My Son jumped the battery wrong..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LAH60, Mar 23, 2013.
  1. Mar 23, 2013 at 11:09 AM
    RPD STARS
    RPD STARS Turn up the good, turn down the suck!
    BC
    2010 Raptor
    Go Faster Retrozzz... Drop in Dry Flow, Blowfaster Delta 50, 315/70/17 BFG Stock Action
    LOLZ
  2. Mar 23, 2013 at 11:14 AM
    Doozer
    Doozer Member
    '13 TRD Off Road 4x4
    TRD Catback Exhaust
  3. Mar 24, 2013 at 3:37 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    I do not think so.
  4. Mar 24, 2013 at 5:40 AM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    No color was right!!!
    We don't use u in all our words!!
  5. Mar 24, 2013 at 12:26 PM
    JKD
    JKD Well-Known Member
    That's one good reason to always connect to the positive terminal and a metal grounded part. If you hook it up "backwards" (pos to neg, neg to engine/chassis), current will flow through the negative battery cable, not the vehicle's electrical components.
    Might kill the jumping car's battery, but won't kill either vehicle's electronics.
  6. Mar 24, 2013 at 2:04 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    The fuse box should have a cover that pops off. No need to unbolt anything.
    Look for any fuses that may look burnt to start with.
    replace with the same amp rating
  7. Mar 24, 2013 at 2:13 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    1. Smack son upside the head.
    2. cross fingers.
    3. Replace battery.
    4. Hope for the best.
  8. Mar 24, 2013 at 2:34 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    There is indeed a 100A or 120A "alt" fuse "bolted" into the fuse panel beside the battery. If its blown, its a PITA to change, but not the end of the world. You have to cut a tie strap or two where the wiring exits the bottom of the box, then carefully pry the tabs back so you can lift the panel with all the fuses and relays up out of the box. Once its up an inch or two, you can remove the 10mm head bolts, and replace it. Then, check all the other fuses, both in that panel and behind the change drawer in the dash. Replace any blown ones, have the battery tested and replace if needed, cross your fingers, and try to start it up.
  9. Mar 24, 2013 at 2:34 PM
    deepcoma
    deepcoma Well-Known Member
    Land of the rising sun
    2013 TRD Sport DCSB 4X4
    LMAO
  10. Mar 24, 2013 at 6:38 PM
    LAH60
    LAH60 [OP] Member
    Laura
    colorado
    Thanks for the help Redlight, and everyone else. Got it running
  11. Mar 24, 2013 at 6:39 PM
    LAH60
    LAH60 [OP] Member
    Laura
    colorado
    Well I did 1,2, and 3 Working on 4
  12. Mar 25, 2013 at 5:46 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Laura, glad to hear that you got it running. If it were my vehicle and to avoid problems from latent damage, I would fully charge the battery with an external charger and test the battery and charging system. Many auto parts or battery stores will it for free and it just takes a few minutes.
  13. Mar 25, 2013 at 5:51 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    No Colour is correct Nunavut's Location is CA. Oz is a true Canuck :canada:.
  14. Mar 25, 2013 at 6:59 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    It is my understanding that reversing polarity while jumping a 12-volt car battery was applying a short across a 24-volt battery (two 12-volt batteries wired in series) and that a voltage spike that could damage the electronics before a fuse would open. I believe the reason for making the last jumper/charger connection from negative terminal of the donor's battery to the frame/block of the vehicle with the dead battery was to significantly reduce the possibility that a spark might ignite any residual hydrogen gas around the battery.
  15. Mar 25, 2013 at 7:08 AM
    #35
    fletch97
    fletch97 Well-Known Member
    NJ
    2020 Tacoma TRD Sport
    What happened to the other vehicle he jumped it from?? :confused:
  16. Mar 25, 2013 at 7:09 AM
    #36
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Ha that is strange I tough blocking diode is built in now into fuse box. In old times blocking diode would be right beside positive battery cable.
  17. Mar 25, 2013 at 10:21 AM
    #37
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Well there's your problem. It was abooot the difference between the word 'color' and 'colour' which I KNEW was going to cost someone dearly someday. When will our great nations ever come to an agreement? :confused:
    Seriously though, how do you f*%k up something like this?
  18. Mar 25, 2013 at 2:23 PM
    #38
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Yep. Keeps the spark away from any explosive gas that might be around the battery.
  19. Mar 25, 2013 at 7:06 PM
    #39
    LAH60
    LAH60 [OP] Member
    Laura
    colorado
    Nothing, Still running and okay
  20. Mar 25, 2013 at 7:13 PM
    #40
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Has this been figured out yet?
    If not...there will be a main fuse...like 100+ amp fuse. That most likely got puffed. Check/replace every fuse before moving on to replacing main components. That's where it gets expensive.
