MY STOCKS ARE 17X8, CAN I GET 17X9
Discussion in 'Wheels & Tires' started by Mater5, May 31, 2012.
  1. May 31, 2012 at 11:17 AM
    Mater5
    Mater5 [OP] Active Member
    M
    Ridgecrest Ca
    2012 TRD SPORT
    NONE YET... TO BE CONTINUED ...
    OK SO MY STOCK WHEELS ARE 17X8.
    THE WHEELS I WANT ONLY COME IN 17X9
    WHATS THE DIFF AND CAN I GET THE 17X9 WITHOUT ANY ISSUES... ? :cool:
  2. May 31, 2012 at 11:29 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    yes. Just make sure to get a 4.5-5" backspace on the new wheels.
  3. May 31, 2012 at 3:52 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Your stockers are 17x7.5.
    And what size tire do you want to run on the 17x9s
  4. Jul 17, 2012 at 6:54 AM
    Mater5
    M
    Ridgecrest Ca
    2012 TRD SPORT
    im gonna put 265 70 17 on.
  5. Jul 17, 2012 at 8:45 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    after you decide on which brand and model of tires you want, check out the tire manufacturer's website to see if it's approved for a 9" wide wheel. some are and some are not.
  6. Aug 21, 2012 at 9:24 AM
    Mater5
    M
    Ridgecrest Ca
    2012 TRD SPORT
    well i wanna put bf's on. all terrain ta ko. 265 70 17. im pretty sure thats the biggest i can go without getting a lift.
    do you know what the highest i could go if i were to get a 2 inch lift?
  7. Aug 22, 2012 at 12:37 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    BFG AT KO 265/70/17 are not approved for a 9" wheel. On an 8" wheel you'll be ok. With 2" of lift, you're still stuck with the same size listed.
  8. Aug 23, 2012 at 11:25 AM
    Mater5
    M
    Ridgecrest Ca
    2012 TRD SPORT
    Series 101 Black
    item # 1018-8988
    Wheel 17x9 - -8 offset, 130.1 hub what size tire would be ok on these???
    i wanted 265/70/17 but what will i have to go to if i got these?
  9. Aug 23, 2012 at 11:40 AM
    Hydrabyte
    Hydrabyte Well-Known Member
    Florida
    1987 4Runner
    fwiw, I have 17x9 Moto's & BFG AT's 265/70/17 installed as did another member I got the idea from (probably many more as well), Discount tire never told me 3+ years ago they aren't approved? I have close to 3" lift and they still slightly rub on the front mud-flaps at full turn.
    .02
  10. Sep 11, 2012 at 10:19 AM
    gr8tacsprt10
    gr8tacsprt10 Well-Known Member
    Vince
    Kirtland AFB, New Mexico
    I am glad i found this info.... i just bought a used 17x9 eagle alloys..hmmm- how about 275/70/17 tires? or I do have to get 285's for it? thanks for any input
  11. Sep 11, 2012 at 11:37 AM
    TexasTacoma37
    Check the tire manufacturers website. It will have the approved wheel sizes.
  12. Sep 11, 2012 at 1:43 PM
    gr8tacsprt10
    Vince
    thanks! i went to tirerack.com and reading on the tire manufaturers specs.... got confused on "Rim Width Range" vs. "Measured Rim Width".... can someone please explain
  13. Sep 11, 2012 at 2:36 PM
    TexasTacoma37
