My suspension project. HELP!
Discussion in 'Suspension' started by Eesh, Jul 8, 2009.
  1. Jul 8, 2009 at 11:46 AM
    Eesh
    Eesh [OP] Well-Known Member
    Regina, Sask., Canada
    trd Sport
    Hey guys, I'm going to be starting work on my suspension. I have an 06 TRD Sport Regular box 4x4 . So far all I have is Icon coil overs and Total Chaos UCAs. I don't want to be flamed on here. I have read ALOT about things. I'm not going to be using my truck as an off road machine, but I do travel alot of winter snow covered roads so I like the clearance.
    What I need help with is what should I do with my rear end? I want 2.5 to 3 inches of lift and I wouldn't mind increasing payload a little if that was possible.. I have the TSB done on my rear leafs. What are my options? I don't want the resivoir shocks. Do I need to go with different leafs or an add a leaf? What kind of shocks would be good? Your help is greatly appreciated.
  2. Jul 8, 2009 at 11:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Toytec has an AAL that should be good for about 2" of lift, and you could get some OME N182 rear shocks....
  3. Jul 8, 2009 at 3:25 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    wheelersoffroad.com has some OME leaf springs that give 2.75" rear lift.
    OME 2.75" Lift Leaf Spring Set: 375.00/pr [​IMG] THESE OME DAKAR SPRINGS
  4. Jul 8, 2009 at 3:29 PM
    Eesh
    trd Sport
    K so If I went with the OME with 2.75.... would I need different rear shocks?
  5. Jul 8, 2009 at 3:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes.
  6. Jul 8, 2009 at 4:17 PM
    bermise
    Houston
    08 TRD off road
    you will have to indeed.
  7. Jul 8, 2009 at 6:15 PM
    Eesh
    trd Sport
    K so .. the leafs will add 2.75 inches. Which I am happy to hear. What some good options for rear shocks?? Also do I need the diff drop etc. if I'm keeping my lift under 3 "????
  8. Jul 9, 2009 at 5:11 AM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    Bilstein, OME, ICON, Fox, King all have really good shocks for lifts. You don't "need" the diff drop and some say it's pointless but for the price I just went ahead and picked it up as well.
  9. Jul 9, 2009 at 1:10 PM
    bermise
    Houston
    08 TRD off road
    +1 Yea my diff drop is sitting in the drawer next to me. I did not need.
