My new overpriced heaping pile
Discussion in '4th Gen. Tacomas (2024+)' started by snickers, Aug 27, 2024.
  1. Sep 1, 2024 at 1:53 PM
    #121
    TacoRancher
    TacoRancher Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    I hear the screen is nice.
  2. Sep 2, 2024 at 4:46 AM
    #122
    TacoRancher
    Houston
    So let me get this straight, I had a 2022 Tacoma TRD PRO with 9.4” of clearance at the diff, out of the box. I put 265/75/16s (32s) on it and got that figure up to near 10”…
    Then I buy a trillion dollar Trail Hunter which is supposed to be a halo model, with 33” tires out of the box, and it’s got 9” of ground clearance? So I have to put 35” tires on it to get the same clearance I had before with 32s? Got it Toyota.. that’s super disappointing..
    Does it at least have better running clearance???? My old 3G was stolen so I can’t compare.
    No wonder Toyota doesn’t include the clearance specs anywhere like they did on the 3G.
    Edit: I don’t recall what my actual 3G measurements were .. going off official posted numbers.
  3. Sep 2, 2024 at 4:49 AM
    #123
    TacoRancher
    Houston
    Probably the most planted feeling truck I’ve driven .. similar to a full size.
  4. Sep 2, 2024 at 4:51 AM
    #124
    TacoRancher
    Houston
    OK, so the 3G has 9.4” official clearance but in real life it was 8.5”? That kind of makes sense because I don’t think mine was actually 9.4” as claimed .. maybe that was wirh tires inflated to 80psi
  5. Sep 2, 2024 at 7:06 AM
    #125
    snickers
    snickers [OP] My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Tell me about it. My hopes and dreams of being able to walk under the rear diff without ducking my head has been smashed to smithereens.
  6. Sep 2, 2024 at 7:12 AM
    #126
    TacoRancher
    Houston
    lol
  7. Sep 2, 2024 at 7:14 AM
    #127
    Hrímfaxi
    Hrímfaxi Well-Known Member
    Because it now has grown into the size of a 1/2 Ton. Crazy how big Toyota’s “little” trucks have become.
  8. Sep 2, 2024 at 2:45 PM
    #128
    Kodachrome
    Kodachrome Well-Known Member
    Western Colorado
    2005 Taco, 2024 Audi SQ8 ETron
    TRD S/C, URD...Stuff
    I have a Four Wheel pop-up camper in the bed of my 2005 that is about 700lbs dry, probably close to 1K with everything on/in it. But, my truck is highly modified front to back, suspension, lift, S/C’d engine putting out over 400HP.
    I have a TH with the 6’ foot bed on order but I am not sure if I will continue with it. I need to see a report of someone putting one of these slide-in campers on it and how the truck actually does, if they blow way past GVWR, etc.
  9. Sep 2, 2024 at 2:47 PM
    #129
    snickers
    I wasn't expecting real 35 inches, but the KO3 LT 285/70/18 is even shorter than 34.8. Another example of Toyota's quality falling:
    40 psi. Maybe haft ta inflate it to 80 to get the 34.8. C'mon Toyota!
  10. Sep 2, 2024 at 2:51 PM
    #130
    snickers
    Not sure what to tell you since I have no plans on a slide in camper. The TH is supposed to be out of the box with all that other stuff. That is why the payload is lower. I am going to pull off that ARB fake rack thingy and give you a number on that. Good luck.
  11. Sep 2, 2024 at 2:54 PM
    #131
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    The big question is how long will the frame remain solid in the rust belt... or anywhere else.
  12. Sep 2, 2024 at 2:58 PM
    #132
    snickers
    I waited six years in the salt belt for my frame on my 3G to rot out under me as promised by the gurus here at TW. Since I can't do that anymore considering I no longer have the truck, I can't celebrate the Rotting Of The Frames with those exquisitely beautiful, high IQ gurus. Me thinks they have a convention coming up soon? Maybe I can drop in.
  13. Sep 2, 2024 at 3:02 PM
    #133
    Kodachrome
    Western Colorado
    Right, I would be punting the bed bar thing as well for obvious reasons. I would just keep my truck running for another 50-100k miles but the frame rust means it has a finite life. On paper the TH looks to be the part, but you are seeing that load number with a 5’ foot bed. I’m sure I will get more info as more people get the truck…
  14. Sep 2, 2024 at 3:41 PM
    #134
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    Trailhunter doesn't come with 285/70/18s which are spec'd at 33.7 (the 285/75/18s are 34.8). Did you mean to blame BFG?
    PUMPKINKING and ace_10 like this.
  15. Sep 2, 2024 at 3:44 PM
    #135
    TacoRancher
    Houston
    You need to get to know OP. He’s a bit sarcastic but all in good fun.
  16. Sep 2, 2024 at 3:49 PM
    #136
    snickers
    Oops. Typo. C'mon Toyota!
  17. Sep 2, 2024 at 3:51 PM
    #137
    snickers
    This is why I opened up this thread. To quarantine myself here in my own lunacy.
  18. Sep 2, 2024 at 3:57 PM
    #138
    snickers
    Rear ARB high lift jack points verified to work:
    PUMPKINKING, Slashaar, Burns and 3 others like this.
  19. Sep 2, 2024 at 4:00 PM
    #139
    TacoRancher
    Houston
    Noiceeee
    rchrds likes this.
  20. Sep 2, 2024 at 4:28 PM
    #140
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I doubt it all stays in here :anonymous:
    snickers[QUOTED][OP] likes this.
