My new OME 3" lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Icepuck72, Apr 21, 2014.
  1. Apr 24, 2014 at 4:07 PM
    #61
    Supashawn
    Supashawn Well-Known Member
    Canada
    09 tacoma trd
    did u use a trim packer? I have the same lift and yet to install...I have an 1.5" 3 leaf progressive for the rear....do u think I will get bro lean if I use the 1/2" spacer? its dclb
  2. Apr 30, 2014 at 3:33 AM
    #62
    ThomasMore66
    Dallas/Fort Worth & Durango
    Mark, any update on the rubbing with the new tires/lift?
  3. Apr 30, 2014 at 4:25 AM
    #63
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    tell me about your alignment specs.
  4. Apr 30, 2014 at 5:03 AM
    #64
    Icepuck72
    Icepuck72 [OP] Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    no rubbing. I can take some pics where some of the trimming was. It was very minor. Very happy with it.
  5. Apr 30, 2014 at 5:04 AM
    #65
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    I do think I need the carrier bearing drop, though. I have the shudder when I take off.
  6. Apr 30, 2014 at 5:10 AM
    #66
    ThomasMore66
    Cool. As of Monday my OME leaf springs were in WA. Finally all my parts will be here.
  7. May 17, 2014 at 6:51 PM
    #67
    ThomasMore66
    I got my icon stage 4 installed with OME rear leafs. Love it, but I have a question. I went to the car wash today and when I left I had this creaking from the rear. It went away, but I'm curious if other people have this issue when the ome's get wet.
  8. May 19, 2014 at 5:15 AM
    #68
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    03 Tacoma SR5
    3" lift Freedom Off-road adjustable coilovers 5100’s out back with AAL TRD Pro wheels w/ 285.75.16 KO2’s Freedom Off-road UCA’s 4xInnovations front bumper (on order!)
    I get it all the time after car washes. The dakars are known to be squeaky but I thought powerwashing them would help stop the squeak for a bit but that hasn't been the case for me.
  9. May 19, 2014 at 5:37 AM
    #69
    ThomasMore66
    Passenger side is really annoying
  10. May 19, 2014 at 5:41 AM
    #70
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    No creaking or squeaks as of yet.
  11. May 19, 2014 at 6:03 AM
    #71
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    give it a few months. Winter sped it up for me. I find the DuPont Teflon spray works well. OzT had a write up on putting some rubber near the shackle to alleviate it. I spray once a month give or take and I don't have issues. That spray seems to do the trick.
  12. May 19, 2014 at 6:45 AM
    #72
    ThomasMore66
    The thing is brand new. I took it for a little minor off-roading just to see how everything handled, went to the car-wash, squeak. I'm kinda surprised that I've never had issues with any of my trucks until the OME springs. Is this the stuff? http://www2.dupont.com/Consumer_Lubricants/en_US/products/silicone.html
    Seems to better if there is a load in the back. Hauled some rock around this weekend and it didn't seem to squeak then. I went with the OME because I felt that the hauling characteristics of the truck would be enhanced vs. the AAL that came with the Icon.
  13. May 21, 2014 at 1:13 PM
    #73
    TRD6Speed
    Bill
    East Hartford, CT
    This is what I use.....although that silicone spray looks good too.
    http://www2.dupont.com/Consumer_Lubricants/en_US/products/multi_use_lubricant.html
  14. May 21, 2014 at 1:17 PM
    #74
    ThomasMore66
    So, I just got back from the installer. Turns out that after all the installation work they did on the Icon parts, they installed the back two leaf spring bolts backwards and they were rubbing on the shackle support. OMG! The squeak is gone and the ride is better. I think the ride is better than stock even with the Dakars. I think the bolts were limiting the travel of the leaf and now it's perfect. Now I can carry a bunch of stuff and haul ass. Need wheels/tires!
  15. May 22, 2014 at 6:49 AM
    #75
    tacopaulo
    tacopaulo Tanned
    Paulo
    Raleigh, NC
    red truck
    Love it man. I got an 07 and the same color and want to do this setup now hah. I'm just worried about the mpg since I do about 50 miles a day.
  16. May 22, 2014 at 6:52 AM
    #76
    ThomasMore66
    I drive right at 60 miles/day and the traffic is awful - stop and go a bunch of the way. I don't even calculate my gas mileage. I know I get gas twice/week and I don't buy as much as I did when I had a 1st gen Tundra.
  17. May 22, 2014 at 6:54 AM
    #77
    RedDragonTaco
    RedDragonTaco Knight Industies Toyota Tacoma
    Slc, UT
    2007 Double Cab TRD Sport
    Toytec 3" Ultimate w/ LR UCA's, 18" Rockstar rims, Nitto Grappler 285/65/18, OEM roof rack, foglight anytime mod, front bull bar and Smitty side steps, tonneau cover, debadged, BHLM, blacked out tail lights, stubby antenna, flowmaster
    Sweet ride
  18. May 22, 2014 at 8:01 AM
    #78
    tacopaulo
    tacopaulo Tanned
    Paulo
    Raleigh, NC
    red truck
    You fill up twice a week? What's your setup?
  19. May 22, 2014 at 8:37 AM
    #79
    ThomasMore66
    I fill up when I get to about 1/2 tank, so the reality is I use a little over a tank a week for 300 miles. Bought the truck a little over a year ago and I have over 21,000 miles.
  20. May 22, 2014 at 8:48 AM
    #80
    tacopaulo
    tacopaulo Tanned
    Paulo
    Raleigh, NC
    red truck
    Gotcha. You scared me a little there.
