My Satoshi Grill write-up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FlawedXJ, Mar 2, 2009.
  1. Apr 10, 2011 at 12:47 AM
    #281
    rcfreak201
    rcfreak201 Well-Known Member
    ok so glue then sand and then bondo and sand again? also is there any advantage in using epoxy over superglue? not sure what epoxy even is, sorry about the noob questions:p
  2. Apr 10, 2011 at 12:49 AM
    #282
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    glue, sand, bondo, sand, primer, sand.. you get the idea :)
    epoxy is just stronger, local auto part stores sell it. I believe some is called "plastic weld". I used it and its STRONG and made for plastic. hence the name :rofl:
    i suggest using plastic epoxy over anything else
  3. Apr 10, 2011 at 12:53 AM
    #283
    rcfreak201
    hmm okay haha ill go pick some up tomorrow then and post pics once im done probably in a few days once i get mesh:cool: how did you attatch the mesh?
  4. Apr 10, 2011 at 12:56 AM
    #284
    snowgod06
    Rob
    06 Access Cab
    whatever way you want really. Some people drill small holes on the inner lip and bolt/zip tie, others make some sort to mounts around the outside. I just use some zip tie holders epoxied around the outer lip. I can snap a pic tmrw when its light out if you want to see.
    But really just do whatever comes to mind, its pretty easy to decide when you stare at it. lol
  5. Apr 10, 2011 at 12:58 AM
    #285
    rcfreak201
    its cool ill figure it out
    yeah i was just gonna get the hard part out of the way and then think about the mesh later on lol
  6. Apr 10, 2011 at 1:00 AM
    #286
    snowgod06
    Rob
    06 Access Cab
    haha, yea. I really recommend plastic epoxy for the patch panels. Its worth the 4-5 bucks.
  7. Apr 10, 2011 at 1:02 AM
    #287
    rcfreak201
    yeah ill go pick some up, the only downside that ive read about this mod is the bondo, some people screw up on the hardener n stuff. whats your input on that? lol ive never used bondo, i just bought the stuff today and was only worried about that, i feel confident about everything else:D
  8. Apr 10, 2011 at 1:05 AM
    #288
    snowgod06
    Rob
    06 Access Cab
    its not to bad, just make sure to eyeball the right proportion of hardner and your good. Allow for a good dry time, and use a higher grit sand paper. It make take a bit longer but will be a lot nice. And dont worry about little holes or pitts. Just apply another thin layer and sand more. It takes time but will be worth it.
  9. Apr 10, 2011 at 1:11 AM
    #289
    rcfreak201
    i sure hope so:D thanks for the info dude!:cool:
  10. Jun 8, 2011 at 2:51 PM
    #290
    tacomatweaker1
    tacomatweaker1 Active Member
    Brad
    Naples FL
    07 PreRunner SR5 Looking to Modify
    K&N
    looks sick was curious if that switch you used for the fog lights was an aux switch that was previsouly in the truck of if it can be purchased somewhere??
  11. Jun 8, 2011 at 5:31 PM
    #291
    FlawedXJ
    FlawedXJ [OP] mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    I bought it at radio shack and drilled a hole in one of the switch blanks.
  12. Jun 8, 2011 at 11:17 PM
    #292
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    You can but I think you have to get it from the dealer. Something like $50-$75 for one. Not worth it. Do a search on here for switches. Lots of good info
  13. Jun 21, 2011 at 9:36 AM
    #293
    TidalWave
    TidalWave I have a shovel and no one will miss you...
    Mendy
    Surprise, AZ
    05 TRD DCLB
    4" Maxtrac Spindle lift, 33" BFG A/T, Avid weld on rock sliders and rear bumper, Smoked Projector Headlights, smoked tails and fogs, HID healights and fogs, flowmaster exhaust, Wet Okoles, debadged. Ready to take your milk money.
    Hope to be doing this very soon, wish me luck!
  14. Jun 22, 2011 at 7:55 AM
    #294
    Drunknsloth
    Retribution
    South West
    Take your time and don't worry about driving around with no grill if it comes to that
  15. Jul 3, 2011 at 5:39 AM
    #295
    Sankofa
    Sankofa Member
    St. Louis
    06 Prerunner SR5 semi-debadged TRD sport
    That is a sharp grill. Looks great
  16. Jul 26, 2011 at 6:48 PM
    #296
    LBCdan
    LBCdan TACO --> TUNDRA
    Dan
    Long Beach , CA
    2018 Tundra CM 4x4
    Toytec Coilovers, TotalChaos UCA, Icon w/ Resi, Toytec Lift Shackle, Methods w/ 285/75/18 Tires.
    Is the mounting bracket for the lights flush with the metal? I went to Lowes and got some longer bolts, but the lights can still swivel and move around.. Thanks for the help!
  17. Sep 3, 2011 at 6:38 AM
    #297
    Ivan
    Ivan Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
    That looks great
  18. Sep 25, 2011 at 6:11 AM
    #298
    chicagocontractor
    chicagocontractor Active Member
    Jon
    Chicago, IL - Elgin
    '07 - 2wd
    They all look great! where did people buy the new grill mesh from?
    Thinking about doing mine, instead of fiber glass i think i may sacrifice a five gallon bucket and use the plastic. If your going to bondo it anyway it maybe easier to use plastic and counter sink the screw so you can bondo over the hole.
    Not sure if it would work, just a thought.
    I use bondo a lot for filling wood at work, normally i use a good taping knife and do two coats. one to get it smooth and one to fill any divots. little fast then sanding it down. ( normally the second coat is with wood filler because its a lot easier to sand but that wouldn't work here)
  19. Oct 19, 2011 at 7:49 PM
    #299
    Ivan
    Ivan
    Western Mass
    nice write up, very thorough
  20. Oct 19, 2011 at 7:51 PM
    #300
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I haz mesh.... :spy:
