My shop is saying they cannot correct this caster issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Darryle, Sep 20, 2014.
  1. Sep 20, 2014 at 11:01 AM
    Darryle
    Darryle [OP] It is just a truck
    Darryle
    Weatherford, Texas
    Vehicle: 2004 Toyota Tacoma Prerunner Double Cab
    Christian Brother's Automotive is saying they cannot correct the 2.4* caster on the right side?
    Is it even the correct specs?
    Can it be corrected, do I just need to find another shop, what are the consequences of not correcting it?
    Anyone see any other numbers I need fixed?
    Thanks
  2. Sep 20, 2014 at 11:12 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    I don't see why not, unless it was wrecked or damaged somehow. Try another shop?
  3. Sep 20, 2014 at 11:12 AM
    Large
    Large Red
    Did they give a reason why, bent spindle maybe
  4. Sep 20, 2014 at 11:13 AM
    Darryle
    Darryle
    Weatherford, Texas
    No reason given, it has never been wrecked either
  5. Sep 20, 2014 at 1:10 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Did they say they can't change it from 2.4* in either direction or just can't improve it? 2.4* of caster isn't bad btw. You may have run out of adjustment on the lower cams
    Either way I'd find out why they can't do anything with it and/or take it somewhere else.
  6. Sep 20, 2014 at 1:19 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    2.4 deg is decent caster. In fact, I'd ask them to bring the caster on the LH side from 1.7 to 2.4 deg to match the RH.
    More caster = more self-centering force in the steering system and more camber gain in corners (both are good things). If you didn't have power steering, it would also mean greater steering effort. On my lifted 2nd gen with aftermarket control arms, I'm at 5 deg caster.
  7. Sep 20, 2014 at 8:24 PM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    The caster spread looks ok to me. If the truck tracks straight down the road and doesnt pull then I see no issue here.
  8. Sep 20, 2014 at 8:35 PM
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    You actually want higher caster on the pass side to fight the road crown. As long as it drives straight.
  9. Sep 20, 2014 at 9:03 PM
    Darryle
    Darryle
    Weatherford, Texas
    It drives awesome, tracks great even on the crowned back roads.
    I appreciate it guys, I just had Discount Tire install new Michelin LTX M/S 2 tires and then drove it to Christian Brother's and had them install new KYB Mono-Max shocks and struts and then do the alignment. Hopefully I am good for another 100,000 after I had Toyota do the timing belt, water pump, drive belts, thermostat, all of the tensioner, even the hydraulic one, flush the radiator and change the transmission fluid. This has been an awesome truck so far.
