My Right Rear Axle Seal has gone bad... I need a hook-up a.s.a.p.
Discussion in 'Southern California' started by w8n4mud, Aug 1, 2009.
  1. Aug 1, 2009 at 2:58 PM
    w8n4mud
    w8n4mud [OP] There's a mod for that!
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bilsteins 5100's (Front & Rear), GrillCraft, Line-X'ed Skid Plate & Bumper Valence, Blacked out hood scoop, Avid Light Bar and much more.
    I need help badly guys... here's the scoop.
    I took my truck to get the rotors resurfaced and my tires rotated when the tech there said that my right rear axle seal had started to leak in the brake drum. He mentioned that they were able to clean it up, but that they would not be able to fix it there. I was okay with that because I know that's not their specialty. So now my situation leads me here. I need a place in San Diego that can do the work this week (Mon Aug 3rd through Fri Aug 7th). I'm leaving for vacation on Sun so I can't wait until TacoberWest. So please, does anyone have a family shop, a close friend who owes you a favor or anything else for a mad hook-up? Please let me know. Thank you all.
  2. Aug 1, 2009 at 3:15 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Could you replace the seal your self? The seals are pretty damn cheap if IIRC, and it is only about a 1 hour job. If you can do a brake job, you could probably replace the seal without a problem. Just remove the rear axle shaft on the side leaking, replace the seal, and then replace the axle.
  3. Aug 1, 2009 at 4:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  4. Aug 1, 2009 at 4:41 PM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    Dang that sucks Al! Sorry can't help you out. I'm sure some one on here gots something for ya!
  5. Aug 1, 2009 at 4:42 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    x3
    I paid for one to be replaced on my old truck and it sucked. I'd do it myself if it had to be done again.
  6. Aug 1, 2009 at 6:11 PM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
    I don't exactly have tools that would do the job. Needless to say I think I would need to jack up the truck to even start removing things.
    While Im under there, could I take care of other things like this axle wrap TW members keep talking about (you know that feeling of getting tapped from behind/that slight thump). I'd consider going to someone's pad for help if it was an option.
  7. Aug 1, 2009 at 6:19 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Just had both of mine done at 56k. Stupid. Lasted 150k on the 82. Dealer did those & replaced the brakes since the drivetrain warrantied parts fouled the shoes. Got fresh gear oil, seals & shoes free. Took them 2 days because they jerked off half a day seeing if I really had coverage then only had 1 seal on hand & by that time I guess it was just too much to get another from their other toyota dealership 8 miles away. If it wasn't all free it'd been complete bullshit. I woulda done it myself too if no warranty but I'm gonna hold them to every bit of that 7/100k shit.
  8. Aug 1, 2009 at 6:24 PM
    SC4333
    Grant
    San Antonio, TX
    Oh ok, gotcha. Well if someone steps up and can lend a hand, you will need the inner seal. The outer is just an o-ring and only prevents dust from getting in the housing. It does nothing to prevent oil from leaking out. Good luck!
  9. Aug 1, 2009 at 7:20 PM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
    I hope that's not me. I can't be out of commission. I wouldn't mind doing it... just not alone. Someone's got to half some knowledge I can work with. :D
    I'm hoping too. Thank you for the good luck. I think I'm going to need it.
  10. Aug 1, 2009 at 7:25 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Lubbock Texas
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    sorry to hear that Albert, I hope you get your truck fixed with ease
  11. Aug 1, 2009 at 11:26 PM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bump!
  12. Aug 2, 2009 at 3:28 PM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
    http://www.rapidtransmissions.net or http://www.sdtruckshop.com is what I'm leaning towards right now.
    I will probably end up doing both sides and changing out the rear differential fluid at the same time. This service should set me back around $200. I will keep you posted with updates.
    Here is a great link for additional information about this situation. I know it's not for our 2nd generation, but I would assume there can't be much of a difference. Thank you to Edrin55 for PM me this information.
    http://www.4x4wire.com/toyota/maintenance/rear_axle/wheel_bearing/
  13. Aug 2, 2009 at 3:37 PM
    rpparkster
    rpparkster Well-Known Member
    Roger
    Long Beach, CA
    2009 Tacoma TRD 4X4
    TRD FJ Wheels, 285 GY DuraTrac's, Fox 2.5 C/O w/ Res, TC UCA's, Demello Sliders,AllPro 3" Leaf Pack, Walker Evans 2.0 Adj. RR, AllPro Front Bumper & IFS Skid, Timbren Bump Stops, Leather
    Glad you found some quick and reasonably priced solutions. Now get it done before you ruin your trip.
  14. Aug 2, 2009 at 6:29 PM
    SiRMarlon
    SiRMarlon The Photo Ninja!
    Marlon
    Los Angeles
    Canon 5D MarkIII
    To bad your not in LA...those are easy to replace.
  15. Aug 2, 2009 at 7:20 PM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
    Don't tempt me... I would make the drive. I would need to offset the cost of gas to drive there so if I needed to pay for parts w/ free labor then its on like donky kong. What's the catch?
  16. Aug 5, 2009 at 12:22 AM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
    UPDATE-Took my truck to Rapid Transmissions on Balboa Ave in Clairemont Mesa and guess what... They tell me there is no leak! They asked me if I was the original owner (which I am) and if I had any recent maintenance done (which I hadn't). To my surprise, they're not charging me at all and they can't figure out why it had leaked but isn't leaking any more. There was proof! When the guys on Sat. noticed the leak, they cleaned up the grease as much as possible. Either way, I still had the rear diff change and its parked at the shop on the lift so I can see it first thing tomorrow morning. For now, Im driving my wife's Highlander with a lovely Mary Kay sticker on the side. Haha! Where's my truck!!! Keep you posted.
    By the way, these guys at Rapid Transmission seemed very honest and trustworthy. They said if they had discovered anything other than the work needing repair that they would sent me a digital pic of it before starting that. Kinda cool. Got to gives these guys props. His name if you ever need their service is Noe.
  17. Aug 9, 2009 at 2:45 PM
    dwntwnall4u
    dwntwnall4u Well-Known Member
    Kevin
    san diego
    2013 4x4 Dbl cab Auto
    So is everything ok now?
