My Sub and Amp Install 2005 Access Cab
Discussion in 'Audio & Video' started by mjbirdie75, Mar 14, 2013.
  1. Mar 14, 2013 at 9:16 AM
    mjbirdie75
    mjbirdie75 [OP] Member
    Cordova, TN
    05 PreRunner White
    Box design credit goes to Chadderkdawg. My box was inspired by his posts showing his stuff and many thanks for sharing Chad!
    I had previously installed a Kenwood DNX 6140 Head unit and Pioneer door speakers (speaker rings courtesy of HookedonTronics - thank you sir).
    So, what is shown here is really just the sub and amp stuff.
    Purchased from Sonic Electronix:
    Rockford Fosgate R600-5 (5-ch amp: 50x4 and 200x1 RMS)
    Rockford Fosgate Prime R1S410 10" sub
    NVX XKit42 - 4 ga amp kit (sep bought 2 extra signal cables and extra 25' of 16ga speaker wire)
    Terminal Cup
    Total was: $386.51
    Purchased from Lowes:
    (1) 4'x8' sheet of 3/4" MDF (which I had them cut 3x to (4) 2'x4' pieces)
    5 lb. box 2" ext sheetrock screws
    Titebond wood glue
    (1) Tube of Silicone
    Assorted Extras
    Total: (lost receipt, but it was around $50)
    That's all the files I could upload, so will continue in next post.
    Tube Silicone
  2. Mar 14, 2013 at 9:19 AM
    mjbirdie75
    Cordova, TN
    05 PreRunner White
    Next Pics, I did the compass fix while I was at it.
  3. Mar 14, 2013 at 9:25 AM
    mjbirdie75
    Cordova, TN
    05 PreRunner White
    The box I made over the course of a few days, couple hours here, couple hours there. I elected not to upholster, just some wood filler over all the outside joints, prime, and paint. My rear cab is crammed with tools day in and day out and if I ever have a passenger, it's just one. Definitely not a show truck.
    I found that a piece of 12 gauge electrical wire helped a great deal to keep the door boots as open as possible when trying to fish the speaker wire through there (I guess a coat hanger would work too, which I had read someone used in another thread).
  4. Mar 14, 2013 at 9:36 AM
    mjbirdie75
    Cordova, TN
    05 PreRunner White
    A few more pics
    My head unit only had two sets of pre-outs: one for Front and one for Rear/Sub, so I used splitters on the rear/sub pre-outs to allow for all 3 sets of signal cables. Again, not a show truck, I just like a "full" listening experience, and the gear and setup works for me.
    I guess what I'm saying is, it sounds good to me and this setup is not for competition. It is quite a stark contrast to just running the cab speakers off of the head unit though!
    Last pic is rear view camera inside Pop-N-Lock tailgate handle. Did that a while back, just thought I'd post that too.
    I'm extremely grateful to all of you TW members out there for posting up so much info on these trucks. It really took all the guess work out of doing this and my other projects.
    I'm sure I would never have done half the stuff I've done to my truck if I had to take it to a shop for install. DIYer, what can I say.
    And thanks again to Chadderkdawg for the inspiration on the sub box. U da man! (Go Huskers! I grew up in Omaha) ;)
  5. Mar 14, 2013 at 9:48 AM
    Lazylegs
    Lazylegs Well-Known Member
    Craig
    Southern Maryland, USA
    2011 Red Toyota AC Sold
    Tint (35%), a must. Step bars, Bull bar, Bull lights,4x4 light mod, Flip down 10" DVD player, De badged, Color match front emblem, color matched bumpers., black out tails, Cobra cb, Flashlight mod,bed-light mod,
    Just a heads up!g Placing that amp under the seat is a harsh place to install. If it shorts out your on fire. There is not enough airflow to keep the Amp cooled. It should be off the floor. The floor gets hot. Props on the DIY..
  6. Mar 14, 2013 at 9:51 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Nicely done
  7. Mar 14, 2013 at 1:48 PM
    mjbirdie75
    Cordova, TN
    05 PreRunner White
    I certainly follow your point. Space is at a premium in this thing. I need the rest of the rear cab room for my tools. Any suggestions?
  8. Mar 14, 2013 at 1:49 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Does you amp have a fan?
  9. Mar 14, 2013 at 1:56 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Excellent work, looks great. I have my amp under the seat as well, have had zero problems so far.
  10. Mar 14, 2013 at 2:20 PM
    mjbirdie75
    Cordova, TN
    05 PreRunner White
    I'm sure it doesn't. I know that the amp needs air space, but it seems like it has a pretty good bit. The ass end of the seat upholstery hangs down in a way that makes it look like there isn't any, but I looked and it has at least a couple inches of clearance between the top and sides.
    I think I feel myself starting to get paranoid.
  11. Mar 14, 2013 at 2:23 PM
    mjbirdie75
    Cordova, TN
    05 PreRunner White
    Thanks man! Glad to hear that, I'm cetainly not looking to start a fire under my seat!
  12. Mar 14, 2013 at 2:25 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    my amp as been under my seat since 2006. never had a problem with it getting too hot
  13. Mar 14, 2013 at 2:26 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Just looked it up on crutchfields, not fan cooled. Mine is under the seat also but it is fan cooled. You probably dont have to worry about it unless its 100 degrees inside your truck and you are blasting music for hours. Your setup looks awesome, check out my access cab sub, pretty uh...unique http://www.tacomaworld.com/forum/au...-enclosure-09-access-cab-under-rear-seat.html
  14. Mar 14, 2013 at 2:38 PM
    mjbirdie75
    Cordova, TN
    05 PreRunner White
    Thanks for the input! I looked at your thread, that's awesome!
    In the summer, here in Memphis, it does get XTRemely hot, so I'll keep that in mind. I do love to blast it, but after a few songs my age starts to show. Sometimes I feel like quite the puss turning it down, but what can I tell you?
  15. Mar 14, 2013 at 2:42 PM
    mjbirdie75
    Cordova, TN
    05 PreRunner White
    :rockband: Danke!
  16. Mar 14, 2013 at 3:12 PM
    mjbirdie75
    Cordova, TN
    05 PreRunner White
    I checked out your build, btw. Badass! My Dad worked at Langley for about 8 years in the 90s, so very familiar with Newport News, Williamsburg, Hampton, etc. Love being down there! (Most of it anyway ;))
  17. Mar 14, 2013 at 4:05 PM
    Aw9d
    Aw9d That one guy
    Just space the amp with some 1/2 spacers to get it off the carpet and you'll be fine. I live in Az, ran amps under my seats for years in this heat, no problems.
    Plus to help cool, run the AC to the floor if your worried.
  18. Mar 14, 2013 at 4:29 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    yeah i want out of that area. not really cuz of the area, mostly from just wanting to pcs to another post
  19. Mar 14, 2013 at 4:43 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    My installer told me the same, so I chose this as a good spot.
  20. Mar 14, 2013 at 8:39 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I've ran amps under my seats since 2003 with no issues.
