My REDARC Tow-Pro Liberty Install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pgfitzgerald, Aug 4, 2022.
  1. Aug 4, 2022 at 7:27 AM
    pgfitzgerald
    pgfitzgerald [OP] Well-Known Member
    Hi all!
    I just got done installing the REDARC Tow-Pro Liberty into my 2016 TRD Off-Road.
    I picked up the kit, which included the brake controller, a vehicle-specific wiring harness, and a universal switch insert. I didn't use the universal insert; I used the Tacoma insert instead.
    I watched some videos and came up with a game plan. The wiring harness was easy... just plugged it into the factory plug and grounded it to the factory ground stud behind the kick panel. The remote was easy too... just popped out the old insert and installed the new one with the remote. Only issue I had was that the new insert kept wanting to pop out of the dash panel. I haven't had any further issues since putting the dash back together though.
    I wasn't happy with the mounting options for the controller itself, so I designed and fabricated a bracket:
    After mounting the controller to the bracket, I bolted the bracket to the vertical portion of the airbag bracket using these holes:
    Here are a couple of close-ups of the top and bottom of the bracket/controller after it was installed:
    Couldn't be happier! Hope y'all like it. :)
    Tacoma'?, RT_VIC, Vikter and 20 others like this.
  2. Aug 4, 2022 at 7:34 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    If you get the bracket mass produced, I bet others would buy one. I used zip ties myself But would love something cleaner. Solving the design is the hard part. Nice work.
  3. Aug 4, 2022 at 7:36 AM
    pgfitzgerald
    Thanks!
    Well... I did get 10 made. It was the same price as 1. I could definitely get them made up in bulk if folks are interested.
  4. Aug 4, 2022 at 7:37 AM
    ChilliTaco
    ChilliTaco Well-Known Member
    Richard
    Alberta, Canada
    2017 AC TRD OR AT MGM
    Nice! Zip ties were the bracket I used. Where were you when I was doing this 3 weeks ago?!?!
    pgfitzgerald[OP] and daveeasa like this.
  5. Aug 4, 2022 at 1:00 PM
    REDARC_Ryan
    REDARC_Ryan Well-Known Member
    Michigan
    2021 Tacoma TRD Off-Road
    OME BP-51's, CBI Covert Bumper, Rhino Rack Roof Rack, Mits Alloy Tray & Canopy, Alu Cab RTT, Falken Wildpeak A/T, RIGID Lighting
    Great install mate, that's a clean bracket!
  6. Aug 4, 2022 at 1:04 PM
    daveeasa
    David
    PNW
    Any chance you can confirm the liberty and elite share a form factor?
    pgfitzgerald[OP] likes this.
  7. Aug 4, 2022 at 1:04 PM
    kuruma1
    kuruma1 Well-Known Member
    Can you share the design file? I can run one on the CNC.
  8. Aug 4, 2022 at 1:08 PM
    pgfitzgerald
    DXF work? If so, send me a message with your email and I'll get it over to you.
    I didn't include the countersinks on the back because the place I get stuff done doesn't offer that service. I just did them by hand on the drill press. I'm sure you could have the CNC do that for you. :)
    sil80s13 and kuruma1[QUOTED] like this.
  9. Aug 4, 2022 at 1:25 PM
    Yjcrawler
    Yjcrawler New Member
    2018 Trd Offroad
    zonzin and pgfitzgerald[OP] like this.
  10. Aug 4, 2022 at 1:28 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I believe they're identical.
  11. Aug 4, 2022 at 1:34 PM
    jmneill
    SE
    Interesting timing.
    I just pulled their mount out of my mailbox an hour ago.
    @pgfitzgerald
    If you would, outside of the fact they're highway robbery, what in particular were you not satisfied with, with the REDARC mount?
    TIA
  12. Aug 4, 2022 at 1:38 PM
    MGMDesertTaco
    That install looks pretty clean. Would you consider selling a kit with the bracket and hardware that you used for install?
  13. Aug 4, 2022 at 1:40 PM
    MGMDesertTaco
    Out of stock at the moment...
  14. Aug 4, 2022 at 1:41 PM
    pgfitzgerald
    Just felt meh about it. I wanted something that felt "purpose built" and bolted sturdily to the truck in two spots. Plus, I had been wanting an excuse to design and fabricate something. I'm sure that bracket is just fine.
  15. Aug 4, 2022 at 1:41 PM
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
    Did your truck come with the factory tow package?
  16. Aug 4, 2022 at 1:41 PM
    pgfitzgerald
    Sure, send me a message.
    MGMDesertTaco[QUOTED] likes this.
  17. Aug 4, 2022 at 1:41 PM
    pgfitzgerald
    Yes
  18. Aug 4, 2022 at 1:42 PM
    jmneill
    SE
  19. Aug 4, 2022 at 5:22 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Kudos, cleanest install I have ever seen of a Redarc.
    My only advice for an ultimate clean install, buy or make a custom length cable for the panel switch. The liberty uses regular Cat5 with RJ45 connectors in patch. Cutting and crimping the included cable is certainly an option.
    Where's the airbag by the way, is that if on the right rotated down?
  20. Aug 4, 2022 at 5:40 PM
    pgfitzgerald
    Thanks!
    Yep, I unbolted the airbag and swung it down to the right just to give me some more room to work.
