My review of 4.88s on a 2nd gen with 34s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IvanhoeTaco, Jan 9, 2021.
  1. Jan 10, 2021 at 5:31 PM
    #41
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    that’s not my understanding.. it is a mechanical LSD with locking characteristics when the brakes are engaged while accelerating.
    https://youtu.be/JXtHM5-P0s0
    https://youtu.be/lZmsY2YvVsc
  2. Jan 10, 2021 at 5:32 PM
    #42
    IvanhoeTaco
    IvanhoeTaco [OP] Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    From the video from Eaton I watched 6 pinion gears slide over the side gears and lock it.
  3. Jan 10, 2021 at 5:35 PM
    #43
    IvanhoeTaco
    Eastern NC
    I stand corrected, an lsd is NOT a locker.
  4. Jan 10, 2021 at 5:36 PM
    #44
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    It's a little different with a supercharger…both tires spin quickly.
  5. Jan 10, 2021 at 5:38 PM
    #45
    IvanhoeTaco
    Eastern NC
    That's the one things about gears...they cant add 60whp.
  6. Jan 10, 2021 at 5:40 PM
    #46
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    @IvanhoeTaco
    @JasonLee
    That’s why I am confused about the characteristics of the TruTrac in the below situation
    https://youtu.be/lA52RTjOcQw
    also as per reports and research, lightly riding the brakes should send power to both wheels by tricking the differential into thinking both tires need traction. I have yet to 100% confirm this in my applications
    IvanhoeTaco[OP] likes this.
  7. Jan 10, 2021 at 5:44 PM
    #47
    JasonLee
    15 TRD OffRoad
    Well, from my knowledge, the oil doesn't matter (you don't need the special LSD additive with the TrueTrac), so you can rule that out.
  8. Jan 10, 2021 at 5:49 PM
    #48
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    100% DONT use LSD additive. They recommend against it
    Key-Rei and IvanhoeTaco[OP] like this.
  9. Jan 10, 2021 at 5:51 PM
    #49
    JasonLee
    15 TRD OffRoad
    Yeah, so it's not the gear lube that is your problem.
    Does your parking brake work / rear drums adjusted? Maybe you have a lot of hydraulic pressure biased to the front brakes and not enough is getting to the rear, which would require you to use more brake to get the rear to lock up.
  10. Jan 10, 2021 at 5:56 PM
    #50
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Yeah parking brake works just fine. I think it was either I was going to slow and the forces were applied or I wasn’t applying enough brakes.
    i am hoping someone reading this has played with theirs more. I feel when it engages normally but I am always in the drivers seat and I can’t exactly tell what it is doing
  11. Jan 10, 2021 at 5:58 PM
    #51
    IvanhoeTaco
    Eastern NC
    Uh oh.
  12. Jan 10, 2021 at 6:11 PM
    #52
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
  13. Jan 10, 2021 at 7:14 PM
    #53
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    Lockers aside, and back to the gears, as per thread title, how's towing with these gears?? Nothing too heavy, just towing in general?? I'm sure my current mods will help in this over-revving that others always talk about, but the exhaust gears and what not. How do those help efficiency?? Better exhaust scavenging??
  14. Jan 10, 2021 at 7:25 PM
    #54
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    Nice. I’m on 4.88s (auto) and 35s. So glad I didn’t go 4.56. 4.56 would be for someone who drives their truck mainly on the highway
    IvanhoeTaco[OP] and ColtsTRD like this.
  15. Jan 10, 2021 at 7:31 PM
    #55
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Running 4.88’s with 35s and you’re right!! Best money I’ve spent on the truck yet!
  16. Jan 10, 2021 at 7:42 PM
    #56
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Any idea what the lead time from ECGS is right now? I need gears, planning on 4:88's so the experiences in this thread help reconfirm that.
    Anybody get gears and have them cryo treated and electro polished before install or does everybody buy the assembled members and just drop the chunks in?
  17. Jan 10, 2021 at 7:51 PM
    #57
    JasonLee
    15 TRD OffRoad
    I am hoping to get set up with HP Tuners to do some data logs before and after I install a set of the exhaust cam gears, so I'll let you know. I haven't heard anyone have negative feedback or even neutral feedback after installing them - with or without a supercharger.
    Key-Rei likes this.
  18. Jan 10, 2021 at 7:58 PM
    #58
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    Nice. Still wondering if 4:88's are for me given I do lots of hwy for work, and will be towing on wknds. Lots of hills in my area. I currently run long tubes, cai, upper plemum spacer, air flow sensor spacer, x-piped dual inlet single outlet exhaust, so I'm very free flowing, just wondering if I'll be screaming, or just cruising?? Either 4:88's with 35's or 37's, and or 4:56's. Currently on 305x20's and current gearing. Not the best, but I can chirp some rubber still..
    Jared8907 likes this.
  19. Jan 10, 2021 at 8:00 PM
    #59
    la0d0g
    running for the hills
    For crawling not hauling
    They're usually a week turnaround.
  20. Jan 10, 2021 at 8:04 PM
    #60
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    ProCharger supercharger will be my last costly upgrade. So maybe 4:56 will be my go to?? This way I still have some top end to to be a sleeper on the street, and blaze on the trails..
    cdex8357 likes this.
