My new overpriced heaping pile
Discussion in '4th Gen. Tacomas (2024+)' started by snickers, Aug 27, 2024.
  1. Sep 28, 2024 at 11:25 PM
    #301
    Chriswhaaaat
    Chriswhaaaat Well-Known Member
    Alberta, Canada
    2024 Tacoma Trailhunter, 2018 4runner, 1977 FJ45, 2006 Hijet
    I feel this might be a relevant update… with my ATV in the back (~500lbs with other gear in there too), I dont really have much squat, which I was actually quite pleased to see.
  2. Sep 28, 2024 at 11:29 PM
    #302
    Chriswhaaaat
    Alberta, Canada
    Yooo this seems like shit. I’m looking at about 4000-5000 Canadian for wrapping about 80% of the truck with PPF. (Can’t do the plastic/matte surfaces, not doing side windows)
    Flori-duh Taco likes this.
  3. Sep 28, 2024 at 11:42 PM
    #303
    Chriswhaaaat
    Alberta, Canada
    In fact, the back seat actually has an extra inch of space, deleted from the front seat space. Front is just more ‘upright’ now, giving a roomier feel.
    snickers[QUOTED][OP] likes this.
  4. Sep 29, 2024 at 1:04 AM
    #304
    snickers
    snickers [OP] My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Yours are wider? Post pics please.
  5. Sep 29, 2024 at 1:08 AM
    #305
    snickers
    Yeah lots of cornfuzion about this. When it was first announced, youtubers were up in arms saying the wider track was because of wheel offset. Then later it was revealed they all come in positive offset. This does not compute. I was going to measure my 3G axle width from wheel hub face to compare with the new truck. But, didn't get the time. Now I just don't care.
  6. Sep 29, 2024 at 8:36 AM
    #306
    TacoRancher
    TacoRancher Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    I saw this in the manual. My trailhunter is 5” wider than my 3G pro. As for the wheel offset I think that’s true, as I think the TH just has less positive offset than the other trims. Either way it helps fit larger tires on the pro and TH so it’s a win for me either way.
    Chriswhaaaat likes this.
  7. Sep 29, 2024 at 9:59 AM
    #307
    Chriswhaaaat
    Alberta, Canada
    I dont know if they are wider. I think they are a bit dumb. I do not like that gap between the flare and flap, and dont like the stiffness. I’d like rally armour flaps or something like that, but I wish they offered just a little more coverage outward and downward.
  8. Sep 29, 2024 at 10:25 AM
    #308
    snickers
    Thanks. I think I saw these earlier and wondered if they were flexible (as in almost doubled over) like the US version. That saves me from making a bad purchase.
  9. Sep 29, 2024 at 10:42 AM
    #309
    snickers
    For those interested in the Toyota molle panel set for the hybrid and want to compare them with others here are the part numbers. I do not know if a molle panel exists for non-hybrid:
    Front bed: PT767-35900, 1 piece
    Side 5ft bed: PT767-35700, 2 pieces, driver and passenger
    Side 6ft bed: PT767-35800, 2 pieces, driver and passenger
    Each part number/package comes with an identical bag of hardware. Each side panel requires drilling a hole and installing a provided rivnut. Said rivnut didn't fit my tool, so I used my own.
    Here is the driver side:
    Here is the passenger side:
    Here is the overall:
    Installation pdf is attached below.
  10. Sep 29, 2024 at 1:13 PM
    #310
    Chriswhaaaat
    Alberta, Canada
    What do you think of that bed mat? Is it Yota brand?
  11. Sep 29, 2024 at 1:21 PM
    #311
    snickers
    Lasfit. Ok with it so far. I can only compare it with my 3G Toyota mat. That was a hard rubber. The current crop of aftermarket mats seem to use the same material. Deeper grooves and rise higher along the bed sides.
  12. Sep 29, 2024 at 3:42 PM
    #312
    bobobuhanych
    bobobuhanych Well-Known Member
    Rob
    Hawaii - Big island
    2024 Trailhunter
    Nice Molle panels. The ones I have installed didn’t require any drilling. Which is nice
    it suppose to require drilling on driver side only but with the compressor panel. I didn’t have to. Used the bolts for the compressor panel
  13. Sep 29, 2024 at 3:49 PM
    #313
    snickers
    What did you get? Yes, I would preferred that they used the existing panels screw hole locations on the compressor panel and the power outlet panel.
  14. Sep 29, 2024 at 4:00 PM
    #314
    TacoRancher
    Houston
    Does front Yota molle need drilling or just the sides
  15. Sep 29, 2024 at 4:04 PM
    #315
    snickers
    Just the sides.
  16. Sep 29, 2024 at 4:04 PM
    #316
    bobobuhanych
    Rob
    Hawaii - Big island
    2024 Trailhunter
    rago fabrications for sides and caliraised for front of bed
    Fieldsanitation and PUMPKINKING like this.
  17. Sep 29, 2024 at 4:08 PM
    #317
    snickers
    I like the Ragos. Didn't know they had them out until way past when I ordered the Toyotas. I would keep the front Toyota. Just don't understand mounting on top of the bed rail.
    TacoRancher likes this.
  18. Sep 29, 2024 at 4:13 PM
    #318
    bobobuhanych
    Rob
    Hawaii - Big island
    2024 Trailhunter
    I agree. I would have done the Toyotas. Caliraised front Molle was the only one that didn’t have rip off prices shipping to Hawaii. Its two piece so box was smaller.
    CaliRaisedLed likes this.
  19. Sep 29, 2024 at 5:40 PM
    #319
    TacoRancher
    Houston
    For the front MOLLE - it looks like Cali raises goes on top of the deck rail and the Yota goes behind it? How do either of them secure at the bottom?
  20. Sep 29, 2024 at 5:50 PM
    #320
    bobobuhanych
    Rob
    Hawaii - Big island
    2024 Trailhunter
    Correct. They secure with the factory bolt in the bed floor. Its under the bed mat So you can’t see it
