My Opinion & Thoughts: 6AT vs 6MT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KY_Rob, Oct 9, 2022.
  1. Dec 4, 2022 at 1:35 PM
    #41
    tacomadome
    tacomadome Well-Known Member
    I just upgraded from a 2005 TRD OR 6MT to a 2023 TRD OR 6MT. My impressions are:
    * The new motor is just fine, and in fact seems harder to lug than the 4L
    * The transmission feels identical, but the final drive feels taller.
    I actually think on the stock vehicle, the final drive is too tall off the lot. It probably only gets worse if you put larger tires on. 6th gear is a true overdrive gear now, and not useful until 75mph. I will probably regear the final drive once the warranty runs out, but run stock tires and leave it alone for a few years.
    While I feel the final drive is too tall, its only by a smidge, and I am loving the truck.
    Canadian Caber likes this.
  2. Dec 4, 2022 at 1:46 PM
    #42
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    There are certainly pros and cons to the 5th and 6th both being ODs, and while a lot of people claim 5th is useless, it’s actually pretty useful for cruising at a reasonable rpm when 6th feels too tall. Whereas if 5th had been 1:1, you’d be dropping to the equivalent of 4th which would make for better passing power (while only shifting one gear) but not enjoyable to cruise in long range as an alternative to a too-tall 6th scenario. So pros and cons for sure, but 6th being tall sometimes is what makes 5th great, because it’s still a highway speed ratio that has more power without revving unnecessarily high.
    econwatch likes this.
  3. Dec 4, 2022 at 1:53 PM
    #43
    tacomadome
    The fact that reverse feels too tall gives me the impression this was not a well thought out decision, it feels like they just took the purposefully geared 6MT from the 2nd gen and slapped a taller final drive on it. Nobody has ever wanted two overdrives on an off-road vehicle, it doesn't make any sense. I'm not arguing that 5th is useless, but having spend over 10 years driving the 2nd gen, it felt geared more thoughtfully than this one does. I will say, there were times in the city with the 2nd gen where it felt like the crowded lower gears forced me to row a bit much.
  4. Dec 4, 2022 at 2:08 PM
    #44
    BLtheP
    Plano, TX
    See I don’t know where any of that comes from, because actually the 2nd gen and 3rd gen 6MTs are geared about the same once their final drives (3.73 vs 4.30) are taken into consideration.
    2nd gen (3.73 axle ratio)
    1 - 4.17 X 3.73 = 15.55 final ratio
    2 - 2.19 X 3.73 = 8.17 final ratio
    3 - 1.49 X 3.73 = 5.56 final ratio
    4 - 1.19 X 3.73 = 4.44 final ratio
    5 - 1.00 X 3.73 = 3.73 final ratio
    6 - 0.84 X 3.73 = 3.13 final ratio
    R - 3.61 X 3.73 = 13.47
    3rd gen (4.30 axle ratio)
    1 - 3.98 X 4.30 = 17.11
    2 - 2.02 X 4.30 = 8.69
    3 - 1.32 X 4.30 = 5.68
    4 - 1.00 X 4.30 = 4.30
    5 - 0.85 X 4.30 = 3.65
    6 - 0.71 X 4.30 = 3.05
    R - 3.39 X 4.30 = 14.57
    Overall the first three final drive ratios in the 3rd gen are slightly shorter (higher rpm) and the last 3 are slightly taller (lower rpm), but not by much. On the highway in 6th, a stock 2nd and 3rd gen will be within 90 rpm of each other at highway speed. 70 mph should be 2525 rpm in the 2nd gen, and 2435 rpm with the 3rd gen.
    Reverse is better/lower on the 3rd gen than the 2nd, but it still sucks.
    I’m not really sure what 2 ODs has to do with offroading, because most offroading happens in the lower gears. As shown in comparing ratios, even though the 2nd gen didn’t have 2 ODs, the way it was geared in the axles made it where the rpm and final ratios were about on par with the 3rd gen, because the 2nd gen only has a 0.84 6th.
    I think what you are feeling different between the two is the more powerful 4.0L.
    TexasG and tacotoe like this.
  5. Dec 4, 2022 at 2:27 PM
    #45
    tacomadome
    Good info on the ratios. My point on the location of 1:1/overdrive is, if you have 6 gears, and draw the line of 1:1 at 5th, that gives you 4 "underdrive" gears for offroad towards the low end, vs with 1:1 at 4th, you have two "highway" gears.
    The differences in feel don't line up with the ratios as listed but the math doesn't lie. I could just be accustomed to the old ratio and complaining about nothing. I do recall on the 2nd gen 1st gear being nearly a crawl-gear vs 1st on the 3rd gen feeling a lot more useable on road, but the ratios don't agree with me.
  6. Dec 4, 2022 at 2:32 PM
    #46
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Why? it's not the tires.
    Junkhead likes this.
  7. Dec 4, 2022 at 2:33 PM
    #47
    BLtheP
    Plano, TX
    I think it’s probably a few things, one being the engine and one being the tune, and just overall different sounds from each and such. The stock 3rd gen tune feels very padded in the throttle, basically meaning that you have to push the pedal really far to get any acceleration out of it. So the 3rd gen to me felt like the gearing was taller even though it wasn’t. Once I got my truck tuned it felt a lot different in that aspect. The numbers between each gen are pretty close, yet they still feel quite different.
