My Taco: 2000 Reg. Cab TRD Prerunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000TRDTaco, Dec 15, 2013.
  1. Dec 15, 2013 at 5:38 PM
    2000TRDTaco
    2000TRDTaco [OP] Well-Known Member
    Corey
    Angier, NC
    00 Prerunner
    Just joined up a couple of weeks ago, so I thought I would show off my junk a bit
    Originally bought used in 2004 w/ approx. 60k miles.....daily driven since then back and forth to college and work (Western Carolina Univ.)
    Currently:
    175,XXX miles
    2.7 Auto
    265/75/16 Nitto Terra Grapplers
    Factory TRD wheels
    Truck runs like new.....gets oil changed every 5k, basic maintenance
    Nothing major besides new battery, starter
  2. Dec 15, 2013 at 5:47 PM
    2000TRDTaco
    Corey
    Angier, NC
    00 Prerunner
    New Bilstein HD rear shocks
    New Headlight assemblies and Philips Crystal Vision Ultra bulbs.....so much brighter than stock
    Also I am currently working on a front bumper mount for my 13" LED lightbar.....Since I am a welder and we have a machine shop where I work, I have access to 4 HAAS CNC machines, plus 2 manual CNC machines.....I made the mount out of 2" x 3" Alum. angle.....milled out some spots and drilled some holes so I can mount it in the license plate location (when mounted it doesn't move at all)
    Hoping to get it all mounted and wired up this coming week.....will post pics
  3. Dec 15, 2013 at 7:38 PM
    yoterdude
    yoterdude Well-Known Member
    Jared
    Athens, AL
    2000 Taco SR5 TRD
    Aero Turbine 2525, Aero tip, AFE Dry Pro S filter, deckplate mod, TRS Morimoto Mini H1 projectors, TRS xBLed angel eyes, Vent visors, Blacked out tail lights, LED turn signals, 10w LED auxiliary reverse lights, 20in LED light bar, OTRATTW switches, LED interior lights, Blue needles, front Bilstein 5100s, Eibach coils, Bilstein 5100 rear shocks, OMD leaf spring mod, Trail Gear low profile bumper, Black grill, JVC KW-HDR81BT head unit, Husky Liners, 5% tint all round, 50% tint on windshield with 9 inch strip, front Wet Okoles, stickers, and a rubber ducky on the antenna :D
    Great looking truck man! I like that light bar your building. I'm going to college now for CNC machining and I'm currently working on a light bar mount for a 20" led light bar too. Keep up the good work man!
  4. Dec 16, 2013 at 5:08 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    Interesting...haha
  5. Dec 23, 2013 at 2:29 PM
    2000TRDTaco
    Corey
    Angier, NC
    00 Prerunner
    LED Lightbar mount is finished and everything is wired up.....WOW! this thing is insanely bright
    Painted gloss black and hit with some clearcoat.....will get some pics of everything on and working when the weather gets better outside
    Also, my LED lightbar rocker switch from OTRATTW
  6. Dec 23, 2013 at 10:57 PM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    Nice truck! LED bar is lookin good :cool:
  7. Jan 22, 2014 at 3:33 PM
    2000TRDTaco
    Corey
    Angier, NC
    00 Prerunner
    Well I finally got around to ordering my Bilstein 5100s and my rear leaf springs.....my stock springs are original with 175k on them and are basically flat when unloaded
    Also ordered new coil springs, poly. isolators, new hardware front and rear, new u bolts, and new rubber shock bushings
    I plan to take some pics before, during and after when I finally get around to installing all of this
  8. Jan 24, 2014 at 1:02 PM
    geodude
    geodude Well-Known Member
    Good looking truck, how do like that tool-box? I've been looking at buying that same one from Lowes.
  9. Jan 25, 2014 at 7:21 AM
    2000TRDTaco
    Corey
    Angier, NC
    00 Prerunner
    I love it....the low profile of it is great.....its slammed full of tools, hunting boots and other misc. stuff
  10. Feb 9, 2014 at 12:35 PM
    2000TRDTaco
    Corey
    Angier, NC
    00 Prerunner
    Well finally got around to installing my new leaf springs (original size ordered from rock auto.com).....these actual gave me almost 1.25" of lift in the rear due to the old ones being worn slam out
    Also installed my 5100s in the front (set on middle setting) and got almost 2" of lift before alignment
    I would recommend NOT trying this w/o a spring compressor.....I got the passenger side off w/ no problem but putting the new stuff on proved to be a PITA
    Went to O'reilly auto up the road and rented me a spring compressor and it worked like a charm......It took me less time to do the whole other side than it did to just get the passenger side back together
    Will post the pictures I took when I upload them from my phone......all in all it took me about 4 hours for the rear (last sunday) and about 4 hours for the front (today)
  11. Feb 9, 2014 at 12:36 PM
    Fiolo
    Fiolo Senior member
    1998 Tacoma, 2022 Tacoma, 2019 L5P Duramax
    Lost track many mods ago
    Nice truck ! Subbed
  12. Feb 9, 2014 at 5:11 PM
    Terminal4
    Terminal4 Well-Known Member
    South of the Sierras
    2022 DCLB 4WD
    Accutuned Fox suspension, Wildpeaks AT4, Batzmaru
    :bananadance: 2.7 reg cabs!
  13. Feb 9, 2014 at 6:40 PM
    2000TRDTaco
    Corey
    Angier, NC
    00 Prerunner
    Here are the rear leaf springs: old ones on the right and new ones on the left (both stock size, no lift in them)
    Old front shocks (these had rebound at all.....had to pull them back out by hand)
    New 5100s installed.....set on middle setting (LF is pictured)
    Pic from the front.....going to get it aligned on friday
    Old worn out leaves that will be for sale shortly.....hoping somebody local to Raleigh, NC wants these for cheap ($40 for both).....PM me if anyone who sees this is interested
    Will post side shots later
  14. Feb 9, 2014 at 7:54 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    subbed nice looking truck! I like the Led bar.
