My Newest Mods
Discussion in '1st Gen. Tacomas (1995-2004)' started by MowTaco, Jan 27, 2010.
  1. Jan 27, 2010 at 6:05 PM
    MowTaco
    MowTaco [OP] Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Hey guys
    I just did a couple of little things to the Taco. I had a couple questions anyway and I thought I'd just put pics of everything in here.
    First, I did the deck plate mod. I got a 4" deckplate off ebay for like $1 and the shipping was $8. I picked up some silicone from Oreillys and got to work.
    When I had it all apart, I noticed this and thought it looked cool. THIS is why we use air filters...
    Then I got my pattern traced around it
    I tried cutting it with a dremel first, but I broke like 4 cutting wheels and got about 3 inches around it. I switched to the jig saw and it worked a lot better, just had to get a little creative in avoiding the pipe inside.
    Put the plate in. I used these random screws I found in the basement to keep costs at a bare minimum (plus it was Sunday and the hardware store was closed). They came out of some door hinges at some point.
    And I gooped it up. I put a bead on the plate before I put it in, then I globbed it on on the back side.
    Then I re-installed it
    Open
    Closed
    I think i might not have cut the hole quite big enough. The plate spun in and out really easy when I got it, but now that it's installed It's a pita to get to spin in. I think the hole is too small and I tweaked the ring when I jammed it in.
    I've also noticed an annoying whistle that I'm assuming is coming from the hole that's right at 40 mph. Has anyone else noticed this?
    AND
    Do the 4 bangers have 2 silencers? I'm assuming this is one:
    I didn't see the other kinda hook shaped one under there.
    I took pics with the intention of doing a write up for the 4 cylinder air box, but do you think it's worth it? I'll do it if anyone thinks it'll be helpful, but I don't know if it's different enough from the 3.4 to be worth it.
    Next, I put in a 2 piece Carriage Works billet grille i found on craigslist and bought for $30. It wasn't really on my "to do" list of mods, but for 30 bucks I couldn't afford not to.
    For some reason, I decided to do this on the coldest day of the year. That's just snow and ice on the bumper.
    Here is a before (kinda a bad pic, but it was in the garage)
    After much staring at it and scratching my head, I got the grille out (once I figured out that the corner lights had to come out it was pretty easy, you just gotta pull the right way and it slides right out)
    Then I masked it off and cut the old grille out. I'd definitely mask it off and leave the tape there until the grille goes back on the truck. When I brought it inside the snow started to melt off and the tape kinda got wet and fell off. I then nicked it with the dremel and pissed myself off. It isn't bad, but it still made me angry.
    Then I put the new grille in (after realizing the shell was upside down in the last pic :eek:)
    And I put it back on the truck and put the lower piece in.
    I think it kinda looks funny since it's the only thing thing that isn't stock. I think after a couple more mods it'll really look good, it's just a case of "wrong mod first".
    Anyway thanks for looking and thanks for any help you can give me on the whistle/silencers.
  2. Jan 27, 2010 at 6:42 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    good job man! never noticed a whistling sound with my deck plate mod. i took my silencer off, the one u have a pic of, & put a 3 liter bottle cap in its place. i drilled 2 small holes in the cap & stuck a piece of aluminum wire thru it & bent both ends of the wire, then stuck it in & tightened the clamp. never had a problem with it!
  3. Jan 27, 2010 at 6:47 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Nice job Matt :thumbsup:
  4. Jan 28, 2010 at 1:45 PM
    MowTaco
    Kansas
    Thanks
    So is this the only silencer? I haven't looked again since I did it, but I will in a minute when I go out to measure for the cap. I gotta go to the hardware store and figured I'd get a cap for the silencer while I'm there.
  5. Jan 28, 2010 at 3:03 PM
    MowTaco
    Kansas
    Ok, I looked around and didn't see anything anywhere else. here's what I came up with for a cap:
    It's a rubber stopper like the ones that go on the end of a crutch or cane. Is this what everyone else did? Or did you guys just cap off the box and put it back in? It looks kinda flimsy, but it's pretty solid and I gave it a good yank and it's not going anywhere. Should I leave it as is or did someone find a better plug?
  6. Jan 28, 2010 at 6:49 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    ill try to take a pic of mine for ya tomorrow!
  7. Jan 28, 2010 at 7:56 PM
    MowTaco
    Kansas
    Well that would be just dandy :D
  8. Jan 29, 2010 at 4:13 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    here ya go man, if ya need me to take the cap out & take pix of it, i will!
  9. Jan 29, 2010 at 4:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Looks great!
    Keep an eye on that plug. When I tested my 2.7 without it, the pipe cover I used to block the hole fell out a few times. If it does this, you will be sucking in unfiltered air. I found no gains, so just put the factory peice back in.
  10. Jan 29, 2010 at 4:31 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    cool man, thanks! that was the cheapest thing i could think of, ive had it in with no adjustments so far, for about 6-7 months!
  11. Jan 30, 2010 at 11:56 AM
    MowTaco
    Kansas
    I've noticed a lot better sound out of it at all rpms when I get on the gas without the silencer box on. I will keep an eye on the plug. I have two and I guess if they both fall out I'll but the box back on.
