My OBD2 won't communicate with my truck but Autozone's does
Discussion in '1st Gen. Tacomas (1995-2004)' started by cstick6, Dec 27, 2021.
  1. Dec 27, 2021 at 10:18 AM
    cstick6
    cstick6 [OP] New Member
    Christopher
    1999 Toyota Tacoma SR5 4WD
    Lift Kit
    My Ancel AD310 scanner bombs out about half way through attempting to connect with my 1999 Toyota Tacoma SR5 4WD truck. I took it (truck) to Autozone and their scanner worked flawlessly. Also, I tried my scanner on my other vehicle, a 1996 Lincoln Town Car and it works fine. I changed the 10amp fuse in the fuse box under the hood. I can't figure this out. If Autozone's scanner works that tells me that there are no issues with the trucks wiring and if my scanner works on my Town Car that tells me that the scanner is working ok. What could be preventing the scanner from connecting to my truck?
  2. Dec 27, 2021 at 10:34 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Poor connection between your device and the truck .
    Might be some corrosion might be how the pins and sockets mesh
    Your device works on your other vehicle Auto Zones connects to your Truck
    Logic says it is in the connection.
  3. Dec 27, 2021 at 1:14 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Not familiar with the handheld models but is it possible it doesn't support the protocol?
    Wulf likes this.
  4. Dec 27, 2021 at 1:22 PM
    Glamisman
    Glamisman Well-Known Member
    that scanner is an entry level scanner and as such, it probably doesnt have the communication protocol that your Tacoma uses. I looked on the Ancel website and they dont list anything in the specifications tab. OBDII is a “general standard” interface but the function of the pins and the software is different sometimes from year to year and manufacturer to manufacturer.
    couldn't find this when I originally posted.
    https://www.scantool.net/blog/which...tly, ISO15765-4/SAE J2480 (a "flavor" of CAN).
  5. Dec 27, 2021 at 1:24 PM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
  6. Dec 27, 2021 at 2:19 PM
    Bivouac
    i hav
    I have the same model for a few years now it connects fine to my OBII vehicles. it worked for my 2017 Ford F550 with the Can systems.
    Then I have had to do some cleaning and replacing of pins over the years.
    It lives in the Truck I have never had a code trip I could not read.
    It is a simple code reader of course it does not read ABS or Transmission codes nor real time data.
  7. Apr 14, 2024 at 12:25 AM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    I Realize I’m posting in a 3 year old thread but came across this issue today on my own and had been troubleshooting. I have had this Ancel for a while and it’s worked in my 99 4Runner and in my crawler w a 5vz and 97 4Runner Ecm. It will not however connect to my 99 5vz Tacoma. Fuses good, connections appear good. Truck functions normally I don’t suspect an ECM issue. Just curious what the difference is. Port has power and screen cycles through protocols attempting to connect but can’t sync up with the truck for some reason. Times out after maybe 4 different protocols over 30 seconds then presents a failure message. Going to fiddle with it a bit tmrw.
  8. Apr 14, 2024 at 8:28 AM
    Glamisman
    Just my 2 cents worth...
    Not all scan tools are compatable with all vehicles, thats just how it is. Even professional level scan tools have issues, case in fact. I am working on a few project cars, one is a 2005 BMW 330Ci and the other is an 2003 Jeep Cherokee. My Snap On Verus misidentified the BMW, using the auto ID feature, on the BMW. It stated that it had the 2.5 motor when I know it has the 3.0. The same tool did not pick up the Crankshaft position sensor code on Jeep but my older Snap On Solus Edge worked correctly on both. I reached out to some people here on the board and they confirmed that sometimes certain tools just dont work on certain brand vehicles. I am glad that I had a feeling to switch tools to verify what my gut was telling me otherwise I might have gone down a different diagnostic path and who knows how much time that would have wasted. I tried both OBDII and manufacturer specific scan too. By the way, my BlueDriver got both diagnostics right, that is a $100 tool vs the thousands into the Snap On ones. Dont get me wrong, the Snap On scan tool(s) are great and they do things that the $100 tool cant, like synch the cam position sensor to the crank sensor on the Jeep which was part of the problem.
