My new KMC XD222 17x8.5s
Discussion in 'Wheels & Tires' started by tostidos, Feb 21, 2011.
  1. Feb 21, 2011 at 8:28 AM
    tostidos
    tostidos [OP] Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    So I just ordered a set of KMC XD222 17x8.5s. These bad boys look awesome! Should have 'em in a week or 2. What do you guys think?
  2. Feb 21, 2011 at 8:32 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    clearcoat no.....thats just me
  3. Feb 21, 2011 at 8:34 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    why so against the clearcoat?
  4. May 9, 2011 at 7:28 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Thought I would add some info and feedback after Ive put some miles on them. The offset and backspacing was off on my rims and needed to put 1" wheel spacers to clear my calipers. Thus in turn causing my tires to rub without a lift on both forward and rear parts of my fenders. I am runnning 265/70R17 terra grapplers. Well I got a 3" prerunner style lift to stop the rubbing and it continued to slightly rub on the rear part of the fender wells. So then I resorted to pre runner fenders and now the problem is fixed.
    Just a heads up because I believe they only offer this wheel in one offset/backspacing. and you will need atleast a 3" lift and 1" wheelspacers only on the front to get these to fit. I assume a 6" lift should be plenty to clear them all the way. hope this Info can be useful.
  5. May 9, 2011 at 7:35 PM
    sierrahsky
    sierrahsky Expedition Style
    Josh
    Reno
    09 TRD Tacoma V6 Ex Cab | Extreme Sierra
    This year they are going to offer them in a true beadlock 17" and 15" with the correct backspacing. I was going to order these locally until I saw the price.
    I hope you enjoy this wheel it had awesome specs on it for a bead lock.
  6. May 9, 2011 at 7:36 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Offset is 0mm and backspacing is 4.75". They are legit beadlocks. had an issue where the guys who installed them slashed all the valve stems. But after that was fixed they hold air real well.
  7. May 9, 2011 at 7:40 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    do you have a pic of them mounted, and where did you pick them up and for how much. I got a set of ATX beadlocks but in the wrong wheel pattern that im sitting on until I can sell them
  8. May 9, 2011 at 7:42 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
  9. May 9, 2011 at 7:44 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    The reason I ran with a 17" is some guys were showing signs of rubbing on the inside diamater of 16" rims while running LT.
  10. May 9, 2011 at 7:46 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    There you go. Ill get some better side pics in the AM. I added the link to 4wheelonline a couple posts back.
  11. May 9, 2011 at 8:02 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Havent had to yet. The guys installing them will bitch about how hard they are to balance which I understand. But thus far Ive had them on for just over a month and havent had any new issues. I feel pretty confident offroad with these things. They are thick and stout. and the beadlocks arent going anywhere. Im going to throw the torque wrench on them tommorow to see if any are losing torque.
  12. May 9, 2011 at 8:18 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    I should probably Add that I found out the hard way that Beadlock rims are not DOT approved and therefor illegal. So allot of chain owned shops will not even look at them or check the air pressure on them. Kinda a pain in the ass.
  13. May 9, 2011 at 9:42 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Sick wheels. My buddy has them on his LT f-150... but yeah they're illegal for on road use.
  14. May 9, 2011 at 9:47 PM
    bobby15
    bobby15 Well-Known Member
    Bobby
    Chino Hills, Ca
    09 DC LB 4x4 magnetic grey tacoma
    tint, Fox 2.5 coilovers, Total Chaos UCAs, bump stops, fox 2.0 piggybacks, All-Pro leaf pack, Nitto Trail Grapplers, Robby Gordon signature series rims, Magnaflow exhaust, Gen 1 TRD cai, blacked out tails, halo head lights, flood lights behind the grill, Street scene grille,L.E.D. dome, map and license plate lights, HID's in the headlights and fog lights, Kenwood touchscreen head unit, fog light mod, vinyl rapped valence, plasti dipped badges ..more to come
    Why are true beadlocks illegal?
  15. May 9, 2011 at 10:11 PM
    bobby15
    Bobby
    Chino Hills, Ca
    thanks for the info !!
