My Potential Set Up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808 Tacoma, Oct 24, 2011.
  1. Oct 24, 2011 at 3:39 AM
    808 Tacoma
    808 Tacoma [OP] Member
    SR5 V6 4x4
    Hi guys, this is my first post on TW and im excited to be a member and a proud owner of a Tacoma! So now to business...
    Ive been doing some research and I came up with a potential set up that I think would suit my taste. What I want is for anyone to give their input on what they think of the products that I have selected and/or any personal experience or even opinions. Thank you in advance to anyone that responds to this post.
    The goods:
    *3" lift kit with Bilstein 5100 Height adjustable Coilovers
    http://www.toyteclifts.com/index.ph...tegory_id=113&option=com_virtuemart&Itemid=72
    *Driveshaft Carrier Bearing Drop Kit (05 & UP Tacoma)
    http://www.toyteclifts.com/index.ph...duct_id=58763&option=com_virtuemart&Itemid=72
    *Front Swaybar Relocate Kit
    http://www.toyteclifts.com/index.ph...tegory_id=118&option=com_virtuemart&Itemid=72
    *Mickey Thompson Classic II Wheel
    17x9, 6 on 5.5 Bolt Pattern
    Backspace 5 in.
    Max Load= 3000lbs
    Finish = Polished
    Hubcentric= No
    Offset = 0 mm
    Part Number: M/T379413
    http://www.4wheelparts.com/Wheels/C...&t_s=210&t_pt=100039&t_pl=2892&t_pn=M/T379413
    *BF Goodrich All Terrain Tires
    -33's perhaps?
    (I have questions like do I need any other parts for the lift?, Would the 17's give me any problems or would they fit fine?, and also Ive heard that 33's with a 3" lift would have slight rubbing problems...so would anyone suggest a smaller tire or would i be fine?) once more thanks for any input or advice.
  2. Oct 24, 2011 at 8:53 AM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    I didn't see there what u planned for in the back?? (found it. Ur getting the kit) Get the AAL as opposed to the block.
    285/70/17 will be the tires you want. You will have some rubbing that can be taken care of by removing your front mud flaps and timming some plastic. U might have to "cab mount chop" search that term. 17's are fine although I've read you should find a wheel with backspacing 4.5 or under.
    If u want any other options search OME, and eibach.
  3. Oct 24, 2011 at 8:56 AM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    Welcome!
    Can't go wrong with Toytec!
  4. Oct 24, 2011 at 9:03 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You might want to consider new UCA's. I didn't see where you included them and they can be a fairly significant amount of money. Also, I wouldn't throw the CB drop kit on when you do the install. I'd wait til afterwards and install it if you need it. I bought one for my truck but if you look, it'll make the initial angle coming out of the transmission worse and only slightly better the angle between the CB and rear diff. Seems axle shims would be much more effective in my opinion.
  5. Oct 26, 2011 at 4:19 AM
    808 Tacoma
    SR5 V6 4x4
    Thanks for the input guys. I placed in my order with toytec and im super excited. With your responses im veering more towards a 32" tire mainly because I currently dont want anything "chopped" at least not yet lol. Also im looking more into uca's...pretty expensive but im guessing it'll be worth it in the long run.
  6. Oct 26, 2011 at 5:22 AM
    leveltwo
    leveltwo Well-Known Member
    fyi, the mickey thompson classic 2s have a sealer or clearcoat to protect the finish. do not, DO NOT use any aluminum polish or buffing compound on the wheels.. or the clear coat will come off and you will have shitty looking wheels.
    ask me how i know.
