My new to me 2020 Trd OR has been modified by previous owner
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Defcon, Jan 23, 2024.
  1. Jan 23, 2024 at 5:02 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    They are all flat.
    jmneill and Junkhead like this.
  2. Jan 23, 2024 at 5:08 PM
    na8rboy
    WI
    The
    The way that 3rd leaf looks from top. Sure looks like an add-a-leaf, or it's broke/cracked. Not sitting right...Overload looks normal.
  3. Jan 23, 2024 at 5:19 PM
    Defcon
    Defcon [OP] Member
    Shawn
    Really appreciate the breakdown! A lot of great information here. Thank you!
    As long as I can get in and out without a tow truck!
    nudavinci64[QUOTED] likes this.
  4. Jan 23, 2024 at 5:25 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    If you want to do the YouTube video stuff you linked, a good set of Mud Terrain tires would be my first addition. Your video showed a great many different types of vehicles, you should be good with the Tacoma for that stuff. Join an organized club, not an ad hock group of Yahoos and get some knowledgeable, guided experience. Expect to lose those steps one way or another. There are people talking about the springs being bent, maybe so, get down and take a good look in person. I have wrapped several sets of springs rock crawling and regard springs as consumables, just like tires. Generally spring wrap resembles an "S", not a "W". No telling how the previous owner treated the truck.
    RowdyRobby likes this.
  5. Jan 23, 2024 at 5:53 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    You’re fine . If it rides fine then it’s good to go.
  6. Jan 23, 2024 at 6:01 PM
    Toycoma2021
    Your winch will handle that.
  7. Jan 23, 2024 at 6:16 PM
    Defcon
    Defcon [OP] Member
    Shawn
    I am coming from a subcompact hatchback, so I think it rides fine? lmao.. It sure handles road bumps and railroad tracks a lot better! Only issue I really notice is, and I'm new and learning the truck, is bump steer and either wheel weight issue or something, at 45 or 50+ the steering wheel will wiggle back and forth if I go hands free.
    :D
  8. Jan 23, 2024 at 6:21 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    That’s how these trucks come stock.
  9. Jan 23, 2024 at 6:24 PM
    MGMDesertTaco
    Another vote for the Bilstein 6112/5160 if you decide to replace the blocks and spacer. Also, JBA high castor uca's and icon RXT leafs if you decide to go that route.
    Defcon[OP] likes this.
  10. Jan 23, 2024 at 6:28 PM
    Defcon
    Defcon [OP] Member
    Shawn
    I have a folder of bookmarks piling up. Appreciate the recommendations! Anyone have a winning lottery ticket they don't want?
  11. Jan 23, 2024 at 6:30 PM
    Dead-Weight
    Dead-Weight Well-Known Member
    Scott
    Sedalia, CO
    ‘22 OR Lunar Rock
    Pine tree air freshener
    Previous Owner probably took it over some sweet jumps :)
  12. Jan 23, 2024 at 8:34 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Naw man, I know you. I don't get mad over a good exchange of opinions. :hattip:
    I just never saw that level of deformation on an empty load on a Tacoma. (I did see it on my own trailer right before it dropped its axle in the middle of a big road trip last November, but that's something completely different and unrelated.) I do agree that this likely is a case of overtightened bolts around that dang spacer block. I just have weird speculations about how that affects the performance of the metal. :cookiemonster:
    musicisevil likes this.
  13. Jan 23, 2024 at 8:51 PM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    I have been running a slight w leaf for 5 months and notice no difference on an empty bed. Stock are pretty much flat anyway. I bought some takeoff leaf packs from a guy who replaced his packs and no more w.
    Your vibration could be simply worn tire tread if old tires and/or time for an alignment.
    Stock front and rear shocks not too old. You only want a 1/2" top hat spacer, otherwise a basic Bilstein 5100 ride height adjustable shock is the better route to get an inch lift in front if you're going to be offroading.
  14. Jan 23, 2024 at 9:19 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
  15. Jan 23, 2024 at 10:08 PM
    #35
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    While they do not directly address your concern or lack therof, one may infer a W shape is not desireable. It was why I caveated my post with "FWIW"
    It's the same shape you would see on overloaded leafpack. Less deflection from the designed shape begets longer fatigue life.
    There are a few other good articles on that site...
  16. Jan 23, 2024 at 10:10 PM
    #36
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Seems like a tire balance issue . Steering wheel vibes at that speed points to a front tire
  17. Jan 24, 2024 at 8:03 AM
    #37
    BlarBlarjosh
    BlarBlarjosh Well-Known Member
    Josh
    Southern California
    I find it odd that the PO put in a warn winch and only a block and spacer lift. Why pay the premium on the winch and cheap out on the suspension?
    BTL Y-Wing likes this.
  18. Jan 24, 2024 at 10:11 AM
    #38
    81shark
    81shark Well-Known Member
    not surprising to me. 90% of the time, it's about the look. see trd grill.
  19. Jan 24, 2024 at 10:13 AM
    #39
    BlarBlarjosh
    Josh
    Southern California
    I get that, but I'd imagine a badlands winch with a factor 55 fairlead/hook if that were the case. Now I'm wondering if they bought someones warn fairlead/hook take offs for cheap.
  20. Jan 24, 2024 at 10:41 AM
    #40
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Nipple rings.
