013.
  1. Apr 24, 2013 at 8:20 AM
    kansay
    kansay [OP] Well-Known Member
    dude
    Twin Cities, MN
    08 tacoma dbl cab 4x4 sport
    Bilstein shocks front and back.
    Just upgrade my audio setup from 2 8" kicker L7 to 1 JL TW5v2-4. Still running the same Soundstream Rub1.1600 amp and added another Sounstream Rub4.600 for my mids and highs. Sound way better than the 2 kicker but not that loud as the kickers. Made the box myself with some help from a friend.
    Looking to sell the kicker and box setup if anyone interested. $350 local pickup and $400 shipped. PM me
    Old Sub Setup Subs:
    Old Setup Amp location:
    New Sub Setup:
    New Amp Setup:
  2. Apr 24, 2013 at 10:53 AM
    Highspeed
    Highspeed Well-Known Member
    +42° 52' 21.69", -124° 32' 8.50"
    TRD off road
    A.R.E. cap
    nice setup! How did you mount the amp under the back seat? I'm putting amps there now and working on several ideas.
  3. Apr 24, 2013 at 10:55 AM
    Aw9d
    Aw9d That one guy
    Az
    Good call on ditching the Kickers.. I hate square subs.. They sound like ass.
  4. Apr 25, 2013 at 5:40 AM
    kansay
    dude
    Twin Cities, MN
    I mounted the amp there which I had to build my box correctly to fit with the 2 amp. I didn't bother with the back rail that there. Built the backboard over the railing. But I only had about a few cm left for space and barely got the amp to fit without modification to it. So what I got left is 18" by 17 3/4 to fit 2 amps.
  5. May 3, 2013 at 2:04 PM
    kansay
    dude
    Twin Cities, MN
    Here's a diagram of what I did to build my tw5 box if anyone is interested in building one. I didn't cut out the box to fit the back support beam but build it over the beam. So simple angle box with no cutting into the beam or building around the beam itself.
  6. May 3, 2013 at 2:08 PM
    Aw9d
    Aw9d That one guy
    Az
    Awesome! Loads of people will benefit from this diagram..
  7. May 3, 2013 at 2:17 PM
    TuFerLife
    TuFerLife 2 4 LIFE!!!
    Taylor
    Chattanooga, TN
    2011 Ford Raptor (I'm a traitor)
    Hey OP, I see you went with a 13tw5. I have one in a Mr. Marv box and after I installed it o started to listen to music and I could hear it hitting the plastic behind the seat and I immediately shut it off.
    I see in your pic that you removed yours... Has that helped? I just know there isn't much room behind our double cabs and it doesn't seem like I have enough room to really get the benefit of this badass sub...
    Any help would be appreciated!
  8. May 4, 2013 at 6:30 PM
    kansay
    dude
    Twin Cities, MN
    TuFerLife,
    Taking the back piece off would really help your sub. But I didn't know that why Mr. Marv would build a box like that for you. I think he meant that you have to take that back piece off before use. But taking that back piece off don't change anything but gives you more room for the sub to push than to have it damage your sub with the pieces on. Hope that helps.
  9. May 4, 2013 at 8:41 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    That does help...
    I purchased the sub/box from another user on here so I wasn't really sure what the correct way to have it installed. But I took it off, and already feel more confident playing the sub and not worrying about it hitting the back plastic piece...
    Thanks for the tip!
