My Off Road Worthy 5x8 Camper Build
Discussion in 'Other Builds' started by jmanscotch, Sep 25, 2018.
  1. Oct 3, 2018 at 11:10 AM
    jmanscotch
    jmanscotch [OP] Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Overall it pulls great. The Taco isn't a towing king, so I do notice the 1,500# back there, but not in any abnormal bad way. The best gas mileage I've achieved in two years of owning my truck has been towing this trailer. I contribute that to driving and shifting my automatic manually to keep it out of OD though.
    No wind issues whatsoever, I'm glad I cut it down those 8". It doesn't seem to have excessive drag and isn't shaken by passing semi's or even some strong crosswinds we get in the mountains here.
    The only complaint is the tongue weight needs to be a bit lighter. Right now I'm sitting around 250# and would like to see it closer to 150#. I can feel it weighting down the rear leaf springs on the truck pretty good. Bumps for the rear axle are a little more rough.
    Slashaar and TacoRD16[QUOTED] like this.
  2. Oct 4, 2018 at 5:13 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    love the jack and shovel mount
  3. Oct 4, 2018 at 5:21 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I've read all through this. Love the build. I didn't have the nerve to do all the interior stuff so last year we bought a micro off road camper just the basic version but it allowed us to start camping rt away. It seems I've been modding ever since and still a ways to go. I've done several of the mods you have with the front frame except I built a large steel box to house the fridge and for storage. Cool work I think I have more fun modding this than the truck. Welding and fabrication is a large paart of whakt I do so I kinda went a little bonkers so far but it is suiting our needs perfectly. Next is wheels tires and suspension I wanted to get it to where we could be self sufficient off road first
  4. Oct 15, 2018 at 10:10 AM
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Pretty much finished the rear door finally. I ended up reusing some aluminum sheet from the old doors instead of the sheet metal, all to save weight. I initially didn't go this route because reusing the aluminum meant it'd have some holes in it and would have to make out of three pieces, but I needed to trim some fat and the ole lady said I couldn't spend any more mula right now to get it done, so it'll work for now. I may redo it down the road, for cosmetic reasons. All in all, it came out ok. I covered two large holes with a license plate relocation and have come stickers coming that'll cover two more large ones.
    I used some liquid nail around the exterior edges, some self tapping black screws along some of the frame and some clear caulk on the inside edges to adhere the skins to the door frame.
    Door skinned, all flaws in the aluminum are visible :/
    Clamping everything together for it to cure in place.
    Weather seal installed.
    Had to move the rain rail up a bit to clear the door effectively, also here's the shelf up/done.
    Stove on the shelf
    Took it out this weekend for some 10 degree camping
    Next up: figuring out a 90 degree door stay to keep it open and wiring up the license plate light after relocating it.
    Jake
  5. Oct 22, 2018 at 8:30 AM
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    Awesome build man! From the looks of it you do great work.
    jmanscotch[OP] likes this.
  6. Oct 22, 2018 at 7:24 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Good looking trailer. You sir have some skills to chop 8" OUT of it. Not to mention all the other work you did.
    Where did you get your wheel adapters? I would like to change my 5x8's wheels out to match my truck wheels.
    adventureclassicsla and Casper66 like this.
  7. Oct 22, 2018 at 8:08 PM
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Thanks, it was just a lot of planning and a good amount of measuring twice, three and sometimes four times before cutting!
    These would be the ones I purchased, from seller “lugnutguys” on eBay https://www.ebay.com/itm/2-Wheel-Ad...951687?hash=item48a0e42587:g:tZgAAOSwpgNZjfYB
    The biggest negative is they come 2” thick as a minimun, due to the fact that the 5x4.5” lugs existing in the same real estate as one or two of the 6x5.5 lugs, so the 2” thickness provides the clearance with these specific lug combo.
    Jake
    Casper66 and Bigdaddy4760 like this.
  8. Oct 23, 2018 at 3:03 AM
    POOLGUY
    JEFF
    ALABAMA
    jmanscotch[OP] and Casper66 like this.
  9. Oct 23, 2018 at 3:26 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Nice rig :popcorn:
  10. Oct 23, 2018 at 10:12 AM
    Dctaconny
    Dctaconny Well-Known Member
    Don
    Watertown, ny
    2021 T4R sr5p
    Read through the whole thread. Very nice
    jmanscotch[OP] and Kolunatic like this.
  11. Nov 16, 2018 at 10:47 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Nicely done op
    Kolunatic and jmanscotch[OP] like this.
  12. Dec 11, 2018 at 1:40 PM
    TexasTaco4x4
    TexasTaco4x4 Well-Known Member
    Cliffton
    2017 Tacoma TRD 4x4 Sport 6MT
    Saawweeeeettt!
  13. May 22, 2019 at 6:26 PM
    Moose256
    Moose256 Well-Known Member
    2018 Tacoma TRD Off Road
    :thumbsup: Nice build.
  14. May 22, 2019 at 6:30 PM
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Amazing!! Looking forward to more updates!
  15. May 22, 2019 at 6:51 PM
    #35
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    I was getting excited about starting back on this build, but our house plans have surprised us and instead of closing on our house in the fall (buying from a friend) it’s moved up to June. So unfortunately, very little will probably happen this summer. House to buy in June, I’ve already promised the fiancé a new kitchen, floors, master and more, so remodeling to ensue through July and August, then our wedding in September.
    That said, I WILL FINALLY HAVE A GARAGE to work in! So tinkering through the winter will be an option.
    I’ll update if things happen, but we’ll probably have to wait for winter for anything significant fellas.
  16. Oct 18, 2019 at 12:03 PM
    #36
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    No major updates yet, but with winter closing in and the house remodel almost done, work will be starting again soon. Plans to finish the inside built and equip it with all the electric stuff and just generally button her up.
    For now, some pics of us our enjoying Colorado and the trailer this summer.
  17. Oct 18, 2019 at 6:23 PM
    #37
    POOLGUY
    JEFF
    ALABAMA
    How are the wheel adapters holding up? Have you had any issues with the axle?
  18. Oct 18, 2019 at 8:19 PM
    #38
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    I actually just checked it all over (bolts, connections, etc) a few weeks ago, before our last outing to Ouray, CO. Zero issues with anything really.
    Spacers and all lugs are still tight, axle is secure and in good shape (not surprised with the Dexter axle).
    Only things I noticed were a couple spots needing touch up paint and I lubed the lock-n-roll a bit with 3in1 oil so it’d rotate a little smoother.
    A wood screw, that holds the interior door trim ring on, worked loose so I’ll have to fix that. Everything else has held up great to the off-road abuse!
    Jake
    POOLGUY[QUOTED] likes this.
  19. Oct 18, 2019 at 9:17 PM
    #39
    POOLGUY
    JEFF
    ALABAMA
    That’s good to hear.
  20. Jan 28, 2020 at 8:40 PM
    #40
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Sold the Tacoma today...nearly 4 years ownership, which I know is nothing to some, but is monumental to me! I’m on my 43rd vehicle at mid-30 years of age...so I do get bored and go through them a lot and the Tacoma served me very well. Beat my old ownership record by 2 years lol.
    No progress on the trailer, still finishing house projects and now I’ve gotta find a new off road hauler...I’ve got some leads though and will update as soon as I have something.
    Cheers
    ChamYota likes this.
