My slant on the Fogs on mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AZFizik, Jan 7, 2009.
  1. Jan 7, 2009 at 12:32 PM
    AZFizik
    AZFizik [OP] Slowpokeologist
    James
    Phoenix
    07 TRD OffRoad Prerunner
    TRD Catback & CAI, Fogs only, Recovered Armrests, BFG AT's
    Ok, I didn't like the fogs on mods so far because of that dumb 4 hour on thing. So I figured, why not just grab the signal from the marker lights? Its an on with light switch circuit, its fairly low amperage, and its really easy to get to.
    So, first to mod the relay itself. I took the rear most coil contact (the one that shows 12v when the headlights come on) bent it over and solder/shrink sleeved a 16ga wire to it. Simple enough, just have to be careful that you don't heat the contact up to much.
    I left about 2ft of wire on there, so it'd be easier to work with. I found one of those holes that was nice and close and just started pushing the wire through. It popped out the bottom without much complaint. So what we have is a very clean look after its plugged back in.
    Now to grab the signal I'd need, I went to the breakout for all the driver side signal lights. Following the wire back from the marker itself, I stripped back a length, cut my signal wire from the relay to size and soldered them. Being very careful not to brand myself in the process.
    Ok, clean it all up and make it look pretty.
    And the result:
    Freeheelbillie likes this.
  2. Jan 7, 2009 at 2:16 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    ooOo i like =D mine looks like shit cause i wont ever see it.. haha, but good job! excellent pictures too
  3. Jan 7, 2009 at 3:51 PM
    camsbored
    camsbored Well-Known Member
    Raleigh, NC
    08 PreRunner DC/Sport/LB
    Kenwood DNX8120, Homelink mirror, Valentine One hardwire
    Nice! I think I'm going to do it this way on Saturday. Thanks for the pics.
  4. Jan 8, 2009 at 4:28 PM
    craigFLA
    craigFLA Well-Known Member
    Ft. Lauderdale, Florida
    Tacoma TRD Sport Pkg.#1, XSP Package
    Leather, 20" rims, Borla cat-back exhaust, running boards, back up camera/3" screen in rear view mirror, carbon fiber interior trim. Tow Package. MODS: URD intake BHLM. Tinted tails & 3rd brake light Fog Light mod. 5pc Grill Craft (High Gloss Black powder-coat) T-Rex eye-lids AVS Wind Deflectors 3M Window Tint 15 front/30 rear OBX Sports Pedals Viper 5901 / remote start Pioneer AVIC F90BT-NAV Hybrid L8's in doors, L4's and Dynaudio MD102 tweets in custom kicks, morel rear-fill, JL TW5-13" sub, JBL MS-8, 2@Tru B475, Tru 4.65, PPI a600.2, PPI 456 X-over, Raamat BX2 and ensolite. relocated rear seats 3/4" Retrax cover electric dual "dead-bolt-lock" electric tailgate lock. electric Dynalock for Retrax Cover/custom fabricated case. kinetik second battery/power-gate isolation. Powerslot Cryogenic rotors, Hawks HPS Pads, SS lines,painted calipers&drums FULL trans flush mod OE Denso plugs
    I disassembled the fuse box, and moved the wire location in the plug from 1 plug to another. No soldering, and no way to tell the mod was even done while looking at the fuse box...
    No worries of lights coming on after 4 hours etc...
    There is a very good write up on TN, which I added pics to when i did mine.
    Good luck.
  5. Jan 8, 2009 at 4:38 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    fantastic... :D
  6. Jan 8, 2009 at 4:38 PM
    Delmarva
    Tucson, AZ
    Linky??
  7. Jan 8, 2009 at 4:44 PM
    ERdept
    ERdept Well-Known Member
    Thanks.
    Your caption at the bottom doesn't make sense......
    "Good engineers design things to be idiot proof. Truly amazing engineers craft things to be idiot resistant".
    Isn't "proof" a higher level than "resistant". Like a waterproof watch is better than a water resistant watch.
    So a truly amazing engineer would make something idiot proof, right?
    I'm not arguing, just pointing out something you may want to change. Perhaps you typed it in haste.
