My Satoshi/Jameoshi mod journey
Discussion in 'Florida' started by fghtngsquirrel, Jul 1, 2009.
  1. Jul 1, 2009 at 6:49 PM
    fghtngsquirrel
    fghtngsquirrel [OP] Ka-freakin'-BOOM!
    Jacksonville, FL
    '08 4x2 Rad Red *SOLD*
    07.01.09
    I'm off work for the next five days, so I decided to start on Satoshi/Jameoshi mixed mod. Here is what I have done so far...
    The Dremel was a little bit challenging, so I used a mini hack saw as well...
    Below are a few pictures after I sanded down the remaining tabs with the Dremel.
    [​IMG][​IMG]
    First time messing with fiberglass, but I think it turned out good!
    [​IMG][​IMG]
    Took off the tape and trimmed up the fiberglass with the Dremel, though it needs some touching up.
    It was getting dark, so this is as far as I have gotten so far. Tomorrow I will hopefully finish it up, though I'm having a difficult time finding some steel mesh :mad: The grillcraft insert is too expensive, so I'm combining the Satoshi and Jameoshi styles together!
    Will update tomorrow :headbang:
    07.02.09
    Well, things didn't go at the speed I had anticipated, nor did I see the rain forecast :(.
    Anyway, here are the pictures from today...
    The Bondo was more challenging than I thought- PITA for sure. I think I used too much hardener, and then packed the crap in there good. This left me with a lot of sanding... I don't have any pictures of sanding, but I used 80 and 320 grit sandpaper, along with a mini belt sander.
    [​IMG][​IMG]
    I got this huge piece of 1/2" mesh steel from Cannon Welding over on Richard St. for $12! If it works and looks nice, I will be pleased with not spending $150 on a Grillcraft.
    This is post-fiberglass, Bondo, sanding, washing. This also as far as I got before the rain ended my day.
    [​IMG][​IMG]
    07.03.09-07.04.09
    So I started today by trying to paint it black, which did not work. I was not very patient with sanding, so I went out and bought the filler primer, which worked pretty well.
    [​IMG][​IMG]
    I don't have pictures, but I had to use Bondo spot filler to fill in some areas. Through this I learned that Bondo either sucks or I am just terrible with it!
    While I was waiting for all the primer, black Krylon Fusion and clear coat to dry, I also completed the actual grille part.
    [​IMG]:eek:Horrible picture, but it was hot as hell![​IMG]
    After this, things really took a turn for the worst. I tried the method of threaded posts epoxied to the plastic and then using a washer and nuts, like so...
    [​IMG][​IMG]
    I let these sit for about 12 hours, and the epoxy never solidified. I used Loctite Epoxy Gel, but it was either old (I bought it from Harbor Freight) or I suck at mixing it. Either way, when I tried to tighten the nut, the post twisted off.
    Ditched effort #1. My dad had the idea that we could fiberglass the posts on, but that quickly turned into ditched effort #2. Frustration was quickly setting in at this point. I then saw the method lifesaflaw123 used with zip ties and those mounting squares, though I took of the sticky backing from the squares and used a lot of super glue. I do not have any pictures because it was dark, but this method has worked so far, even with a grille as heavy as mine!
    After a lot of work and frustration, I finally finished it! :D I will probably have the grille insert powdercoated and take the rest of it to a professional to get the pits and rises sanded out and professionally painted. Anyway, here is the result of the project mostly done, minus whatever badge I want on it...
    [​IMG][​IMG]
    Sorry that the truck picture has the glare, but it was pitch black by the time I put it on the truck.
    Since I had a lot of time during coats of paint, I decided to add on to the project with some Hella 500FF lights, which will be coming soon!
  2. Jul 1, 2009 at 6:50 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    uh-oh... another squirrel...
    and who's james?
  3. Jul 1, 2009 at 6:51 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    looks good bro, using my write up?
  4. Jul 1, 2009 at 6:56 PM
    fghtngsquirrel
    Jacksonville, FL
    Yeah, I use this name for everything... online, xbox...