    I do get what you’re saying about where the 1:1 is, and how many highway gears you have, although honestly the 2nd gen still kind of has two highway gears. It’s 5th gear 1:1 with 3.73 axle ratio nets about the same final ratio as our 0.85 5th on 4.30.
    but anyways, I do think most of what you’re feeling is just differences in the engine management and the motor vs the actual gearing ratios.
  8. Dec 4, 2022 at 2:45 PM
    #48
    Gamma11
    Gamma11 ((‘)) yea, i like the taste
    Andrew
    Northeast
    2024 DCLB OR Bronze Oxide, 2022 T4R ORP Super White
    said no one ever
    tacotoe likes this.
  9. Dec 4, 2022 at 3:22 PM
    #49
    slippinjimm
    slippinjimm Active Member
    Wyoming
    2006 Silver Tacoma TRD
    ATC TOPPER 2.5 Kings /TCA Upper Control Arms 285/75/16 Mickey Thompson Baja AT’s 2nd Gen Headlight Upgrade
    I
    have
    Have either of your tried 4 Low in 1st yet? The 2nd gen really did crawl in that sense. I am really curious how well it do on a few hills I need to climb to get to my elk hunting spot next fall.
  10. Dec 4, 2022 at 3:24 PM
    #50
    BLtheP
    Plano, TX
    They both have the same transfer case, and the 3rd Gen Has a slightly lower final drive ratio in 1st gear, if both trucks are stock. So, the 3rd gen theoretically should have a better crawl ratio. However, the actual feel may vary depending on the engine.
    slippinjimm[QUOTED] likes this.
  11. Dec 4, 2022 at 3:42 PM
    #51
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    My experience has been that if I lug my truck and if Im doing it on certain terrains , it seems confused. If I just drive it with purpose , I experience zero issues. These motors like to be revved a bit. And the transmission will act accordingly.
    2Nice, TacomaGuy7878, TexasG and 2 others like this.
  12. Dec 4, 2022 at 3:50 PM
    #52
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Re: "302" Ummm-Ummmm-Ummmmmm.... I had that engine in the first new car I ever bought. What an engine. (I'm not going to reveal the year: sorry! Any knowledgeable Ford fan can do the math. :rolleyes: ) Anyway, I talk cars with my nephews and nieces all the time, especially trucks, and when the "5.0" comes up in conversation, I never fail to translate it into "the 302"....... ....returned by blank stares, confused looks, and silence. I make it worse by casually slipping "289 grandchild" into the discussion. Fun stuff and adds to the conclusion that "uncle is slipping" is running through their minds. Next time we're all together for Christmas, I'll have to make it a point to work " the Ford I6 into the conversation and then add a "4.9" liter reference. They won't know what to do. :D
    TexasG and Horseshoez[QUOTED] like this.
  13. Dec 4, 2022 at 3:57 PM
    #53
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Idk why so many rag on the auto in these trucks. I've found mine to work as good, or better than my gen1 tundra. All shift points happen spot on vs the road conditions. No hunting like it did for the first 1k miles or so. Truck has plenty of pep right off idle, not at all sluggish like a buddies v6 tacoma that he had. Just the other day pulling into traffic off the on ramp onto the highway, it felt just as strong off the bottom as my old v8 tundra.
  14. Dec 4, 2022 at 4:15 PM
    #54
    sethstacoma
    sethstacoma Well-Known Member
    Seth
    2022 Toyota Tacoma TRD O/R 6spd manual.
    Only the hybrid versions have planetary gears the regular gas models come with a belt and pulley!
  15. Dec 4, 2022 at 5:29 PM
    #55
    InThePlains
    InThePlains Well-Known Member
    Shouldn't it be the RPM divided by the diff gear ratio to get the final gear ratio?
    Higher the diff ratio, lower the speed, higher the torque. That's why people regear to taller gears to drive bigger tires.
    Maybe i'm wrong.
  16. Dec 4, 2022 at 7:09 PM
    #56
    slippinjimm
    Wyoming
    I am 29
    I will report back, I hope this one likes to eat just as much as the last one.
  17. Dec 4, 2022 at 7:11 PM
    #57
    slippinjimm
    Wyoming
    I tried all over the place. Check weekly next allotment comes out tomorrow. Grand Junction Colorado and New Mexico. I picked up mine in Idaho. If any dealers give me a call on one this week I will shoot you a DM
  18. Dec 8, 2022 at 1:31 PM
    #58
    hafjell
    hafjell Well-Known Member
    Idaho
    2023 TRD OR MT
    Thank you. I live in ID but couldn’t buy one in Lewiston because I was out of market.
    Have a deposit on one on the lot in WA. Should be able to pick it up on Monday if this snow doesn’t reroute every plane west of the Mississippi.
    487 mile drive from dealership to home. Anything I need to know? Don’t drive too fast? Is that a thing anymore? Thanks again.
  19. Dec 8, 2022 at 1:50 PM
    #59
    tacomadome
    During the first 1000 miles you are supposed to vary engine speed, so no cruise control on the way back haha
  20. Dec 8, 2022 at 1:54 PM
    #60
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    noticed that with about 500 pounds of weight in my bed my truck shifted much better (automatic). no more gear hunting or upshifting to 6th gear at every opportunity. seemed to shift a lot better after driving on the highway for an hour...maybe it still had some learning to do as i don't typically drive on the highway. drove like a dream on my camping trip this past weekend. really surprised me. the suspension also felt a lot better. I think my truck was designed to haul weight so it drives like crap when empty. I have the SR utility package which is the typical fleet vehicle.
