My shifter jerks,need input!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rburdeaux, Feb 13, 2017.
  1. Feb 13, 2017 at 10:48 PM
    Rburdeaux
    Rburdeaux [OP] Well-Known Member
    2004 Double Cab Prerunner
    Hey everyone i am new to this site. i have been hawking on it for awhile and really enjoy it. I bought a 2004 Double Cab trd off road, with 118,000 miles on her in San Diego. I took her to the "truck shop" in San Diego, and everything is running great. so i think.(i'm a total noob) The past couple days when i come to a red light or stop sign i have noticed that the car jerks(i don't know if jerk is the right word but it feels like it sits down real quick) a slight bit and the shifter pulls back quickly. when i accelerate i feel it pull a little too. is it something to be concerned about or is this normal?
    Here is some info on the truck if that helps:
    I am the second owner.
    Manufactured in Fremont, CA
    Originally Sold in El Cajon, California
    Bought in Miramar, California (by me, used car dealership)
    So Cal truck only
    119,950 Miles-currently
    Maintenance at 118,500(replace spark plugs, replace air filter, replace windshield fluid reservoir, replace timing belt and tension rollers, replace water pump, replace t-stat, replace front struts, replace rear shocks, replace coolant, replace steering rack bushing, reseal valve cover gasket, EFI service, alignment, and got new tires. General Grabber AT/2- 245/75/16) i get an average 18MPG and have just put a full can of seafoam in the fuel tank. its runs so smooth.
    Is creating a new thread appropriate to find an answer to this question or is there another direction i should go.thank you!
  2. Feb 13, 2017 at 10:53 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    That would be axle wrap my friend. Also possibly carrier bearing. Does it jerk when shifting while you are parked?
  3. Feb 13, 2017 at 10:55 PM
    Rburdeaux
    it does not jerk at any other time, just when i come to a stop. usually faster speeds.
  4. Feb 13, 2017 at 10:57 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Axle wrap for sure, get spring helpers, or stiffer leaf springs.
  5. Feb 13, 2017 at 10:59 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Or traction bars that's the word I was looking for lol
  6. Feb 13, 2017 at 11:01 PM
    Rburdeaux
    okay thanks for the input! could i just live with it or will it hurt my truck?
  7. Feb 13, 2017 at 11:04 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Tbh I'm not sure, it changes your pinion angle when I wraps so I guess that could slowly mess up stuff in transmission or differential I'm not sure, here's a write up for spring helpers though.
    https://www.tacomaworld.com/threads/goodbye-axle-wrap-mod.108316/
  8. Feb 13, 2017 at 11:05 PM
    Rburdeaux
    Thank you
    RedManRocket likes this.