    Jameoshi was something I found here Click here . Mine will mostly be a Satoshi mod, though I'm using my own steel mesh instead of the Grillcraft.
    As far as the write-up, I am using yours and this one... Satoshi by lwyattl
  5. Jul 1, 2009 at 6:57 PM
    usctacoma
    usctacoma Be a thinker, not a stinker
    Columbia, South Carolina
    05 PreRunner SR5 Doublecab
    Tint, Black Badges, Firestone Destination 265-70-17s, Weathertech Floor Liners, Sockmonkey decals, Flowmaster 40, Defiant light bar, 4 5" PIAA 540s, BHLM, 5100s @ .85, eibach springs, 1/4" Toytec spacer, 2" Toytec AAL, painted grill, UWS tool box
    looks good so far. good luck with the rest. i havent done the satoshi myself, but from what i hear, its a PITA.
  6. Jul 1, 2009 at 8:43 PM
    fghtngsquirrel
    Jacksonville, FL
    It hasn't been too bad yet, though quite time-consuming. Also, I'm not sure if I used too much hardener or what, but the fiberglass mix dried up on me in 3-4 minutes, not 12-13 like the box claimed.
  7. Jul 1, 2009 at 8:49 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Looking good!
  8. Jul 2, 2009 at 11:49 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    awesome man i cant wait to see it in person. When are you gonna finish it?
  9. Jul 2, 2009 at 11:52 AM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    OoO im interested
  10. Jul 2, 2009 at 1:23 PM
    fghtngsquirrel
    Jacksonville, FL
    I'm trying to finish it today actually, and waiting on the Bondo to set (that stuff is brutal if you don't work fast enough). The toughest part so far was finding some expanded steel mesh, but I just picked a sheet up at Cannon Welding.
    I'll update it again tonight!
  11. Jul 2, 2009 at 2:52 PM
    rmb_crew
    someone posted this site awhile back when they did theres. You can have any design of expanded metal made, and in any material you want. I know it would take a few days to get it so sorry im late with it.
    http://www.mcmaster.com/#mesh-screens/=19yilm
  12. Jul 5, 2009 at 12:41 AM
    fghtngsquirrel
    Jacksonville, FL
  13. Jul 8, 2009 at 10:34 PM
    fghtngsquirrel
    Jacksonville, FL
    Well I am trying to mount the fog lights behind the grille, but they're wanting to rest on the radiator. Is that safe, or do y'all have any suggestions? I am using Hella 500FF lights with the factory mounting brackets and bolts. Thanks!
  14. Jul 8, 2009 at 10:40 PM
    fghtngsquirrel
    Jacksonville, FL
    I think I figured something out actually... I feel dumb. :frusty:
  15. Jul 9, 2009 at 12:01 AM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    What did you figure out? Mine have been resting there for almost 3 years with no problems.
  16. Jul 9, 2009 at 2:54 AM
    fghtngsquirrel
    Jacksonville, FL
    Yeah, I got them close to the radiator but not actually touching. Hopefully they'll stay that way. However, I hooked everything up and the lights are not coming on :eek:
    Here are some pictures of the install though...
  17. Jul 21, 2009 at 5:29 AM
    mxracer16
    mxracer16 Well-Known Member
    2006 trd
    stock stock stock
    get job !!!1
    Nice write up
    great informational pictures and detail !!!!!
    High 5 !!!!!
    I love the color wish i wold have go that one ....in about 20 years when i beat up my swb trd then i will get that one.
    Nice job again.
  18. Jul 21, 2009 at 5:56 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    looks good and a nice write up
  19. Jul 21, 2009 at 12:02 PM
    rmb_crew
    nice job man. Oh and i saw your bull bar for sale on craigslist a few days ago.
  20. Jul 21, 2009 at 12:14 PM
    fghtngsquirrel
    Jacksonville, FL
    haha, yeah I was wondering if anyone would see that. I sold all my chrome stuff because I hated the look, though my new exhaust tips are chrome :( Craigslist is good though.. I bought a 48" Hi-Lift the other day for $60.