  8. Jan 8, 2009 at 4:59 PM
    AZFizik
    James
    Phoenix
    Proof expects the engineer to outsmart the idiot, resistant expects the idiot to confound the engineer and for the system to survive
    Philrab likes this.
  9. Jan 8, 2009 at 5:02 PM
    Delmarva
    Tucson, AZ
    :laugh: :D
    too bad I only know good engineers... lol
  10. Jan 8, 2009 at 7:46 PM
    Ghost96Romeo
    Ghost96Romeo What is the Search Tab for????
    Texas
    06 TRD Off-Road D-Cab
    3" Pro-Comp Suspension Lift AAL Rear w/TSB, All-Pro Plate Bumper, Lightforce 240 Blitz lights, Lund Genesis Roll-top Bed cover, K&N Filters, Spidertrax Wheel spacers, Built-by-Me Rock Sliders, Jeep Tow-Hook, Black Leather seats, 48"Hi-Lift Jack mounted in the bed, Blacked out TRD Rims, BHLM, FLM..... and Awesomeness
    That looks great but I've got a few questions...
    Can you still control the fog lights on/off with the existing switch?
    and
    Which wire do you slice into from the relay to turn on the foglights?
    and
    What happens to the relay when you don't connect all the pins back into the terminal? Doesn't seem like it would work...
  11. Jan 8, 2009 at 8:43 PM
    AZFizik
    James
    Phoenix
    Existing switch works normally. The only difference in function is that you can turn the lights on with the marker lights. The fogs also stay on when high beams are turned on.
    The wire I sliced into was the hot +12v wire for the driver side marker light. The terminal on the relay I bent over was the rear most pin. That side of the relay shows 12v with low beam and turns off with high beam. The other side will show 12v then ground when the switch is pressed.
    You need to understand the circuit of that relay. The pin I bent up is merely a feed, not a signal. Its what is called a low signal circuit, meaning that it rests (not triggered) at +12v and signals from the switch with a ground. The FOG switch in the cab just grounds the relay, it does not send power.
    What the problem that I solved was that the +12v source for that relay would not be turned on until you had triggered low beams. So you'd loose them whenever those were turned off. I made it so the source is from the marker lights, which is on constantly with the switch.
    Hope that clears it up.
  12. Jan 8, 2009 at 8:48 PM
    Ghost96Romeo
    Texas
    Absolutely thanks for the help!
  13. Jan 9, 2009 at 3:33 AM
    craigFLA
    http://www.toyotanation.com/forum/showthread.php?p=2456780#post2456780
    my posts started at #213 (sandfleee) but I simply added blurry pics to someone elses explanation. I was doing the BIG THREE at the same time (while the fuse box was open) so there are a few pics of that as well.
    All your doing is taking the wire from pin 21 of Junction Block 2A and moved it to pin 13. The challenging part is getting to the underside of the fuse box, but in the end much cleaner then the "add a fuse" method, or any "solder - relay" method.
    Hope this helps anyone considering this mod.
  14. Jan 9, 2009 at 4:22 AM
    Delmarva
    Tucson, AZ
    Thanks! :D
  15. Jan 9, 2009 at 5:21 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    So let me get this straight. If you have the fog lights on and the marker lights on what happens when you turn off the marker lights? Do the fogs go off as well or do they stay on until you turn them off with the fog light switch?
  16. Jan 9, 2009 at 6:57 AM
    AZFizik
    James
    Phoenix
    If the marker lights are turned off, the fogs turn off also. The fogs operate independently from the headlights and are instead tied to the operation of the marker lights.
  17. Jan 9, 2009 at 7:04 AM
    harshest
    Michigan
    05 PreRunner SR5
    Fantastic, that is what I have been looking for. I always forget to turn my fogs off in the morning and end up driving around with them on most of the afternoon. Will be doing this on Saturday. Thanks
  18. Jan 19, 2009 at 8:05 AM
    Delmarva
    Tucson, AZ
    Just did it with your twist - works like a charm.. thanks :thumbsup:
    +1 for you :D
  19. Jan 19, 2009 at 9:58 AM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    Thats also how mine is done...
    I just used connectors/scotch clip in place of soldering.
  20. Jan 19, 2009 at 10:09 AM
    Delmarva
    Tucson, AZ
    ya... that's all I used.
