my powdercoated 2nd gen wheels...
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, Feb 1, 2011.
  1. Feb 1, 2011 at 11:58 AM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    just got these wheels back today from powder coat. Decided to go with a flat black. seein what everyone thought about them, im pretty excited to get them on with my cooper st's right now im just waiting on my wheels spacers
  2. Feb 1, 2011 at 12:11 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Look Badass...
  3. Feb 1, 2011 at 12:13 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    I like it, but something has to be done with the center cap IMHumbleO
  4. Feb 1, 2011 at 12:16 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    the toyota emblem in the middle pops out i plan on painting them the center caps black and putting the chrome toyota emblem back in
  5. Feb 1, 2011 at 12:17 PM
    agroman2001
    agroman2001 Member
    AJ
    San Diego
    07 TRD Offroad 4x4
    Ready Lift leveling kit, Smittybuilt light bar w/ 4 Hella 500s, Grillcraft black mesh grille, painted the rear bumper plastics and Hella light covers with bed liner, custom whip mount w/ green Safeglow 200 LED whip, rear dif. breather relocate
    If you don't mind me asking. What does that cost to get them powder coated?
  6. Feb 1, 2011 at 12:18 PM
    Madjik_Man
    Boulder, CO
    ^ that'd look really sweet
  7. Feb 1, 2011 at 12:22 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    $40 a wheel, well worth it if you ask me, powder coat doesnt scratch or chip like a rattle can job or even a good paint job
  8. Feb 1, 2011 at 12:25 PM
    Madjik_Man
    Boulder, CO
    But if it does, you really have no way of touching them up.
    The only trade off IMO
  9. Feb 1, 2011 at 12:29 PM
    tguil
    tguil Well-Known Member
    Nebraska
    2015 Double Cab TRD Off Road
    Were your wheels pitted/chipped before you had them powder coated? Right now I have a problem with the wheels on my new TRD Sport. I need a little "ammo" for when I talk again with the Toyota rep.
    By the way... I do like your powdered coated wheels. May be doing the same in a couple of years...unfortunately.
  10. Feb 1, 2011 at 12:32 PM
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    wow!!!! me likey
  11. Feb 1, 2011 at 12:37 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    naw these wheels were only on my girlfriends brothers 2010 for about 2000 miles there are basically brand new so there is no chips or dings in the wheels
  12. Feb 1, 2011 at 12:45 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    im gonna paint them to match (hopefully) but i plan on leaving the chrome toyota emblems in the middle chrome plated so it will be the only chrome on the wheel
  13. Feb 1, 2011 at 1:59 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    here is a visual do give you a better idea of what im talking about
  14. Feb 1, 2011 at 2:02 PM
    trdchic
    trdchic Well-Known Member
    Longmont CO
    07, TRD Sport, 4x4, SR5, V6, Access Cab
    I did the same to mine...matte black...$55 a wheel in Vegas. Spray bombed the centercaps. I like it.
  15. Feb 1, 2011 at 2:03 PM
    trdchic
    Longmont CO
    Only issue...when I get them balanced it takes longer and I have to request that they put the weights inside so the paint doesn't get chipped
  16. Feb 1, 2011 at 2:04 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    $40 bucks is a great deal! where is visalia?
  17. Feb 1, 2011 at 2:10 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Visalia is Central Cali, between fresno and bakersfield
  18. Feb 1, 2011 at 2:44 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    forgive my edit ;)
    I had my Avid Lightbar powder coated with 3 baked coats,
    Primer, Color, then Clear.
    Came out great, but cost more than the lightbar.
    The powdercoater, who's been doing it over 20 years,
    told me it WILL still chip and scratch.
    Granted your wheels won't take impacts like the front of the vehicle @ 60mph,
    But remember it's just plastic.
    He recommended "Mothers" Mag & Aluminum Polish for Scratches
    And this is the other caveat.^^^
    I like the wheels and you got a good price.
    All in all a good choice on your part
  19. Feb 1, 2011 at 3:26 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    whoever did you bar did a good job matching the color it looks really good
  20. Feb 1, 2011 at 3:47 PM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    freakn nice man cant wait to see em on the truck
