My New Tacoma.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jonnyis300, Oct 18, 2014.
  1. Oct 18, 2014 at 9:36 PM
    Jonnyis300
    Jonnyis300 [OP] Member
    Jon
    Southern IN
    Prerunner TRD Sport
    Hello all. Name is Jon. Live in southern Indiana. Just picked up my new Tacoma a few months ago. Its a 2014 prerunner with the 4.0 V6. Trd Sport packaged. 5spd auto.
    I have a little over 2800 miles on the truck and decided to check my fuel economy with a little trip. I filled up before hand in town and drove to Louisville and back. 234 miles round trip. Tank was near empty.
    Filled tank again at 16.24 gallons. Now that equals out to 13 mpg.:(
    Why am I not seeing the 23mpg everyone else is getting?
    I was using cruise and had it set at around 80mph.
    Any and all help or suggestions would be greatly appreciated.
    This is my first brand new vehicle. I bought it with 10 miles on the odometer. Is this some normal break in thing?
  2. Oct 18, 2014 at 9:38 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    Once you hit 60 it all goes downhill ...
  3. Oct 18, 2014 at 9:39 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Slow down a bit and don't go 80
  4. Oct 18, 2014 at 9:41 PM
    Jonnyis300
    Jon
    Southern IN
    Prerunner TRD Sport
    Going over 60 kills it that much?
    Around here and most of my driving is on I69, which has a 70mph speed limit. Most everyones rolling 80.
  5. Oct 18, 2014 at 9:42 PM
    Jester243
    Dan
    Spokane, WA
    You're driving a brick
  6. Oct 18, 2014 at 9:45 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Who is getting 23???????????? I have the same truck. Never even came close to 23.
  7. Oct 18, 2014 at 9:46 PM
    Jester243
    Dan
    Spokane, WA
    I have got 23 on one trip but it was over 4 hours on a 2 lane highway with a max speed of 60.
  8. Oct 18, 2014 at 9:51 PM
    Jonnyis300
    Jon
    Southern IN
    Prerunner TRD Sport
    Ok maybe 23 was to high, but many websites say a 2wd AC Tacoma v6 should be getting near 20. 13 to me is a long enough jump from 20 to have me asking. I understand its not an aerodynamic machine, but some people of fuelly.com are averaging 19/20 mpg.
  9. Oct 18, 2014 at 10:20 PM
    Dunckel
    Dunckel Monkey slapper
    Spokane
    TRD Sport
    Yup. Tacomas are aerodynamically equivalent to a loaf of bread.
  10. Oct 18, 2014 at 10:36 PM
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    My mph started to go up after i got about 3500 miles on the truck. I guess it started to finally get broken in around that time. I average about 19.5 to 20. I use 93 octane and usually run about 68/70 on the fourlane. Mine is a DCSB 4.0 V6 4x4 auto.
  11. Oct 18, 2014 at 10:45 PM
    Caboose
    Caboose Active Member
    CO
    14trddcsb
    When I first got my new 14 tacoma I was getting horrible gas milage around 13 to 14. It has slowly been going up ever since then Im at about 17k miles now and I never get below 20 mpg best tank i got was 23 mpg. I would say just keep and eye on it and calculate every tank you should see it slowly go up. My commute to work is about 35 mins long half the time driving at about 80 mph and the other half at about 65.
  12. Oct 18, 2014 at 10:49 PM
    Jonnyis300
    Jon
    Southern IN
    Prerunner TRD Sport
    Now that's more what I was expecting to see MPG wise. Apparently mine has yet to cut its teeth so to speak. Ill watch it and see how much of a difference there is if I cut back to 70mph.
    I know the truck is a brick. That's not why I bought it. I bought it to be a truck. I didn't expect it to get prius fuel mileage. Was only confused as to why it seemed so low. Thanks guys.
  13. Oct 18, 2014 at 10:50 PM
    Jonnyis300
    Jon
    Southern IN
    Prerunner TRD Sport
    Caboose you have the exact same time and speed drive to work I have. Thanks for your input.
    Thank you all for the input.
  14. Oct 18, 2014 at 11:15 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    So, I have an Ultragauge and I was stoked when I got my average up to 15.4 mpg. 23...dream land.
  15. Oct 18, 2014 at 11:22 PM
    15bluetaco
    15bluetaco Well-Known Member
    oklahoma
    15 Tacoma DBSB 4x4
    10%ethanol or pure gas?
  16. Oct 18, 2014 at 11:31 PM
    Caboose
    CO
    14trddcsb
    10% ethanol premium grade
  17. Oct 19, 2014 at 6:21 PM
    15bluetaco
    oklahoma
    15 Tacoma DBSB 4x4
    That's going to make a difference. I lose a couple mpg with corn syrup gas. Do you have access to pure gas so can run a tank and see what your mpg is?
  18. Oct 19, 2014 at 7:29 PM
    Caboose
    CO
    14trddcsb
    I can try to look for some Ill have to get back to you on that.
  19. Oct 19, 2014 at 9:37 PM
    Pool Runner
    Pool Runner Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    Anything over 68 in these truck crushes the economy. I would go so far to say, the Tacoma is a great short trip truck, but a commuter it is not and has never been. Like what has been already said, the aerodynamics of these trucks is horrible, but Toyota gave us excellent clearance, with a focus on Off-road capability over fuel economy (And I'm grateful for that)
    If you want a truck, and care more about fuel economy. You want a 2wd F-150, EcoBoost with super tall 3.15 or 3.31 axle ratio. You will see over 20's easily with that.
  20. Oct 20, 2014 at 8:48 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I can consistently get 19-20 in my '14 DCLB V6 SR5, If I keep the rpm's below 1500 :) and drive like an old fart.
