My SPC UCA experience. It's not good.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IvanhoeTaco, Sep 15, 2019.
  1. Oct 10, 2019 at 11:29 AM
    #81
    redmonster
    redmonster Well-Known Member
    The X Axis on the frame is bad. They determined if you loosen the bolts and the noise goes away, then they are bad. I received the "new" replacements. Let you know outcome.
  2. Oct 14, 2019 at 8:07 PM
    #82
    redmonster
    Received and installed new SPC UCAs over the weekend, and man what a difference. No more clunking noise. Much thanks to Marie from Headstrong and the guys over at SPC for sending new UCAS.:burnrubber:
  3. Oct 15, 2019 at 5:58 AM
    #83
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    THE ONLY WAY TO KNOW YOU GOT A BAD BATCH IS TO INSTALL? AND WITH THE NEW AXIS BUSHINGS CAN YOU REPLACE JUST THE BUSHINGS? OR DO YOU NEED TO GET ALL NEW ARMS
  4. Oct 24, 2019 at 12:26 PM
    #84
    gharris767
    gharris767 Member
    Greg
    McAllen, Texas
    2015 Tacoma TRD Sport 4WD
    285/75/17 KO2's, GoRhino Bullbar & Steps
    I had same issue on my 2015, new SPC's installed this week problem solved. The installer figured out noise went away when it was loosened, said it was a warranty issue. I called SPC they admitted they had a bad batch and quickly sent out the new arms, problem solved. Unfortunately it cost me another $240 in labor to have them swapped out.
  5. Dec 28, 2019 at 4:18 PM
    #85
    cdex8357
    cdex8357 “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    Is this the sound? Just installed spc uca I purchased from toytec
  6. Dec 28, 2019 at 4:51 PM
    #86
    gharris767
    gharris767 Member
    Greg
    McAllen, Texas
    That sounds a lot like mine did before the exchange. BTW mine has been great since the exchange. Good Luck!
  7. Dec 28, 2019 at 4:52 PM
    #87
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    who did your purchase yours through? I gonna need to drive the truck
  8. Dec 28, 2019 at 4:55 PM
    #88
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Be mindful for you guys running used SPCs. Warranty is only valid for original buyer.
    Pretty easy to find them new from approved vendors for used prices if you know who to ask.
    SC4333 and whatstcp like this.
  9. Dec 28, 2019 at 5:15 PM
    #89
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    Thanks. How did y’all advise I should do the warranty claim.. through SPC or toytec..
    I’m gonna need the vehicle while they are in transit until installed. Can’t send these with without something to put in there. How did that work for y’all?
  10. Dec 28, 2019 at 5:18 PM
    #90
    T4RFTMFW
    ToyTec is a vendor. They have nothing to do with warranty of other brands products except facilitating the sale. After the product is yours, it’s you and the manufacturer.
    Kolter45 likes this.
  11. Dec 28, 2019 at 5:20 PM
    #91
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    You should have gotten JBA :p
    Kolter45 and crashngiggles like this.
  12. Dec 28, 2019 at 5:46 PM
    #92
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    If they don’t fix the problem I will..
  13. Dec 28, 2019 at 5:49 PM
    #93
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
  14. Dec 28, 2019 at 6:11 PM
    #94
    12taco12
    rochester NY
    2012 TX Pro
    you can call them with the number on the bushing and they will tell you if you got a set from the bad batch
  15. Dec 28, 2019 at 6:30 PM
    #95
    757yotas
    Virginia
    2007 TRD Sport
    I have had my JBAs for alittle over a year now and they are awesome. Recommend to anyone
    Xrs-fsho and Kolter45 like this.
  16. Dec 28, 2019 at 6:32 PM
    #96
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    I was also recommended spc.. so if it’s a bad batch and spc will own up to it and fix problem then I’m good.. speaks a lot of a company that will own its mistakes and fix the problem. we shall see..
  17. Dec 28, 2019 at 7:26 PM
    #97
    badger
    badger Well-Known Member
    07 SR5
    They have a long history of quality issues, and then coming in with good customer service to make it right. I would rather see the effort put up front and saving everyone the trouble.
  18. Dec 29, 2019 at 8:53 AM
    #98
    gharris767
    gharris767 Member
    Greg
    McAllen, Texas
    I purchased from ToyTec. I called ToyTec about issue, they said it was a known issue and they would SPC contact me directly. SPC called within 1 day, very pleased with responses from both.
  19. Dec 29, 2019 at 9:08 AM
    #99
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    Fairly common to hear that when one tightens down the bolts on the bushing with no load on the suspension. The mounting bolts are supposed to be tightened up with the weight of the truck on its wheels.
    whatstcp likes this.
  20. Dec 29, 2019 at 10:08 AM
    #100
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    I did this and was a pain to get the torque wrench up there
    Island Cruiser likes this.
