My New Satoshi
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moondeath, Nov 19, 2011.
  1. Nov 19, 2011 at 6:35 AM
    moondeath
    moondeath [OP] The answer to divorce...... Tequila!
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I just finished my grill last weekend. I used a colored matched grill off a pre 2011 tacoma. I used many of the write ups on tacoma world to do this, so thanks to all those people.
    Here is my original grill.
    Then my purchased color matched grill.
    Taping the grill up.
    Cutting out the center pieces.
    All pieces cut out. I used a dremel and hack saw blade.
    I used a fiberglass kit for the 2 ends, then bondoed everything. This is after 2 or 3 coats of bondo. Sanding and reapplying.
    Where I epoxied the screws.
    Epoxied screws to the emblem.
    This is where I relocated my horns to. Just used an existing screw that holds a bracket that is in front of the radiator.
    Mounting points for the grill I put on.
    After I painted the radiator with engine high temperature paint.
    Finished product on truck.
  2. Nov 19, 2011 at 6:39 AM
    LostRebel
    LostRebel Well-Known Member
    Almost Canada, USA
    Black Access Cab 4x4 TRD Off Road
    Fisher plow, BakFlip and Snugtop cap, Demello Sliders, Scanguage,
    Looks real good. Nice job!
  3. Nov 19, 2011 at 6:41 AM
    redge_drz
    redge_drz Member
    New-Brunswick
    09 SR5 4 cyl. MGM 4x4
    I used the same grill. Really nice job !
  4. Nov 19, 2011 at 6:43 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Great job!
  5. Nov 19, 2011 at 6:45 AM
    upthemaiden
    upthemaiden Well-Known Member
    Josh
    Pittsburgh PA
    06 Access cab SR5
    Just bought it!
    glad to see someone doing this with the hood guard. I prefer the satoshis that are mounted on the outside of the grill instead of the inside, but I don't ever see anyone who's doing it with a hood guard so it's hard to get an idea if it'll still look good or not with mine.
  6. Nov 19, 2011 at 6:47 AM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    Looks good, people tend to forget to paint the rad.
  7. Nov 19, 2011 at 2:48 PM
    JRob33
    JRob33 Well-Known Member
    Josh
    Bossier City, LA
    '10 White Double Cab TRD Sport 4x4
    Looks great! Are you able to see the horns through the lower valence opening?
  8. Nov 19, 2011 at 9:08 PM
    moondeath
    Pa, Carlisle
    If you know what your looking for you can. But its not really noticeable.
  9. Nov 20, 2011 at 10:17 AM
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    Nice work on the grill, hard to tell but were you able to relocate both horns in that spot?
  10. Nov 20, 2011 at 10:44 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    Chad
    FJ HubRunner SR5
    it's not a satoshi unless it's on the inside... on the outside, it's just a "bolt-on"
  11. Nov 20, 2011 at 10:44 AM
    05Taco4x4
    Chad
    FJ HubRunner SR5
    looks good BTW
  12. Nov 20, 2011 at 10:48 AM
    rev25sharp
    rev25sharp Well-Known Member
    Al
    jacksonville fl
    Silver 17dcsb trd sport
    nice work
  13. Nov 21, 2011 at 3:02 PM
    moondeath
    Pa, Carlisle
    Yes, both horns do fit there. Barely, but they do. Beside where I put the horns, there is predrilled and threaded holes that I could have used. But I would have needed to go to the store and buy some bolts. I may still do that. If I remember correctly, they were the same size as the windshield washer reservoir bolts.
  14. Nov 26, 2011 at 8:02 AM
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    Looks awesome man!!! Did you tape anything off before painting the radiator?
  15. Nov 27, 2011 at 8:14 AM
    moondeath
    Pa, Carlisle
    Yes. I newspapered the bumper and some surrounding areas that I didn't want to accidentally overspray on. I also taped the ac line caps.
  16. Nov 27, 2011 at 9:00 AM
    JustinL
    JustinL Well-Known Member
    Justin
    Newington, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
  17. Nov 27, 2011 at 9:04 AM
    80s toysport
    80s toysport Well-Known Member
    Nikolai (Nik)
    kansas city, ks
    09 DC TRD off road
    Camper, nerf bars, visors, hood bug gaurd, ABS killswitch, bed light
    WOW! Looks really nice dude.
  18. Nov 27, 2011 at 6:11 PM
    kimo
    kimo Well-Known Member
    Darin
    MONTEREY BAY
    07 TRD sport pre-runner
    Nice job. I need to get up the courage to hack up my grill. That looks a lot better than stock.
