My Steering goes from Normal to Stiff back to Normal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AdamT23, Jun 2, 2022.
  1. Jun 2, 2022 at 10:12 PM
    AdamT23
    AdamT23 [OP] Well-Known Member
    Adam
    Fresno, CA
    2017 Silver Tacoma TRD Off Road 4X4 Double Cab
    So recently I’ve fixed my accident all by myself with new spindles and it’s driving now. Just needs an alignment and recalibrate my VSC.
    but my issue is now is that, every time I turn left or right, my steering would go from normal to super stiff back to normal. I just want to find clues of what the issue could be?
  2. Jun 2, 2022 at 10:33 PM
    PahalaTacoma
    PahalaTacoma Well-Known Member
    Tucson, AZ
    2017 Tacoma TRD PRO
    PS system low on fluid, leaking, or air bubbles.
    513Mugsy and AdamT23[OP] like this.
  3. Jun 2, 2022 at 11:16 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    How did the accident happen?
    If you had to replace the spindles due to an accident, then you could have damaged the steering rack and pinion.
  4. Jun 3, 2022 at 12:27 AM
    AdamT23
    Adam
    Fresno, CA
    Power steering is good n no leaks at all.
  5. Jun 3, 2022 at 12:28 AM
    AdamT23
    Adam
    Fresno, CA
    Hit n Run didn’t get the guy info. That’s what I’m afraid of, if it damaged the steering rack
  6. Jun 3, 2022 at 3:51 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Yeah, sound like a bent steering rack.
    AdamT23[OP] and Speedfreak like this.
  7. Jun 3, 2022 at 5:16 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    X3
    If you had to replace the spindles, then the chance the steering rack is damaged is high. There have been lots of issues reported about these racks not liking large tires let alone direct hits in accidents.
  8. Jun 3, 2022 at 5:44 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Yea, rack shaft or some thing else is tweaked. How did your tierods look?
    Chew and AdamT23[OP] like this.
  9. Jun 3, 2022 at 9:22 AM
    AdamT23
    Adam
    Fresno, CA
    Tie Rods are solid. No bends or anything
    ShimStack[QUOTED] likes this.
  10. Jun 24, 2022 at 10:13 PM
    808Time
    808Time New Member
    2005 White tacoma
    I would try getting an alignment since you replaced your spindle
  11. Jun 24, 2022 at 10:24 PM
    Bishop84
    Bishop84 Well-Known Member
    Very common for steering racks to get damaged in accidents, likely a bad spot or tooth. It won't get better.
    Sucky part is they aren't super easy to change. Have someone rotate the wheel back and forth and have your hand on the rack, see if its binding.
    Chew likes this.
  12. Jun 24, 2022 at 10:27 PM
    808Time
    808Time New Member
    2005 White tacoma
    You feel like it’s even harder while reversing? Mine was like that too
