My P11EE CEL at 41k miles on 2018 OR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hemlockz, Apr 4, 2024.
  1. Apr 4, 2024 at 12:25 AM
    hemlockz
    hemlockz [OP] Well-Known Member
    24 Bronze ORP 6MT
    Reading this forum on this problem sounds like the same 'burnt valve' symptoms. Its very concerning! I'm in the unfortunate position to be in the 6th year since the truck was new, so I've just missed that 5 yr/50k mile warranty period. I am the 2nd owner and had it since 21k miles.
    I was just driving around town this evening and noticed the CEL come on about 10 minutes into my errand. I stopped in to the Autozone and checked the code, they said 'oh, it says new head gasket, thats expensive' :facepalm: I cleared the code, and it came back about 10 miles later.
    Thing is the engine is running like normal. I've been getting around 17/21 mpg with no problems. Last weekend I took a road trip and it was running well. The only thing I've done is ran about 9 gallons of cheap gas with a bottle Techron through the fuel system last week, and then filled up with 92 octane on Friday to see if I noticed any mileage differences on the road trip. So my optimistic side is thinking maybe somehow this code was related to the techron and premium gas (which I've never done either on this truck in the 2+ years I've had it...) and not the valve seat issue.
    I'm going to take it in to the dealership where it was originally purchased from, and see if they can diagnose it and rule out a valve issue. maybe get the fuel pump replaced on the recall. It was a corporate truck before I bought it, and it was always serviced at a dealership so maybe they'll show some mercy on me if it's a major repair.
    Okay thanks for reading, I will post the results when I know more.
  2. Apr 4, 2024 at 4:16 AM
    windyhill
    windyhill Active Member
    2019 Tacoma TRD
    None.
    Damn these threads are disconcerting. Hope it works out for you.
    turbosnail likes this.
  3. Apr 4, 2024 at 6:25 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    They should have an extended warranty campaign for this issue for those who are out of warranty. People buy the tacomas for reliability for these things not to happen. I’ve seen people post where the bill to do this job could reach $10000.
  4. Apr 4, 2024 at 7:23 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Sorry to hear. Fingers crossed, though I have never seen this issue NOT be replaced with a new cylinder head and new valves on the affected ones. What is your driving style? Automatic trans I assume?
  5. Apr 4, 2024 at 7:59 AM
    hemlockz
    24 Bronze ORP 6MT
    Yes an AT. I would have gotten manual if it were available on the 4 door model. (The reason I traded my 1st gen is because I needed a 4 door for the family.) Driving style is usually pretty conservative, but I have been flooring it recently with the techron tank.. italian tuneup style.
    BLtheP[QUOTED] likes this.
  6. Apr 4, 2024 at 8:15 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    clear the code and trade it in.
  7. Apr 4, 2024 at 4:03 PM
    hemlockz
    24 Bronze ORP 6MT
    UPDATE- I dropped it off at the dealership. Its going to take a couple of days to diagnose. $189. (I'm 9 months out of the 5-year warranty.)
    They asked me if I had brought it there before, maybe checking if I'm loyal. It is the original dealership that sold my truck to the previous owner. They had last seen it in 2021 just before I bought it. But I never needed service so never brought it there. The oil changes at the dealership are double the price and take a lot longer than my local lube shop that I've been going to... I think they were asking to see if I am loyal but obviously I'm not. He checked my gas cap though and said it was fine...
    Sand_In_My_Taco likes this.
  8. Apr 4, 2024 at 4:37 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    BEJEEZUS !!
  9. Apr 10, 2024 at 2:18 AM
    hemlockz
    24 Bronze ORP 6MT
    Finally got the results of the leak down test. Cylinder 3 is 140-145 PSI, compared to 200 psi for Cylinder 1. So I have like a V-5 and 3/4 instead of a V-6 now?
    They wanted to open it up and inspect the injector or valve, but I needed the truck back it's my only vehicle. I'm going to keep driving it and hope maybe some carbon is just stuck in the valve seat and will work its way out... and if not I'll try and get a big trade in credit from a dealership and get another truck. The service center said their next step would likely be a new cylinder head. :jerkoff:
  10. Apr 10, 2024 at 5:31 AM
    eggs
    eggs Well-Known Member
    Beersconsin
    2017 TRD O/R
    <--- this 2017 had the same with cylinder #1 at 35,000 and 2.5 years into ownership. Might as well bite the bullet. They had mine for 3 weeks so maybe you could find a month long rental. Good luck.
  11. Apr 10, 2024 at 8:55 AM
    hemlockz
    24 Bronze ORP 6MT
    Great you were in warranty, I'm 8 months out of it. Lot harder to bite that bullet.
  12. Apr 10, 2024 at 10:41 AM
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    If they aren’t gonna help with the cost at all I’d run it & install an engine out of a wrecked truck if it ever fails catastrophically.
    I’ve put over 100k miles on mine since my first p11ed code, still runs.
  13. Apr 10, 2024 at 11:25 AM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    If you live anywhere near Chicago call up the car care nut. Bonus if you have AAA you can just have it towed to his shop if you are within 200 miles.
  14. Apr 10, 2024 at 1:39 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    :jerkoff:
    Chew likes this.
  15. Apr 10, 2024 at 1:57 PM
    Hogan1966
    Hogan1966 Well-Known Member
    Kevin
    Loveland, OH
    2021 DCSB TRD OR - Army Green
    Blackout package - planned: black bed logos, black wheel vinyls, front seat window tint, tires.
    This is the first I've read of this issue, but it sounds like it might be prevalent. If so, I would call Toyota corporate and ask for relief for the repair.
    They may not cover it all, but they might pony up something. I got over half of a $2500 transmission repair from Subaru just for taking the time to report and ask them to take care of an issue that was pretty prevalent across the make, model and year of my son's car. The car was 1 month and 10,000 miles out of the extended warranty and they paid up.
    Worth the effort before you pawn off a problem to some unknowing schmuck.
    ToyodaSun likes this.
  16. Apr 10, 2024 at 2:20 PM
    ToyodaSun
    Parts Unknown
    17' DCLB TRD OR
    If you do not ask you shall not receive. The worst they can say is no. I agree, worth a phone call.
    Hogan1966[QUOTED] likes this.
  17. Apr 14, 2024 at 10:14 PM
    hemlockz
    24 Bronze ORP 6MT
    So I cleared the code and have ran through the rest of my gas and a new tank of 87 octane, and the light has stayed off about 500 miles so far. Haven't done a new leak down so I don't know about the cylinder. knock on wood it was just a fluke.
    Pwakchop likes this.
  18. Apr 15, 2024 at 11:56 AM
    Pwakchop
    Pwakchop Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    Great news!
  19. Apr 19, 2024 at 1:38 PM
    hemlockz
    24 Bronze ORP 6MT
    The code came back today, after 500 miles of being off, as I was putting around town. So this isn't solved. o_O Just wanted to put that out there for future reference.
  20. Apr 24, 2024 at 4:36 AM
    eggs
    Beersconsin
    2017 TRD O/R
    I didn't want to be the one to post that it would, but it seems like there is no way this issue will go away with clearing a code, not with those compression numbers. Good luck.
