My power windows fuse keeps blowing (D FR P/W 30A)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eliasrosarino, Mar 23, 2024.
  1. Mar 23, 2024 at 8:11 AM
    eliasrosarino
    eliasrosarino [OP] New Member
    Elias
    2013 Toyota Tacoma
    Out of nowhere the power window control from the driver's side door stopped working. All of the other window controls work for their individual windows. It's just the driver side control of all of them that doesn't work. I was able to fix the issue by replacing the D FR P/W 30A fuse. But this fuse then blows within a day of using it. The fuse does not seem to blow immediately, but after a few uses. I haven't done any electric work recently.
    What's my best bet to try to fix this?
  2. Mar 23, 2024 at 8:22 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Does it blow only when you try to move the window or when you open/close the door?
    TnShooter and Jimmyh like this.
  3. Mar 23, 2024 at 8:38 AM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    It could be the switch itself, or the brushes in the window motor could be wore out hopefully not the wires .
    another possibility could be a problem with the window crank mechanism overloading the motor
  4. Mar 23, 2024 at 12:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it blows when for an intermittent short circuit.opening and closing the door check the wires that go between the door and the body inside the rubber tube.
  5. Mar 23, 2024 at 1:31 PM
    caribe makaira
    Caribbean, Puerto Rico
    Pull the driver's side control and take closer look at connector and mating side of switch...
