My oil filter is stuck in a Tacoma2004
Discussion in '1st Gen. Tacomas (1995-2004)' started by flyboyaviator, Oct 18, 2016.
  1. Oct 18, 2016 at 2:10 PM
    flyboyaviator
    flyboyaviator [OP] New Member
    2004 Tacoma white
    none
    I've tried every type of oil tool and the f******g filter doesn't budge, do the filter turns counter clock wise for removal?
  2. Oct 18, 2016 at 2:12 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    yes counterclock wise, reach thru the wheel well
  3. Oct 18, 2016 at 2:12 PM
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
    yes, counter clock wise. Punch a screw driver in the side of it and use that to twist it off.
  4. Oct 18, 2016 at 2:16 PM
    flyboyaviator
    2004 Tacoma white
    none
    Thanks, will try that, what a PITA.
  5. Oct 18, 2016 at 2:18 PM
    gearcruncher
    Canadain bumper technician
    Righty tighty lefty loosey :)
    Have been down this road before . Sometimes even the screwdriver trick doesnt work , but defenitely worth a try.
    When installing the filter " hand tight " only . Dont use the filter wrench to install
    presta24 likes this.
  6. Oct 18, 2016 at 2:20 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Channel locks or screwdriver (like mentioned above). And couterclock wise. Good luck.
  7. Oct 18, 2016 at 2:24 PM
    copernicus
    copernicus Well-Known Member
    Sure you aren't grabbing a shock or something?
  8. Oct 18, 2016 at 2:29 PM
    TucTaco520
    TucTaco520 Well-Known Member
    Phil
    It's a dry heat
    11 Hooptie
    OME 90000s+887s, LR UCAs. AllPro Expos + 5100. KM Fab hybrid sliders w/kickout. KM Fab bed rack. 48" hi-lift. 16" FJ Trail Team wheels. 285/75/16 Hankook Dynapro ATMs. Magnaflow cat-back. K&N filter. TRD short-throw shifter. Murdered out via plasti-derp front grille and rear bumper. LED interior. De-badged tailgate. Rock lights (7). G2V 3x2 ditch lights.
    Oil filter wrench? just a bigger version of channel locks that have always done the trick for me. Squeeze hard enough and it'll puncture the filter a bit ensuring a tight grip on it.
  9. Oct 18, 2016 at 9:17 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I had one stuck so bad that it disintegrated after I punched through it with a screwdriver and tried to turn it. Ended up removing the entire filter unit, putting it in a vise, then busting the old one loose. I use the proper size oil filter socket now, which works every time.
  10. Oct 19, 2016 at 3:36 AM
    Indy
    Indy Master of all I survey.
    I had the same result the one time i punched through one with a screwdriver. A stuck filter sucks but not as much as a massive oil leaking paperweight with razor sharp sheet metal where the filter used to be.
    ajm likes this.
  11. Oct 19, 2016 at 3:44 AM
    Clearwater Bill
    Billy
    Largo Florida
    ramonortiz55 likes this.
  12. Oct 19, 2016 at 7:43 AM
    presta24
    chris
    Cincinnati
    OP, did you get it?
  13. Oct 19, 2016 at 1:40 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yeah, I had to do this last oil change. I need to be a little less gorilla with the "hand tightening".
    Apparently after the gasket contacts the mating surface you're supposed to do no more than 3/4 turn beyond that
    opteron likes this.
  14. Oct 19, 2016 at 1:47 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    A smear of oil on the gasket has been recommended in years past.
    opteron and TucTaco520 like this.
  15. Oct 19, 2016 at 2:12 PM
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
  16. Oct 19, 2016 at 2:34 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    I've got some harbor freight strap wrenches which are a life saver for times like these. Rarely crush the filter and can be used in several other ways as well (Opening jars of pickles or paints and things like that).
    blind cowboy and FARNORCAL like this.
  17. Oct 19, 2016 at 4:03 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just who put the filter on ??
    Since It does not say what engine I have never seen the new 4cylinder engines .
    Just curious how does one fill a horizontal filter with oil ??
    I have been putting filters on and taking them off by hand far to long to think about
    FirstGen Jer, opteron and FARNORCAL like this.
  18. Oct 20, 2016 at 2:21 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You don't necessarily fill it with oil, but you can "prime" it, by letting the filter media soak in some oil. 1/4 quart or less is enough
  19. Oct 20, 2016 at 2:24 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    FirstGen Jer likes this.
  20. Oct 20, 2016 at 2:29 PM
    erik530195
    erik530195 Instagram: @toyota_vintage
    2003 Tacoma Prerunner Double Cab TRD
    A.R.E. Bed Cover; Upgraded fender flares; PA System; spotlights on tow hitch
    Open the oil filler cap. May be pressurized?
