My new boat!!!!!!
Discussion in 'Boating & Fishing' started by jeckel7234, Jun 26, 2011.
  1. Jun 26, 2011 at 5:12 PM
    jeckel7234
    jeckel7234 [OP] Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
    Just got a 14ft jon boat with no trailer so I decided since it was free it was worth putting in my 6ft bd. lmao, 40 min drive later and the straps still holding tight I have boat.
  2. Jun 26, 2011 at 5:13 PM
    DrewH
    DrewH Well-Known Member
    Sweet boat, and nice name by the way.
  3. Jun 26, 2011 at 5:14 PM
    jeckel7234
    Drew
    VA
    05 Tacoma
    you to buddy, its a good strong name
  4. Jun 29, 2011 at 12:10 AM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    Don't those boats have the welded seams instead of just rivets?
  5. Jun 30, 2011 at 8:20 AM
    jeckel7234
    Drew
    VA
    05 Tacoma
    I dont know, I dropped it off at my dads house the other day, theres two small holes on the bottom of it where the aluminum pelled back, im going to harbor freight tomorrow to get some alumiweld rods, and hopefully that should be able to repair the holes, and ill check, but i do think they are welded
  6. Jun 30, 2011 at 8:39 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    all you need now is a 150....that should be enough
  7. Jun 30, 2011 at 8:42 AM
    jeckel7234
    Drew
    VA
    05 Tacoma
    was planning on 3 supercharger mercury 275's, like they have on the back fountain boats, but no really i am looking around for a 20-30 +/-
  8. Jun 30, 2011 at 8:46 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Don't make the mistake I made.
    Tried to weld a hole that was the size of a pin head and it looked like someone put there fist thru it after I was done. :eek:
  9. Jun 30, 2011 at 8:48 AM
    jeckel7234
    Drew
    VA
    05 Tacoma
    lmao, i have the basic mig welder from HF and i know id put hole through it, but i found this stuff called alumiweld from HF that is like soldering, but you can use it with a propane torch, so im assuming that should work
  10. Jul 7, 2011 at 8:04 PM
    jeckel7234
    Drew
    VA
    05 Tacoma
    They were rivited,
  11. Aug 14, 2011 at 8:58 PM
    SATXguy
    SATXguy Well-Known Member
    San Antonio
    2017 4x4 TRD Off Road
    Mobtown Front Recovery bar Relentless Fab Bed bars (3) Quickfist 2 pair Husky Floor Liners Cali Raised bed channer stiffeners Cali Raised low profile ditch light bracket 27 watt ditch light pods w/ side projection OEM Ditch Light switch Roam Adventure Co. Roof top tent Roof top tent annex Costway 54 Quart Portable Refrigerator/Freezer Compact Smittybilt 2789-99 Transit Bag NOCO GC019 12-Foot 12V Adapter Plug Socket Extension Cable Scoshe Magic Mount for Iphone plus Hypertech Speedometer calibrator BFG KO2 AT 265/75/16 JDMCar Center Console Organizer TRD pro Grill TRD PRO Grille Vinyl Decal Gloss Super White X-Bull Recovery Traction tracks 3rd gen CamPark ACT 74 Action Camera DC cargo 2" Diameter Black Steel V-Ring BoltOn Trailer Cargo Tie-Down CLC 1173 32 Pocket Socket Tool Roll Pouch Viair 00088 88P Portable Air Compressor Toyota Accessories PT580-35050-SB Bed Mat for Select Tacoma Models Rhino USA shackle hitch receiver Toyota Accessories PT580-35050-SB Bed Mat for Select Tacoma Models Smittybilt 3x30 recovery strap 30,000 lb capacity Smittybilt 3/4" D-Ring Shackle (Black) 4.75 ton rating 12V 140 Amp Dual Battery Isolator by KeyLine Chargers - Voltage Sensitive Relay Gen 3 Tacoma Auxiliary Battery Tray
    Nice boat! That's all you need to get you were the fish are! I have a 15ft side console one with a 25hp evinrude. With gear and my two boys in the boat I can do 23 mph per my gps. Alumaweld will patch it just make sure you clean the area and heat it up real good before you try and patch it.
