My new toy! Bushmaster AR 15 - Upgrades?
Discussion in 'Guns & Hunting' started by ShaneHD, Aug 29, 2011.
  1. Aug 30, 2011 at 11:29 AM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    This NC Star 9x42 is for carry handle only i will sell for 80.00. Red/ Green reticle iluminated.
  2. Aug 30, 2011 at 11:31 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I think he should be fine with it. It may be a little heavy for him now, but in time it will be fine.
    I would stick with iron sights before getting a good quality optic. Cheap (<$100) scopes never work well in my experience.
  3. Aug 30, 2011 at 11:52 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    get a pad for the stock and spend the rest on ammo.
    if you are bench shooting then I wouldnt worry about a sling until the time comes for needing one. As for a red dot over a magnified scope depends on how you want to use the rifle. under 75 yards I would say a red dot it fine. anything over I personally like to have a magnified scope, I like to see where im hitting. You can get enrty level nikon scopes that work fine on AR's.
  4. Aug 30, 2011 at 1:09 PM
    TacPro45
    TacPro45 Well-Known Member
    '11 TRD Sport Double Cab Long Bed
    Weathertech Floor Liners
    IMO you should wait on upgrading anything and just get some rounds down range. You don't want to skimp on optics/lights, you get what you pay for.
    Invest in some good iron sights and get some ammo. Down the road explore the world of optics and other Gucci gear.
    You will do what you want, just my .02. ;)
  5. Aug 30, 2011 at 1:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The Stock triggers I have seen, have been between 10 and 12#, and not that smooth. The polished ones, and some RRA's have been between 8# to 6/7#. Being as most of my hunting rifles have a 3# SS trigger, I chose to make that a mod on my AR. BUT.....you make good points on getting some range time in first.
    Yeppo! I stand corrected. For some reason I was thinking the Geisels were a copy. :eek: Thanks for clearing it up.
  6. Aug 30, 2011 at 4:49 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
  7. Aug 30, 2011 at 8:49 PM
    ShaneHD
    ShaneHD [OP] Taco Tuesday
    Fort Worth TX
    2010 Tacoma CrewCab TRD
    Honestly, the trigger is the last thing I think I will upgrade. Never understood why going from 8lb pull to 4lb is such a big deal....
  8. Aug 30, 2011 at 8:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Trigger is one of the biggest factors on accuracy. If the trigger is sloppy, your groups wont be as good as they can be.
  9. Aug 30, 2011 at 8:54 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I know we've discussed this before but I'll just say that $10 JP trigger&hammer springs in my mind is a better value than expensive drop in triggers but that's just one man's opinion.;)
  10. Aug 30, 2011 at 9:00 PM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    trigger for sure after a <100$ you want to spend around 250$ atleast on a scope more if its a red dot....I have used everything under 100$ nothing is worth wasting the money on. my trigger on my .308 in set in the oz. weight around 10oz. cut my groups in half (penny size at 200yrds)
  11. Sep 1, 2011 at 8:08 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    What he said.
  12. Sep 1, 2011 at 9:17 PM
    ShaneHD
    Fort Worth TX
    Are local gun shows a great place to find cheap AR gear? I'd like to add iron sights, front handle/rail system, and maybe the .22 conversion kit.
  13. Sep 1, 2011 at 9:29 PM
    Packman73
    2007 TRD Off Road
    Not here. After you pay for parking and/or admission there just isn't any good deals to make up for that. YMMV.
    I get most everything from the web. Just don't cheap out on stuff because it's cheap for a reason. For real.
