My taco almost got away
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yellowrubiu, May 1, 2012.
  1. May 1, 2012 at 1:22 PM
    yellowrubiu
    yellowrubiu [OP] Well-Known Member
    Empire State
    2012 DCSB 4x4 SR5
    So my daughter knocks on my office window at home with a panicked look on her face and screaming your truck is moving…
    I have a steep driveway and depending on whether I'm head or tail in, I have been leaving the truck in first or reverse plus the parking break on. Well today I came home after running out to grab lunch and was rushing a bit because I had to get on a conference call for work. I backed up into the driveway (tail in) and put the truck in reverse BUT forgot to put the parking brake on :facepalm: Fast forward about 30 minutes when my daughter came home from school and the truck was about half way down the driveway plus about a foot away from one of the retaining walls :eek:
    I ran out and averted disaster but WTH, should this be happening? I never had this previously happen with any other manual car. I've always left cars with reverse engaged when parked downhill and never experienced this, maybe I never forgot to put the parking brake on.
    I sat in the truck put it in reverse without the parking brake and sure enough, it took about 30 seconds, but eventually it crept forward and stopped, then did it again. This doe not happen in first gear. Does anybody know why?
    One thing is for sure I will not be forgetting to put the parking brake on again any time soon :smack:
  2. May 1, 2012 at 1:27 PM
    tdubya72
    tdubya72 Well-Known Member
    Tracy
    Longview, TX
    '13 TRD 4x4 DC SuperWhite
    ARB Bumper, WARN Synthetic M8000, ARB intensity LED Floods, OME suspension all around. 18 Fuel Revolvers with Wrangler MTR Kevlar.
    Sounds like the truck just doesn't like you that much
    :boink:
  3. May 1, 2012 at 1:29 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    SAS, dents, & scratches
    happens sometimes, the weight of the car/truck can turn over the engine kinda like a bump start ;) e-brake her when on any hill
  4. May 1, 2012 at 1:30 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    You parked on an incline, left your truck in reverse and didn't lock the brake?
    I always use my E brake when parking, especially if I am even remotely close to something that represents an incline.
  5. May 1, 2012 at 1:48 PM
    yellowrubiu
    Empire State
    2012 DCSB 4x4 SR5
    Yep, this is what it felt like afterwards when I was trying to recreate it... and yes always put the parking brake when on a incline, definite brain fart on my part but I guess my question is why would it not turn the engine when engaged in first gear.
  6. May 1, 2012 at 1:53 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    it happens because new engines are better made so they have much less friction in them, plus synthetic oil. Also first gear is lower than reverse so more torque is needed to turn engine over
  7. May 1, 2012 at 1:56 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    Yeah, I forgot once in my first car, even turned the wheels to the curb...
    Went to check the mail an hour later and it was down the street in a driveway! :eek:
  8. May 1, 2012 at 2:09 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I always set the parking BRAKE and leave it in neutral (Habit from having a turbo car with a turbo timer). I will put it in gear if I'm on a steep hill. Reverse if I'm pointed down the hill and first if I'm pointed up the hill.
  9. May 1, 2012 at 2:13 PM
    boshak
    boshak Well-Known Member
    Tony
    Southern California
    2003 Manual 4x4 5VZ-FE
    OME 881's, Wheeler's 5-leaf pack, Bilstein 5100's
    I always set my ebrake... Incline or not. Good habit so things like this don't happen. Worth the 1 second and lat pull for the day lol
  10. May 1, 2012 at 2:16 PM
    burnseason
    burnseason TENNESSEE VOL
    Tucker
    Khost, Afghanistan
    2011 TRD Sport double cab long bed 4x4
    none
    This happened to me with my Honda civic. Disaster!
  11. May 1, 2012 at 2:21 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Bull bar, nerf bars, bed extender, tonneu cover, bug deflector, wish list,....
    This will happen to me too one day. I never use the parking brake because Florida is flat and we do not have any inclines. I am just not in the habbit of doing it. My truck and other vehicles are auto, so they are locked up better when in Park, but probably still a good habbit to use the parking brake.
    Glad you caught it - go buy your daughter an ice-cream for calling you!
  12. May 1, 2012 at 2:22 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    in neutral? i am in gear with the parking brake on.
  13. May 1, 2012 at 9:55 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    1st is the gear to use, as Blue mentioned it is a lower ratio than reverse, and contrary to a common myth, engines are not harder to turn over backwards. I always use my brake, flat or on a hill, the cables never seize that way.
    In my younger and dumber days, my '83 hilux used to like to creep down steep boat launches even on 4lo, as the parking brake wasn't up to speed when I first bought it. It made you hurry!:D:D
  14. May 1, 2012 at 11:42 PM
    1980 Well-Known Member
    The Dust Bowl
    My '80 did the same thing when it was brand new (I later found that the parking brake wasn't adjusted properly from the factory).
  15. May 1, 2012 at 11:50 PM
    eh2win
    eh2win HIM
    09 prerunner
    afe s-dry filter
    im glad this hasent happen to me because sometimes i forget the e-brake that aint going to happen anymore
  16. May 1, 2012 at 11:59 PM
    SodakTaco
    SodakTaco Well-Known Member
    Wyoming
    2011 DCab TRD Sport
    Floor mats
    I was home visiting my parents a couple of years ago with my old manual 9-5 and I had decided to take the dog to wal-mart with me. They have a long driveway with a very slight incline. I forgot something and ran inside with the dog inside of the car, and I forgot to set the ebrake. I popped out of the house just in time to watch my car with the dog sitting happily in the drivers seat roll out of the driveway, across the street and right into a tree in the ditch. I always set the brake now, no matter what.
  17. May 2, 2012 at 12:24 AM
    seric007
    seric007 Well-Known Member
    who uses reverse? stick it in 1st and be done with it!
  18. May 2, 2012 at 12:27 AM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    sue toyota. lol. jk. don’t do it! i just had to say it, because when i read thread first think i thought of was all the toyotas “running away” and not stoping. lol
  19. May 2, 2012 at 1:04 AM
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    I always leave it in first with the parking brake. At the very least it'll keep the parking brake freed up and functioning well.
  20. May 2, 2012 at 6:26 AM
    macgyver
    Brad
    Canton, GA
    It's habit from when I drove a turbo car with a turbo timer. My car would still run for another minute and a half after I pulled the keys out. I couldn't leave it in gear with the engine running.
    If I'm on an incline, I will leave it in gear and use the parking brake.
