my radiator pink fluid is running low
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marioso, Nov 24, 2008.
  1. Nov 24, 2008 at 7:59 PM
    Marioso
    Marioso [OP] Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    i get paid wednesday and its something i wanna do...i just dont know how...can someone help?
  2. Nov 24, 2008 at 8:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    go to the dealership and buy a gallon of toyota super long life coolant, and a new radiator cap. while engine is cold....fill to the full/cold line and replace the cap.
  3. Nov 24, 2008 at 8:41 PM
    sonjay
    sonjay Well-Known Member
    just out of curiosity, how come you say to replace the cap as well?
  4. Nov 24, 2008 at 8:46 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    You are in SoCal you don't need to worry about freezing so just add a bit of water.. make sure you have a least a 50/50 blend of antifreeze to water.. Don't add more water to the system than antifreeze.
    Thats the Cheap Fix... (the main issue is finding out why it is low?)
    The right fix is to add the correct fluid per the dealer. They might due a Free fluid check for you and let you know if you have any leaks!!
  5. Nov 24, 2008 at 8:49 PM
    Marioso
    San diego Ca
    good question...idk i just looked and saw pink residue at the bottom...tapped it and nothing moved.
    why replace the cap? and shouldnt i flush out the old and run the cleaner
  6. Nov 24, 2008 at 9:15 PM
    Marioso
    San diego Ca
    im lost sorry
