My serpentine belt took a chit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheDevilYouLove, Dec 22, 2019.
  1. Dec 22, 2019 at 1:31 PM
    TheDevilYouLove
    TheDevilYouLove [OP] You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    After about 25,000 miles. Luckily I kept the original as a spare. Not sure what caused this?
    Rob MacRuger and DG92071 like this.
  2. Dec 22, 2019 at 1:38 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    those aftermarket BANDOs seem to be shredding up a lot take a look at some of the AMAZON reviews for that model, there is a big difference in the quality of the OEM Bando vs. the aftermarket BANDOs from what ive gathered, the OEM Bando is about 3 times more costly but worth the money
  3. Dec 22, 2019 at 1:45 PM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    Have 98k on original OEM, no signs of cracking or wear YET
    TomTwo and BillsSR5 like this.
  4. Dec 22, 2019 at 1:53 PM
    TheDevilYouLove
    Marylandistan
    That sucks but it makes me feel better. I was concerned that I balled something up when I installed it.
    I guess Bando makes “second rate” belts for the aftermarket? Whole reason I went with Bando was I thought they were the OEM manufacturer.
  5. Dec 22, 2019 at 1:57 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Don't forget to check your pulleys!
    I've always had good luck with gates belts..
    ZachPrerunner and KS WRAITH like this.
  6. Dec 22, 2019 at 1:58 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Yikes, this is why I stick with OEM for maintenance parts.
  7. Dec 22, 2019 at 1:58 PM
    BillsSR5
    bill
    2014 SR5
    take a look at the AMAZON reviews some peeps having the same shredding on those BANDOs same model,same truck. those shredding are the US made, I think the OEM s are JAP made version hence the high cost(import) there is a striking difference in quality my OEM for a 2.7l is $80 versus the $25 for a stateside version
    BrianT23, Skyway and photogr4x4 like this.
  8. Dec 22, 2019 at 1:59 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Looks like the OEM belt is 2x the price of the Bando: https://amzn.to/2Shygtr
    Lord Helmet, lynyrd3 and BillsSR5 like this.
  9. Dec 22, 2019 at 2:05 PM
    TheDevilYouLove
    Marylandistan
    Bando is the OEM maker but as noted above there are crappy US made versions and quality Japanese made versions.
    BillsSR5 likes this.
  10. Dec 22, 2019 at 2:13 PM
    BillsSR5
    bill
    2014 SR5
    yes, luckily there wasn't any damage, some other dudes go wrapped up in the pulleys and and may have damaged the radiator whipping around, get the OEM BANDO mines still good approaching 120k miles
  11. Dec 22, 2019 at 2:15 PM
    BillsSR5
    bill
    2014 SR5
    me too, when its day comes im forking over the money for the same one
    grizquad[QUOTED] and Blockhead like this.
  12. Dec 22, 2019 at 2:16 PM
    BillsSR5
    bill
    2014 SR5
    I think they still have a factory in Japan that makes the OEM for Toyota
  13. Dec 22, 2019 at 2:22 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    All manufacturers make parts for the manufacturer(oem parts) and parts for the auto zones, Napa’s, pep boys etc. they are not the same. No matter what anyone says they are not the same quality. It’s not just the dealer marking up price, parts at the dealer are made to certain specs required by Toyota. And like be always said you get what you pay for. Not that every part has to be bought at the dealer but some parts should be.
    Skyway and BillsSR5 like this.
  14. Dec 22, 2019 at 2:32 PM
    BillsSR5
    bill
    2014 SR5
  15. Dec 22, 2019 at 2:32 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Think I still have the original. 2008 with 127000
    b_r_o, Plain Jane Taco and BillsSR5 like this.
  16. Dec 22, 2019 at 2:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    Consider you could have a bad pulley somewhere in the system. Bearing failing or improper installation of a part with a pulley as part of it can cause wobble, misalignment and belt failure.
    Or you could have just had a bad belt.
    I've seen folks put 3 groove pulleys on were 4 were the requirement, but the belt rarely lasted very long.
    But before buttoning it all back up it's worth checking everything out.
    Skyway and TheDevilYouLove[OP] like this.
  17. Dec 22, 2019 at 3:57 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OEM only. My original one went 100k before i pulled it off and put it under the rear seat just incase. Replaced with an OEM toyota belt as well.
    Its funny, belts now adays typically wont show signs of cracking, etc like old belts back in the days. Now what you do get is groove wear which is hard to see without a gauge / feeler comb
    Markcal, Rob MacRuger and Jeremy M. like this.
  18. Dec 22, 2019 at 4:53 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Look at the 3 idlers and the tensioner. At 155k mine were bad and the tensioner was grooved and grating. Got the 3 idlers and tensioner assembly with a belt all OEM online at TotyotaPartsDeals for $300. A big pain to put the tensioner on so I figured 10 years 155k why not pay $100 more and go OEM.
  19. Dec 22, 2019 at 4:54 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Show us the ribs
    Minerva09 and DGXR like this.
  20. Dec 22, 2019 at 5:12 PM
    TheDevilYouLove
    Marylandistan
    I already replaced the factory idlers with Gates pulleys but after this Bando belt issue, I just ordered three OEM pulleys from ToyotaPartsDeals. Don’t trust any non-Toyota parts right now.
    Rob MacRuger likes this.
